Question about Craftsman Push Rear Bag Lawn Mower w High Wheel (CA)
I have a Sears Craftsman 6.5 HP mower. It's about
I have a Sears Craftsman 6.5 HP mower. It's about 4 years old. It has become more and more difficult to start, and today a big problem. After getting it to start after priming and pulling a few times, it started to "knock" after about a minute, then shut down. I got it started again, but the knocking continued and it shut down after a few seconds. It's not a blade problem. Then, when I tried again to start it, I heard a loud "pop" and smoke came out of the side (muffler?). I tried again, and it popped again, Then, I tried to start it on an off for the next couple of hours....nothing! There's gas, oil, it's clean underneath.......I don't know what the problem is. Can you help ?
  • 8 Answers
SOURCE: Craftsman mower will not start without starting fluid
Sounds like you have water / debris in your carb fuel bowl. Using spray carb cleaner will only work if you remove the bowl and clean the carb jets. Also, you could have water in the gas tank as well. First, remove your air filter, then remove the 3 screws that attach your filter bracket to your carburator and mower. Take off your fuel line at the carb and drain all your gas into a clear jar. If it looks very yellow, cloudy, or see water in the bottom of the jug, change your gas. Using a half inch socket wrench, after gas line is disconnected, remove the fuel bowl and clean with carb cleaner. Also, examine the bolt you just removed. There are 2 jets in the side and one at the end. Using the carb cleaner, make sure they are clean as well. Use the carb cleaner extension tube to spray up inside the bottom center of the carb, where the bolt threads, to clean that area as well. After all this make sure your float assembly is intact and reassemblt the bowl to the carb and reattach the the fuel line. finish by reattaching the air filter support bracket making sure the gasket between the carb and the bracket isn't damaged. Also, never use last year gas, alway buy freah every year.
Posted on Jun 07, 2009
  • 4 Answers
SOURCE: craftsman 6.75hp self propelled mower starts and turns off
I think that this is a 4stroke engine and runs on neat petrol.Have you been putting oil in with the petrol like a 2 stroke engine needs because this would account for the smoking.If not the check that you havn't overfilled the gearbox oil.
Posted on Jun 12, 2009
lasvegasrich
  • 65 Answers
SOURCE: Looking for a manual on a Craftsman Eager-1 .
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=131.90300&productCategoryId=1503700&brandId=0247&modelName=ROTARY-LAWN-MOWER&diagramPageId=00001&documentId=00035640&pop=flush
PARTS LIST AND PICTURE.. WHAT DO YOU NEED TO KNOW OR DO??
Posted on Aug 22, 2009
  • 110 Answers
SOURCE: I need to find mounting bolts, blade to shaft
Do you meanengine mounting bolts, blade boss, and 'Operator Presence Control' cable? If so, they are generic parts - not specific to your mower. I have no idea why you are having problems ordering them - they are consumable parts, and should be stock items for ant garden machinery repair outlet.
Posted on Sep 24, 2009
rwvanlue
  • 486 Answers
SOURCE: I have a Sears Craftsman mower with Tecumseh, major oil leak
On many Tecumseh engines, there is a crankcase breather located under the flywheel. It has a cork gasket to seal the top plate of the breather. Either the rubber breather housing is cracked, or the cork gasket needs replaced.
Posted on Nov 08, 2009
Where can I obtain a manual 4 a Craftsman Riding 42" Lawn Mower - Mdl.#944608760?
at the sears parts website. They usually have them for sale or as .pdf files. you will need to know the sears model number.
http://parts.sears.com/partsdirect/index.action
Aug 31, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Where can I find the model number on my Sears riding lawn mower? It is about 6 or so years old.
Sears puts the model numbers under the seat on most machines since 1990. They are in the format
xxx.xxxxxx
example 538.678567
Good luck
Mar 28, 2011 | Craftsman 42" Briggs Stratton 20 hp Gas...
Craftsman riding mower-what year was it made
Hello! The 917= American Yard Products...A major supplier to Sears...The first six digits of the SN#...00/00/00= date of manufacture...In your case...May,1,1997...
Guru.....................Saailer
Jul 08, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Sears Craftsman riding mower V belt getting chewed
I believe you may have the belt over one or more of the belt retainers next to the pulleys. They are 5 or 6 inches long and about a 1/4 inch in diameter. You have to loosen them when you put the belt on then adjust them to where they are just barely touching the back of the belt. They keep the belt from jumping off.
May 01, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Sears craftsman 6hp chipper-shredder FLYWHEEL.
Go to Lowe's they will found the part for on the computer and will tell you where it is at in the store!!
Oct 12, 2009 | Craftsman Gas Mini - Tiller/Edger
Sears Riding Mower stops running when the blade is engaged
check the deadman sensor under or in the seat. if it don't "see" you on the seat then the mower will shut down. good luck and hope this helps
Jul 27, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman snow blade install instructions
Go to sears.com and click on the PartsDirect link at the top. Enter the model number of the blade and you will see a parts diagram of blade. Hope this helps.
Dec 14, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman Lawn Tractor - 6 yrs old
just go to sears .com and put in the modle number . youll get the exact price
Oct 01, 2008 | Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman Push Rear Bag Lawn Mower w High Wheel (CA) Logo
466 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dean Gruber
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
