Question about Samsung SyncMaster 2493HM Monitor
My Syncmaster 2493HM wont turn on, The led is solid blue, (unlike most here that flash) with zero light. Sometimes, it will flicker on, and i will here it trying to turn on (it makes like a zapping or snapping noise) also, when it does turn on after I shake it a tad, it makes a high pitch squeak and turns on. When its on its no problem! Also, (this may help) there is no sound when the monitor is in this not on state, but as soon as it does kick on sound is no problem...
  • zdenardi May 18, 2010
    the sound is coming from the speakers, i found out,
    and no, i found the unit in the trash (someone threw it away) and i didnt even think about trying to check the warrenty until i opened it...
    then i found out i voided the warrenty,...
    Problem Solver:
Sorry for my bad english but i´ll try to help you because i´ve got the same monitor. You must check the power source there is a problem with the glue you must clean it from the components with the time it becomes conductive. Check the capacitor from the inverter source if you can chage the capacitors by about equal. When you asemble it again don´t foget the protective plastic because it may cause a short.
Posted on Dec 06, 2014
  • 11,361 Answers
The snapping sound can be from high voltage arcs over or open lamp circuits, check the connectors for the lamp on the circuit board.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on May 14, 2010
  • 732 Answers
Zdenardi, Good description of problem but you left out two or three important things to tell us!!! 1. Age of unit 2. Is unit covered by Samsung warranty? 3. Approximate total "ON" hours of use has unit seen. Aynway, you or a qualified "cold-cathode-fluorescent-lamp back-lit lcd monitor" technician will need to troubleshoot the units switch-mode-power-supply/ccfl inverter" circuits to determine reason ccf lamps won't "turn-on"!!! Just read my fixya profiles (louie12fix, 12fixlouie) or those of "buddymc" and "budmrtn" for info that will determine if you will fix unit or contract out the repair. You need to know that your symptom is called "black screen" or "blank n black screen" and will only get worse. Just do some free reading on fixya and follow the links you find to other sites. Good luck with the repair. 12fixlouie
Posted on May 12, 2010
Mitsibushi WD-60638 , just replaced the lamp now tv flickers and shuts off with a solid red led light , can anyone help me fix this ?
not sure but check internal fan is functioning correctly...I had same problem with a hitachi
Feb 23, 2013 | Televison & Video
It seems like im having some issue with my syncmaster2493 monitor. it will black out and once i wiggle the power cord it will come back on. any help will be apprecaited
Your power supply board is failing and when you wiggle the cord it is turning it on and off until it finally starts up. There are parts called capacitors that start failing and it will cause intermittent power issues such as slow to show picture, flashing power button, wavy or flashing picture. The board can be repaired and the monitor will be as good as new. Here is a picture of the power supply with the parts circled that need to be replaced.
There is a step by step repair guide for the Samsung 2493HM unit here:
http://www.ccl-la.com/blog/index.php/reparing-a-samsung-2493hm-24-lcd-monitor/
I hope this helps, if so please rate my solution.
BuddyMc
Jul 30, 2011 | Samsung SyncMaster 2493HM Monitor
Samsung monitor 2493HM wont power up I plugged it it and the blue light came on for about 5 seconds then went out and I havent been able to get it going again.
The Samsung 2493HM monitor are known to have an issue with the power supply. When the power supply fails you get the 'no power' or 'slow to show picture' problems like you are having. The board can be repaired and the monitor will be just like new again. This is what the power supply board looks like:
Here is a link to a free repair guide that will walk you through the repair.
BuddyMc
Jul 02, 2011 | Samsung SyncMaster 2493HM Monitor
On light flickers instead of being solid blue and monitor will not come on
Power off the computer leave the monitor on then go to the computer power button once computer is off and unplug the cord press and hold the power cord down for 5 seconds you should see a blink of light then plug the computer back in and reboot the machine. If this does not work get another monitor to check the video card borrow one to see if it works with a mock monitor if that does not work then it is your video card that is the issue and not the monitor. Change out the video card. if the mock monitor works fine then your original monitor is broken and will need to be replaced.
Jan 08, 2011 | Samsung SyncMaster 2493HM Monitor
My Samsung SyncMaster 2493HM Monitor has trouble starting. When my monitor has been off for a while and I restart it. It makes a little beeping sound and the little light on the right bottom of the screen...
The Samsung 2493HM monitors have an issue with power supply failure. When the board starts failing can be slow to show a picture, have no power at all or have a way or flashing picture. Your monitor sounds like it falls in the slow start category. The power supply board can be easily repaired and the monitor will be just as good as new. Here is a link to a free repair guide that will provide a step by step instructions showing you how to disassemble the unit, check and repair the power board.
BuddyMc
Apr 13, 2010 | Samsung SyncMaster 2493HM Monitor
The front LED flashes red & blue when I turn it on. What does this mean?
LED Indicators - LaCie 2big Network
The LED indicators above the drive bays and the front LED indicate drive status and activity.
During Startup
  • Front LED – blinks red/blue until both disks are powered on, then turns solid blue.
  • Rear LEDs – blinks red/blue until corresponding disk is powered on, then turns solid blue.
NOTE: If the device is not able to initiate the boot process following disk startup, the front is solid red.
During Bootup
  • Front LED – solid blue
  • Rear LEDs – solid blue
NOTE: If a disk is failing, both the disk’s corresponding rear LED and the front LED will be solid red.
During RAID Synchronization
  • Front LED – solid red
  • Rear LEDs – The LED corresponding to the original disk will be blinking blue and the one being synchronized is blinking red
  • Once both disks are synchronized, their corresponding rear LED and the front LED will be solid blue.
Apr 06, 2010 | LaCie 2 TB 2big Triple Interface External...
My Samsung 2493HM Monitor wont turn on, the blue light just blinks, then after some undetermined amount of time the light goes solid and all is well. It took over an hour today to start working. This just...
sales660, Monitor should not be doing that!!! Use Samsung warranty if available. Complain about "premature failure". Examine black screen for very faint displayed image with aid of bright flashlight(test all owners of CCFL back-lit lcd displays should know) to determine full or partial SMPS shutdown mode. Read more in my fixya profile for more that you can do. It could be bad capacitors or a thermally intermittant solder connection that you or qualified electronics tech will need to fix if warranty not option. After reading and surfing net you will understand your CCFL back-lit lcd display and how it works. Your monitor no different than ANY other brand of CCFL back-lit lcd monitor in it's basic design and operation!!! 12fixlouie
Mar 07, 2010 | Samsung SyncMaster 203B LCD Monitor
No picture; no operation except flashing blue lcd light.
Look at the power supply first, look for burnt parts, bad capacitors, etc.
Please post back what you find.
Nov 30, 2009 | Samsung SyncMaster 2493HM Monitor
Samsung SyncMaster 2493HM Monitor Logo
2,133 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
