Question about Samsung NV10 Digital Camera
Doesn't turn on, red light & flash pops up
The camera wont turn on.
when i press the power button, the flash pops up and the red light goes on.
cannot turn them off unless i take out the battery.
the battery is not dead, coz i even got a news battery for it, and the problem persists.
  • juarense Apr 13, 2008
    Same problem here, red light turns on, but does not turn on the camera, the flash does not pops up howewer
  • 3 Answers
Most probably your charger inside the camera has gone bad. Get an expernal samsung charger.
Posted on Jul 06, 2009
Sometimes, when we start the carmera and want to take a photo and press the button to take one, a small red light starts to shine. we didn't configure anything on the settings. this is really anoying
Sounds like a feature that comes on when using flash. The light comes on so in low light you can see and focus on what you are trying to photograph. Then we shutter button is depressed all the way the flash goes and picture is taken. Try turning off flash function.
Apr 23, 2014 | FUJIFILM Instax 210 Film Camera
Camcorder wont turn on at all
Are the batteries fully charged ?
Jun 17, 2017 | Mitsuba DV777 Camcorder
Bluetooth wont charge or power on. when charging the red light comes on. once disconnected from charger it wont come on
Indicator Lights:
1.Headset Status Headset Indicator Light
2.Powering on Steady blue, then intermittent flashes
(changes to standby mode)
3.Powering off Red appears and goes off
4.Standby Blue intermittent flashes
5.Charging battery Red solid light. Light indicator turns off when
battery is fully charged and headset is off.
6.Low battery Triple red flashes
7.Pairing mode Blue/red alternating flashes
8.Missed call Purple flashes. Press the call control button
to cancel flashing light.
9.Incoming call Triple blue flashes when ringing.
Power on and off:
1.Turn on the headset Press and hold the call control button until the
indicator glows blue. You will hear ascending
tones.
2.Turn off the headset Press and hold the call control button until the
indicator glows red. You will hear descending
tones. When power is off, indicator stays off.
If none of this is helpful then it may be that your battery is dead, if that is the case then you will need to replace the whole headset. The battery's are not replaceable.
Good luck from Headsets Direct!
Sep 21, 2011 | Plantronics Explorer 220 Bluetooth Headset...
My Ps3 Wont Turn On It indicates on stand by mode(solid red light).i pressed the power button; it wont turn on and it doesnt work or even beeps. i also tried using the ps button on the contoller.same...
Hi Shiman,
Are you seeing any flashingred/yellow lights?
If so this is the red lighterror and you will find that is why the system will not turn on.
Why Does It Happen?
The GPU and the CPU are the 2 main chips in the system and they deal with allof the number crunching however they can get very hot and if they loseconnection the system will either freeze up or turn off and give you the redflashing light.
How To Fix?
The key is stopping the heat build up and you can either send it in and theywill fix it for you.
Bear in mind that for the PS3red flashing light error you will be waiting for about 4 weeks and itwill also cost you $150 for the repair bill!
Other Ways To Fix?
You can also use a good PS3Repair Guide to fix it and this will show you how to stop the heatbuild up with a few household items.
Just make sure that you get a good guide there are some good ones out there!
Click Here For A CompleteReview Of All Available PS3 Repair Guides.
Hope this helps and any questions let me know?
Aug 13, 2011 | Sony Playstation 3 (PS3) Console
Nikon D40. How do i force the flash to work in daylight?
First, you have to be in one of the PSAM modes; in the other modes the camera decides whether it needs the flash and in daylight it will decide there's enough light without it. So, after turning the model dial to one of the PSAM positions, press the flash button on the front of the camera to pop up the flash. In these modes the camera will fire the flash if it's popped up, and not if it's down.
To change the flash mode, hold down the flash button (after it's popped up) and turn the command dial. Depending on the chosen exposure mode, your choices may include Fill flash, Red-eye reduction, Rear-curtain sync, Slow sync, Rear-curtain plus red-eye reduction, and Rear-curtain plus slow sync. Refer to the "Flash Mode" section of the manual for full details.
Jul 30, 2011 | Nikon D40x Digital Camera
When I press the power button the light turns
hi..
Try taking out your batteries and then taking out your memory card. Put back in batteries. Turn on camera.
If this works, just put back in your memory card and try again. Sometimes the memory card hangs and you need to pop it in and out.
thank u
rate me!!
Jul 15, 2009 | Sanyo Xacti VPC-S770 Digital Camera
Changed bulb, now tv does nothing. . .please help
same problem. TV turns on but no picture or sound. when i press power button on the remote control orange light flashes for about a minute and goes back to red.
TV won't turn on. It iz frustating me a lot ay !
Mar 07, 2008 | Televison & Video
Samsung NV10 Digital Camera Logo
290 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
