Question about Champion International Champion& Small Engine Spark Plug 8 Pack
Honda GX 390 with electric start does not charge battery, what could be the problem?
    Problem Solver:
  • 10 Answers
This is the answer to your problem pool tile cleaning
Posted on Jun 16, 2011
Parts manual
go see a HONDA dealer
Jun 25, 2017 | Cars & Trucks
Ihave a honda generator with a gx 390 motor volt drops when i put a load on it what could it be
Voltage regulator, carbon buildup in the cylinders, the carburetor may need overhauling, engine governor may have a stretched spring, Spark plug may need replacing, Timing may be off, air filter may need changing, and lastly, your load may exceed the ability of the generator.Checking this list will uncover the loss of power
Oct 20, 2016 | Honda Electrical Supplies
I have a honda gx 390 that kicks back when i pull the rope to start
The ignition timing may be too advanced . Some times if the pull start rope is not pulled hard enough it will kick back, The ignition fires just before top dead center , if not pulled hard enough it will kick back.
Oct 15, 2014 | Garden
I installed a new GX 390 Honda engine in a Toro 413 TX machine. Motor starts, idles and full throttle fine, but when hydraulics,i.e. drive is engaged, motor dies.
you have a dingo, ugh
I would suspect a bad pump or wheel motor if the rpms are set correctly and no safety switches are causing it to die...
Dec 26, 2013 | 13 HP Electric Start GX390
I have a Honda GX 390 with 13 hp power washer. Overheating.
Make sure the engine is not full of paint or dust debris in it's cooling system. If the fuel mixture setting is very lean, it can cause overheating. Make sure the fuel tank vent is open to prevent fuel starvation. Does the engine seem to be running at full operational speed? If not, it will be short on developed horsepower. Make sure the water source is not partially shut off. Hope some of this helps!
Feb 25, 2010 | Air Tools & Compressors
Honda gx 390 only starts when it feels like it
Sometimes you have to lower the air pressure in the tank to allow it to run. The back pressure from the compressed air in the compressor head overcomes the pressure created in the engine at the slow RPMs you are able to pull while attempting to crank it.
Aug 13, 2009 | Honda Quincy 17 - Gallon Air Compressor...
Honda GX 340-Used to start and run no problem, now nothing
I think both problems could be wiring in the key switch box. Sometimes the connectors shake loose.
Jan 17, 2009 | Honda Pressure Washer PSI 3000
Champion International Champion& Small Engine Spark Plug 8 Pack  Logo
452 people viewed this question
Top Champion International Garden Experts
JohnPaul Robertson
chuck ringwood
chuck ringwood
Dennis Key
Dennis Key
Are you a Champion International Garden Expert? Answer questions, earn points and help others
