Question about Fedders A6P09D2B Portable Dual Hose Room Air Conditioner
Just brought home a fedders aep09d2b*b portable air conditioner. bought it used. it worked well there but when I plugged it in at home it is making a lot of fan noise - more noise the higher the fan setting. sounds like it needs a lube job- can I use wd40?
    Habit-Forming:
  • 156 Answers
If it was running fine before and you moved it and it's making noise, it sounds like something fell against the fan blades. The reason it sounds worse when you turn it up is that the fan is running fast. Grab a flashlight and check to see what might have fallen.
Posted on May 12, 2010
I have a Fedders portable roll around unit that is leaking water all over floor from underneath the unit. it does not look like the drain line is clogged. used to drain through hose but does not anymore....
Hello, Take a clothes hanger wire in the hole a little ways and see if it is stopped up. If that doesn't work get a can of air and blow in the hole.
Jun 05, 2014 | Fedders Heating & Cooling
WOULD LIKE TO KNOW IF A MANUAL IS AVAILABLE ONLINE. TO DETERMINE HOW TO USE OTHER FUNCTIONS THAN AIR COOLING.
I'm sure you can find an Owner's Manual for your unit, if you do a Google search for Maytag M6P09S2B Portable AC Owner's Manual. Most will be free downloads, some you may have to pay for. n addition, the Maytag AC Units were made by Fedders/Airwell under the model # AZ6P09S2A. So, if you can't find it under Maytag, search for the Fedders model number.
Hope this helped you and thanks for choosing FixYa.
Sep 21, 2011 | Maytag M6P09S2B Portable Air Conditioner
Fedders AEP09D2BCOM Portable Air Conditioner. The unit shut off and the buttom with a triangel and ! is flashing
That flashing triangle indicates that the water collection tank is full and must be drained.
Aug 01, 2011 | Fedders AEP09D2BCOM Portable Air...
I have a fedders portable a/c unit and it works for five minutes and it then shuts down. The circuit braker does not trip and I plugged the unit on different locations with the same results. The unit has...
Thanks for your information that " The unit has very cold air".It's cut off by indoor coil sensor.
Reason for shut off in 5 minutes.(There are one or more reasons for the problem) Check as follows.
1. Evaporator coil,air filter and bower wheel full of dusty. Service your unit completely.
2. Check rpm of blower motor. If less rpm replace capacitor.
3.If all above is o.k and still problem means defective coil sensor. Replace it.
Hope, it's helpful?
Jan 19, 2011 | Fedders A6X05F2D Air Conditioner
My danby portable air conditioner won't turn on
New or used? Is is plugged in? Is there electric at the plug? Plug a light in there and make sure it works as a test. Next, check the water pan to make sure it is not full of water. There is a switch there that could be causing the problem.
Jul 06, 2010 | Danby 7,000 BTU Portable Air Conditioner -...
I can't find the window adapter and hose for the portable Fedder #A6P09S2b.Any suggestions?
Cut a piece of plywood to fit your window opening, install a flex connector ductboard%20collar.jpglike the one shown here, and use flexible duct to connect to your unit and the connector you attached to the plywood. flex-duct.gif
Mar 19, 2010 | Fedders SFPEB08F2A Air Conditioner
Can you install an portable window fedders a3x05f2c sideway?
You sure can, but it will not work for very long. The compressor is designed to work the way the Mfr. has made the A/C and if you tilt it up, then the compressor will "flood" out and come to a screeching halt. The kind of screeching halt that makes you go buy another A/C. Do your wallet a favor and set the unit correctly.
Sep 05, 2009 | Fedders A3X05F2C Air Conditioner
FEDDER'S PORTABLE UNIT SAYS STOP. WONT RUN
Disconnect power to the unit and reconnect. If "stop" is still on the display you will probably need a qualified technician to trouble shoot. The best mode is the snowflake (cooling). The rain drop is dehumidification which can cause condesation on unit.
Aug 30, 2009 | Fedders A&B Chassis A1A07W2B Air...
Fedders A6P09D2B Portable Dual Hose Room Air Conditioner Logo
324 people viewed this question
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
