Question about Motorola Mobility Droid (2 GB) Cell Phone
Does not take a charge and heats up. - Motorola Mobility Droid (2 GB) Cell Phone
  • 190 Answers
Time to change the battery.before you burn your droid
battery defective.
Posted on May 12, 2010
Why wont my HV-800 Bluetooth headphones stay charging? They charge for maybe 5-10 minutes then it stops charging and i know theres nothing wrong with the charger.
Those batteries are very small and when they wear out, you are done. Over charging is the leading cause of heat and heat destroys the battery.
May 27, 2015 | Radio Communications
Tip
I disagree with your stament "Heat Pumps are very sensitive to either under or...
Adding Freon to an air conditioner or refrigeration system takes very specialized equipment and years of experience...it would be impossible and irresponsible of me to try to tell you how to do it through a computer.
Let me explain this further….
In small refrigeration systems such as you have in a refrigerator or a beveage cooler, the amount of freon in the system can often be measured in ounces of weight. Many times, just a few ounces. To get these charged correctly takes tons of experience and very finely tuned equipment. Just removing the hoses can release enough freon to make the difference between the system working or not working. Very sensitive scales are needed to weigh in the freon. To make sure the correct amount of freon is in the system, the system must be evacuated to a complete vacum. You need to have a special pump to do this.
To add to this, most small refrigeration systems are factory charged and sealed. They do not have access ports built into the system. To do anything to these system an access port must be correctly placed in the system for proper evacuation and charging. Then also add the the equation the fact that if you need to add freon to your system, where did the exsisting freon go? Finding and fixing very small leaks also takes sophisticated detection equipment.
The next problem is the many different types of freon that are used today. Some equipment has the type used, very clearly marked, but many do not. Only knowledge and experience can tell what type freon is in the system, and then it can be very difficult sometimes.
Air conditioning systems can be a bit more forgiving, but are getting more and more difficult to analyze and figure out exactly what is going on. The many types of refrigerant and variable speed compressors are making troubleshooting very difficult. Add temperature sensors and variable speed condenser fan motors into the mix and it becomes a nightmare.
Heat Pumps are very sensitive to either under or over charging. The only correct way to charge a heat pump is to evacuate the system and weigh in the correct charge.
Leaks in heat pumps or air conditioners are often very difficult to find, also. But finding a leak and fixing to correctly is the only way to achieve a successful repair of an air conditioning or heat pump unit.
So hopefully now you can see that refrigeration, air conditioning, and heat pump system charging is not something that can easily be done without the proper training and equipment.
Oh, and did I also mention that it is illegal to handle and repair any type of system the contains any type of refrigerant with out a refrigerant handling certification in the United States? Yes, and the although rarely anyone has been charged, it still is the law.
Please call for a certified repair technician to repair any refrigeration system and do not try to do it yourself.
on Oct 01, 2010 | Refrigerators
Tip
Charging you laptop battery by Ultra fast charger
Some producers argue charger incredibly reduced charging times of 30 minutes or less. Cells with well-balanced and operating at moderate temperature, nickel-cadmium Dell Inspiron 1525 Batteries designed for fast charging can indeed be applied in a very short time. This is done simply dumped in a high charge current during the first 70% of the charge cycle.
In the second phase of the charge cycle, the charge current should be lowered. The absorption efficiency of the Asus M6000N battery charge is reduced gradually shifts to a higher charge state. If the charge current is still too high in the later part of the charging cycle, the excess energy is transformed into heat and high pressure cell. Eventually, the ventilation will occur, releasing oxygen and hydrogen. Not only reduce the gases escaping the electrolyte is highly flammable! A white powdery substance accumulating in the mouth area indicates the previous outburst.
Ultra-fast charging can only be applied to Dell PC764 battery that are designed for rapid recharge. Applying a high current charge for normal cells will cause the conductive path to heat up. The contacts on the portable packages also suffer if the current arrangements for contact management piston spring is undervalued. These contacts can wear out prematurely. Often, a fine and almost invisible crater appears on the tip of the contact, causing a high resistive path and forms an insulator. The heat generated by a bad contact often melts the plastic. touch voltages exceeding improve the flow of current.
old Dell Inspiron 1501 Battery with high internal resistance and the corresponding cells do not lend themselves to ultra-fast charging, even if they were designed for it. Low conductivity cell is transformed into heat, which further deteriorates the cells. Weak cells which have less capacity are fully charged before the others and begin to heat up quickly. Some HP 530 battery create enough heat to soften and distort the plastic case. Temperature sensing is a prerequisite for rapid and ultra-fast charging.
Several manufacturers offer chargers wrist. Interspersing short bursts of discharge between each pulse of charge can further increase the charge. This method promotes the recombination of oxygen and hydrogen gas, resulting in accumulation of reduced pressure and temperature of the lower cell. Pulse chargers are also known to reduce the crystalline formation (memory) for Nickel-based. Most of the Cadex Inspiron 1525 Battery charger for dv8000 Battery based on nickel implement this function.
Some advanced chargers adjust the charge current according to Dell Inspiron 9300 Battery capacity to accept charge. A DELL E1505 Battery takes a charge initially very high current. Towards the end of a tax, the current is tapered down. batteries have aged since their respect and are automatically charged at rates appropriate to their condition.
on Apr 21, 2010 | Computers & Internet
It overheats when charging
It's typical for heat to be generated during the charging process, but if you feel the heat is excessive your best bet is to contact the manufacturer or your local representative that you purchased the device from.
Sep 06, 2014 | Spectra Precision Spectra Ranger 3 Data...
Samsung c3303 becomes heat during charging
samsung 3303 become heat during charging
Jun 04, 2012 | Cell Phones
Battery heat's up
i put mobile to charge on yesterday at 9 pm after three hours i came to take the phone .but the phone did not charge and it has got very heat whole phone got o heat and now it is not getting on
Jun 02, 2012 | Samsung Omnia II I8000 Smartphone
My nokia 6303 get heat when charge and use
Problem with the Nokia 6303 Cell Phone My nokia 6303 get heat when charge and use
Mar 10, 2011 | Nokia 6303 Cell Phone
BATTERY IS BAD. CHARGE CORD HEATS UP. REPLACED CORD AND CHARGER LAST YEAR
Compaq chargers get heated up a lot when charging. This is a common problem.
Based on the issues you mentioned, unfortunately you would need to get the battery changed.
Regarding the charge cord getting heated up, try keeping it on a concrete/cold surface to lessen the heat. Unfortunately nothing more can be done about it, and as i said compaq chargers do get heated up quickly.
Thanks.
Feb 03, 2010 | Compaq Presario M2000 Notebook
Lg ku990 heats up.... i dont know why but every time i charge my phone it always heats up
LG phones have this weakness of getting heated up while charging and even sometimes while on a call. Try to put charging on the power socket that has enough grounding
Aug 09, 2009 | LG KU990 Viewty
Motorola Mobility Droid (2 GB) Cell Phone Logo
43 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
