Question about Akai CFTD2083 20 in. TV/VCR/DVD Combo
Tv\DVD Wont turn on
I have the problem posted by another AKAI victim. The TV's power indicator is red, then green when the power is initiated but it immediately turns back red and the TV never turns on. What can I do to resolve this? The TV isn't 2 years old.
    Genius:
  • Akai Master
  • 1,550 Answers
Quizas el sistema de la vcr este fuera de tiempo,por causa de la banda del motor de carga el aparato tiene que ser abierto para ser reparado llevalo a un taller.
Posted on Mar 29, 2008
Akai tv/dvd combo LCT3201ad 32" auto-shutoff or turns off after 3-5 seconds after being turned on.
Change input device to some other like a DVD player and see.
Switch off TV, switch off power, remove plug and wait for 48 hours and retry.
If problem persists, call in a qualified service technician.
Aug 05, 2012 | Akai LCT3201AD 32 in. LCD Television
Need to program remote for akai
Hello
You want to programme your Akai TV with a universal remote control; I assumes, and posts this solution.
Three digit universal remote codes for Akai TV are:
002/ 0030
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand
Feb 03, 2012 | Televison & Video
My akai flat screen tv is not turning on. the red light at the bottom of the tv is on and when the tv comes on the red light turns green and in a few seconds the tv comes on, when i press the power button...
i have one of these akai 27 inch with dvd, i had a similar issue i found a power supply at auction and exchanged it and it works fine now, normally with this symptom your power supply is fualty. if the light goes green and you have no picture then you know other boards are fualty
Jun 04, 2010 | Akai LCT3285TA 32 in. LCD Television
I have 32" akai that won't turn on - it is plugged in
I had the same problem witht he same tv that was given to me! I just took off the cover to the DVD player and unpluged all the connectors to it and then the TV worked. Now you will not be able to use the DVD player but you can hook one up externally
Oct 23, 2009 | Akai LCT3201TD 32 in. LCD Television
Problems with the tv coming on
Most likely is a problem on the vertical circuit. In any event, did is a not a fix it yourself problem. You are going to need a tech. Sorry.
Nov 04, 2008 | Televison & Video
AKAI WONT POWER ON!
The power supply on your LCD failed and will need to be replace or repair.
Let me know if you need further assistance.
Aug 28, 2008 | Akai LCT3201AD 32 in. LCD Television
Akai tv
The power supply most likely failed on your LCD.
How old is your LCD?
Jul 26, 2008 | Akai LCT3201TD 32 in. LCD Television
It seems like there's a problem with a component on the Power Supply of your TV or there's a problem with your Picture Tube. I don't recommend you working on TV's unless you know what you're doing since you can get badly shocked if you don't discharge the Ulter Cap on the Picture Tube. If you don't know what you're doing then I suggest you get it repaired by someone who knows what they're doing.
Apr 21, 2008 | Akai CFTD2083 20 in. TV/VCR/DVD Combo
Akai Plasma TV's screen suddenly went blank -model PDP4294
Same thing for me. TV just turned off one day and won't come back on. LED flashes red. Someone said it's because a cooling fan went out. If I can't find someone to fix it I'll take it apart and tinker myself. 32" with dvd built in was barely over a year old.
Nov 04, 2007 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Initial power-up
I just got done fixing an Akai LCT2660 that had four bad capacitors on the power board.Works perfect now.Hope this helps.Thank You very much!
Tyler
Dec 17, 2006 | Akai LCT2060 Television
Akai CFTD2083 20 in. TV/VCR/DVD Combo Logo
152 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
