Question about Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool calypso top load washer GVW9959k stuck on FL
Pressed stop tried to restart still goes to FL.
Did manage to get it to extended spin (8 minutes) spins but will not empty water eventually returns to FL and continues to buzz every 10 seconds
  • Whirlpool Master
  • 8,220 Answers
FL=FLOOD CONDITION
I bet I know what the root cause of the problem is. TOO MUCH DETERGENT. Why do I yell that? OK here is what happens. Suds make the computer monitor work overtime to wash the clothes. The the computer measures the amount of water being used. The computer is also trying to correct the suds problem by adding water during hissy-cycles. (I call em hissy cyles.) Solution: Clean the soap dispencer use HE soap and use the right amount which is:
HE: (2) Tablespoons Per Wash load
HE 2X (double concentrated) : (1) Tablespoon
HE 3X (triple concentrated): (1) Teaspoon
Calypso Service Manual
Posted on May 12, 2010
Whirlpool calypso top load washer stuck on FL
Fl means flood
you either have a bad flood switch or something is in the pump.
the pump is located under the washer
if you where to tip back and remove the 3 5/16 inch screws and look to the very right you will see the pump.
it could be these 2 things and or it could be something in your sump balls. which you would need special tools to gain access to.
let me know if this helps
May 12, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
FL code washer not draining
“FL” (Over Fill) flashes
The washer will beep every 10 seconds with no time-out. The
pump will cycle one half minute on, one half minute off, until
the overfill switch is reset or power is discontinued to the unit.
Press STOP/CANCEL to clear the display. Shut off the water
faucets to the inlet hoses if water continues to flow.
Here is the complete manual.
Jan 08, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Water pump out??
The washer filled with too much water, causing a switch to trip. Then everything stops. It tries to drain during FL but if it can't drain, the washer powers down.Choose Drain & Spin to let the washer drain. Then you have to take the washer apart. Fix the problem. I personally can't tell you what to do because I don't own a Calypso.
POSSIBLE CAUSES:
Bad Pump
High Water Flow
Other Causes
Jul 30, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso Cycle Problem
The FL error code means:
Flood Condition:
FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
This problem I see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
There is a check "valve" in the drain assembly that seems to sometimes cause problems with the FL error code. You can remove this piece, and might avoid changing the pump.
Calypso Service manual: https://docs.google.com/leaf?id=0B5If-wTgYWH5MTQ0OGIxZTAtZjQyMy00MzEzLWJkMzYtZTdmOTY2OTk3YTA4&hl=en
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question#%!^
Mar 23, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool calypso model GVW9959K-0 leaking during rinse cycle
hi my name is joyce
Sounds like your pump is leaking. if it is leaking when you are on a spin cycle.
now if it is stuck on f1 cycle and wont drain unplug and let stay unpluged for 60 seconds and replug and see if you can restart on drain and spin cycle. let me know if I can help with any other problems.
thanks
joyce
Feb 06, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool calypso top load washer getting FL error message
fl,,flood condiction,,the pump is trying to get out the water,,replace or try and un block pump..onthejob
Jan 08, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
FL code
fl is a flood condition,make sure you are using he soap with this machine.press stop/cancel to see if it clears. if not check pump and drains If you take any hoses off you will have a flood.
Nov 03, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Problem with washer
You probably have a bad control pc board
Jun 01, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
249 people viewed this question
Dan Webster
Dan Webster
Sal De
