Question about Whirlpool ET8CHEXSQ Dryer
Water doesn't drain properly after a complete
Water accumulate at the basin after a run of complete cycle. What seems to be the problem?
  • 5,911 Answers
You posted this question under a DRYER category, but it sounds like you are describing a WASHER problem. The model number, however, crosses to a REFRIGERATOR. Can you please verify your model number and/or whether or not this a washer, dryer or refrigerator?
If this is a Whirlpool front loader washing machine, the problem you are describing is usually attributed to either a leaking water inlet valve, or a pressure switch malfunction. The following link explains how to diagnose and repair each problem yourself:
http://www.fixya.com/support/r3753262-front_load_washer_fills_when_not_in_use
I've included steps on how to replace any defective parts and parts resources if you need to order anything. If you have any questions, please post back and let me know. I hope this helps you.
Posted on May 12, 2010
My whirlpool duet washer front loader wont wring out the clothese properly. We have replace the drain pump and cleared all the hoses and filters. It also doesn't seem to go in to real fast spin.
First, make sure your machine is not overloaded. Overloading will not allow the machine to spin out properly. Also, make sure its fairly level. Next, make sure that all the shocks on the drum are properly attached and in working order (after you pull off the access panel, the shocks are readily visible -- there are typically 4 of them, 2 in front, 2 in back). Their heads slip into a slot and then twisting them locks them in. Finally, I would pull of the drain line leading from the drain filter to the tub basin. Once its off, stick your hand up into the basin. All kinds of yuck tends to collect there, semi-obstructing the drain line, which permits more water to remain in the basin, which doesn't allow your machine to spin as quickly as it otherwise would.
Feb 24, 2013 | Whirlpool GHW9100L Front Load Washer
Hansgrohe 88509000 sink drain does not close completely, water slowly drains out
This could be caused by the installation. If the installer did not use plumber's putty between the the flange and basin it will not seal with the basin. Another possible cause is if the basin is not perfectly formed it will cause the flange to oval or not seat evenly. If this is the case it may leak between the flange and the basin or the stopper may not seat all the way down and it may leak between the stopper and flange.
Oct 16, 2012 | Hansgrohe 31060821 Metris S Single-Hole...
Dishwasher not completing cycles
see this causes and fix it. God bless you
If the cycle doesn't complete, check these:Water-heating cycleTimerWater-heating cycleMany dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:On some units, the pause is timed and the unit continues after the allotted time. On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too. TimerTimers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it. 9_25_2012_6_48_09_am.jpg
Sep 24, 2012 | Dishwashers
Water is draing to the bottom catch basin in my Frigidaire Model FRT18B4A refrigerator. Under the 2 bottom drawers there is a catch basin. It takes a week to fill with water. I spounge it out before...
The source of that water is from the automatic defrost cycle in the freezer,the water is supposed to run through a drain in the freezer but that drain is blocked so the water is draining into the refrigerator vents and ultimately to the catch basin instead of draining .
This tip i wrote will help ya to clear that drain in the freezer http://www1.fixya.com/support/r9945686-check_when_refrig_cools_ok_but_leaks
GENE
Sep 16, 2011 | Frigidaire FRT18B4A Top Freezer...
All the lights stay on after a cycle completion even after I siphoned all the remaining water in the filter sump.(After opening and closing the door. ASKO model 1585)
Hello, the reason for the light flash error is the unit either didn't drain properly, overfilled somehow or has a leak which is filling the "overfill basin" ( it's designed to, that way it doesn't get to your floor...in theory ). Check your drain hose by removing it where it connect's to your home plumbing via under sink pipe or food diposer/garberator. You'll also need to remove the lower access panel, or kick plate as it is sometimes referred to, and absorb the water in the basin before it will run a cycle...or wait a few days for enough water to evaporate from the basin ( shut off the power/breaker before doing so ) then look for evidence of a leak. Check at the fill valve, (to the left) the drain pump, (slightly to the left-center) as well as the circulation pump & hoses, ( it is much more difficult to see...directly behind the big gray main sump assembly). That should get you moving forward. The Asko can be a challenge to work on if you've never worked on one. That is why I usually suggest calling a pro, preferably an authorized Asko servicer. It may save many unessasary part's being changed as I see too often with these. Hope that help's, good luck. macmarkus :)
Feb 28, 2010 | Asko 24 in. 1585 Built-in Dishwasher
Water is collecting at the bottom. Where is it
Refrigerators have a defrost water drain that carries water produced during the defrost cycle to the bottom of the refrigerator where it flows into a catch pan. The water is then evaporated by heat from the compressor and refrigerant coils.
Something is likely blocked in your drain system. There is usually a catch basin in the rear of the refrigerator behind the inside lining. From that catch basin, water flows into tubes which usually run down the back of the refrigerator. The drain in the catch basin may be stopped up, or the tube itself could be blocked.
Oct 15, 2009 | Refrigerators
Dishwasher not draining properly. How much water
Its likely to be one of the following
a) a partially blocked drainhose
b/ the solenoid on the drain valve not opening closing probably
c) a blocked drain valve with a piece of bone or debris
This article should help you:
Dishwasher Basics The main parts of a dishwasher are: Control mechanism
The control mechanism is located inside the door behind the control panel. Many units use a simple electro-mechanical system: a timer determines how long each part of the cycle lasts and activates the proper function at the proper time (such as the detergent dispenser, wash spray and draining functions). Units that are more expensive might have a computerized control system. Modern units also have a door latch that must be closed for the unit to run. Some also have child safety locks. Intake valve
This is where water from the home's water supply enters the dishwasher. The unit's pump doesn't pump the water into the basin – when the intake valve opens, water pressure drives the water into the unit. Pump
An electric motor powers the pump. During the pump cycle, the pump forces water up into the spray arms. During the drain cycle, the pump directs the water into the drain hose. The motor-pump assembly is mounted beneath the basin, in the center of the dishwasher. There are two main types of pump:
  • Reversible
    These pumps switch between pumping water to the spray arms and pumping water to the drain by reversing the direction of the motor. Reversible pumps are usually vertically mounted. dishwasher-11.jpg
    -->Reversible pump
  • Direct-drive
    The motor runs in one direction, so the direction of flow is switched from spray arms to drain by a solenoid that opens and closes the appropriate valves or switches one hose connection to another. Non-reversible pumps are usually horizontally mounted. dishwasher-12.jpg
    -->Direct-drive pump
Dishwashers can be installed in either a portable or a permanent configuration. Portable units have finished sides and top that can be used as a countertop. When not in use, the machine sits in place next to the wall. When it's time to run a cycle, the unit can be rolled on casters over to the sink, where it connects to the faucet and plugs into a nearby outlet. In a permanent installation, the dishwasher goes underneath the existing countertop and bolts into place. Hoses underneath the kitchen sink connect directly to the hot water line and the drain line, and the unit usually plugs in under the sink as well. Both types of installation require a 120-volt grounded line.
Jun 07, 2009 | Kenmore Dishwashers
Water not pumping into dishwasher
I first checked the water valve in the dishwasher. It was working properly. The overflow or water level sensor had become stuck in the 'high level' position, thus telling the washer that it was already full of water. I corrected that and it began working properly. As for water in the bottom of the dishwasher that didn't seem to be draining completely - I turned the timer to a point in the cycle where it would drain, making sure I turned the washer off before it cycled back to the 'fill or rinse' cycle. I think the water had accumulated because of the timing of the cycles getting out of sync with the water level in the washer.
Jan 06, 2009 | Dishwashers
D/W doesn't drain all the water out when cycle complete.
most dishwasher drain problems start at the air gap on the sink.inspect,clean out.then disposer and on back from there.ive made more money in five minutes cleaning those out than any other.God bless,tom
Jan 03, 2009 | Admiral Dishwashers
Whirlpool ET8CHEXSQ Dryer Logo
55 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
