Question about Cooktops
I have a Blanco BCCR742DT1 cooktop that started a loud high pitched alarm which I stopped by pressing the power on button but now nothing goes. Any ideas on how to reset this?
Why cant I make jam on a blanco induction cooktop . The base always burns
You can never stop stirring. Jam is thick, heat is slow to travel from the bottom up on its own. If you stop stirring it burns on a gas or electric stove also.
Feb 28, 2017 | Cooktops
Kleenmaid CH600CE ceramic cooktop stopped working
U sure power is getting to cooktop ?- chances of all burners not working and/or going bad at same time is ridiculous.
Get out your VOM and start tracing the voltages back to point of inception.
Sep 17, 2016 | Cooktops
Blanco Blanco BCM6X Built-in Coffee Maker manualmanuals
My Blanco coffee machine (BCM 6 X) does not heat or froath milk
Jan 03, 2014 | Cooktops
Schott ceran touch
might be transformer noise? try turning the cooktop circuit off at the electrical main switchboard.
or get your wife to stop singing opera!!
Oct 22, 2013 | Kuppersbusch Cooktops
Manual for bcg640nx cooktop gas
Do you mean the Blanco BCG640NX cooktop? Many of the Blanco manuals are available here: http://www.blanco-australia.com/Blanco-User-Manuals.html . Scroll down for the Cook top manuals. The direct link to the BCG640NX manual is http://www.blanco-australia.com/IgnitionSuiteVirtual/uploads/docs/BCG640.pdf . (Note the same manual applies for several Blanco models.)
I hope this helps.
Jan 20, 2012 | Cooktops
Trying to set time, got stuck on wrong time, can't bake my turkey F90 displays when I press bake and a loud steady beep comes on until I press Stop. so I need 2 questions answered thanks
According to your service manual page 9 an F-90 is maximum oven door unlock time exceeded.
Here is your SERVICE MANUAL
This video shows how to check the door locking mechanism:
This shows how the electric oven high voltage portion of your oven works:
Jan 01, 2011 | Kenmore Cooktops
High-pitched squeal/whistle noise from range
Noise went away by itself. No root cause found. Please remove this posting, thanks.
Dec 04, 2009 | Maytag MGC6430 Gas Cooktop
Blanco oven wont stop clicking/trying to spark...
By running all the tops for fifteen minutes I fixed the sparking which was the result of too much moisture. Cheers
May 12, 2009 | Cooktops
Hob not working
It is child lock.
Turn cooker on, press two + at front of oven, this will then take it off for that cooking session.
To turn child lock off switch on hob, and touch - for 5 seconds.
Sep 16, 2008 | AEG 23 in. 6410KF-N Electric Cooktop
Cooktops Logo
76 people viewed this question
Top Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
