Question about Intel D102GGC2 Motherboard
I have sata dvd writer.when i connect it my computer does not boot.does intel D102ggc2 supports sata dvd writer?
    President:
  • 2,351 Answers
You're Intel motherboard does support up to 4 SATA hard disk drives including SATA CD-ROM / DVD-ROM drive, reader/writers. This MB also includes two serial ATA IDE ports.
The most likely reason you're system is not booting is because all SATA ports are all seen as Master drives. By connecting the SATA DVD-ROM drive the bios auto configured the SATA ports.
You'll need to enter the bios when you're system boots-up. Press the F2 key on you're keyboard right after hearing a single beep. You will than enter the bios main menu. Listed at the main menu are devices connect to the motherboard. (Instruction on how to move around in the bios is listed at the bottom of the screen). Mainly, the hard disk drive or (drives) and the SATA DVD writer. You'll need to open the Boot tab. Look for boot order. You want the boot order set like so;
First boot device: [Floppy disk] drive; if one is connected.
Second Boot device: [Primary Hard Disk] drive.
(The drive with windows installed on it). (This drive may be ATA IDE or SATA; you did not provide that information).
Third Boot device: [DVD-Rom] drive. Save and exit the bios. The system will auto restart.
You're windows operating system should load correctly after the auto re-start.
The SATA data cable and the SATA power cable should be checked for good connection. It only takes a little bump to make either loose.
Here is the link to Intel for you're motherboard;
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=%22+D102GGC2+%22
Mike
Posted on May 13, 2010
Intel D102GGc2 shows disk read error when detached sata dvd writer and xp boot when attached the same
Hi. if you're getting the same 'disk read error' when the DVD drive is attached and detached, then the error relates to the hard disk, that you're supposedly trying to install XP onto.
Ultimately you want the board to boot the DVD drive first. A quick change to the 'Boot priority' in the BIOS should sort it.
Apr 27, 2014 | Intel Computers & Internet
Can't get ECS PM800-M2 to boot to SATA drive.
You need to make sure that your SATA drive has an Operating system on it. It can't boot if it only has a data drive.
Feb 19, 2013 | VIA ECS PM800-M2 PM800 P4FSB 800 Supports...
I have a an INTEL Motherboard Model DH55HC. I am installing a basic Internal DVD writer (DVR-A18M) Interface ATA/ATAPi-7. I have the power cable from the POWER SUPPLY in the correct plug. I attach the...
That motherboard doesnt support ATA it supports upto 6 SATA devices which is actually better and faster. You will need to take your DVD/RW back and ask to swap for a SATA and also make sure you buy a SATA cable and good thing is these are actually cheaper and faster. Its actually a very nice motherboard dont be disappointed. Cheers from Scott and plz vote
Jan 24, 2011 | Intel DH55HC Motherboard
Sir , I have an Intel D102GGc2 Motherboard .I have connected two hard drives one Sata one Pata . And want to boot from Sata hard drive first . So my problem is that as soon as I connect both the drive...
One needs to be a master and one needs to be pegged as a slave. You can have seperate OS..Win 7 on ons and XP on the other then at post screen you can select which OS you want.
Nov 26, 2010 | Intel D102GGC2 Motherboard
PC Does not boot up with LG SATA DVD Writer
Did you try to move the small jumper next to the connector on the back of the DVD writer.
Then try to choose different places to connect your DVD on the motherboard.
Check if you have the right driver or reinstall it.
Hope its help, don't forget to rate.
Cheers
Aug 19, 2009 | ASUS K8V-MX Motherboard
Boot failure asus a7v 133 motherboard installed a pci sata raid
Hi whistler1410, you need to enter your bios menu. Press the delete key every couple of seconds to load the bios menu.
Once in the bios (See instructions located at the bottom of the menu, to help you move about).
You should see all connected drives at the main menu.
This includes the SATA writer & hard disk drives.
Go to the bios menu, BOOT.
SATA drive even DVD drives are seen by the bios as a master drive. So within the BOOT menu go to "Boot device priority".
The boot priority should read as follows.
First boot device [Floppy disk drive] (If one is connected)
Second boot device [Your SATA DVD writer]
Third boot device [Your primary hard disk drive] (The drive with windows loaded on it).
If you do not have a floppy disk drive than make the first boot device your DVD writer.
Save the bios & exit the bios. You should not receive "boot disk error message anymore".
Run into a problem, post here.
Good luck whistler1410!
Mike
Mar 25, 2009 | ASUS A7V133 Motherboard
DVD Writers can read but can not write
update their drivers: they're indicating readers, not writer devices..
Mar 25, 2017 | LG GMA-4082N DVD±RW Burner
Wont Install
Ofcourse you will need it..Get your DVD writer's brand and model...
Oct 27, 2007 | Intel DG965WH Motherboard
Intel D102GGC2 Motherboard Logo
390 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
