Question about Konica Minolta PagePro 1350W Laser Printer
Stop streaks on printed copies pagepro 1350w - Konica Minolta PagePro 1350W Laser Printer
    Brigadier General:
  • 4,090 Answers
Streaks are caused by toner on paper path rollers, clean these and it should stop. Also dont overfill the casettes with toneer ( common with refurbished)
Please rate my help++++Thanks for using FIXYA
Posted on May 12, 2010
Konica minolta pagepro 1350w not feeding full page but get stuck at half page.
check the size of the document make sure the print drivers and the printer are correct and matching you might also need to replace the fuser unit or the transfer roller and or image unit
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Feb 16, 2014 | Konica Minolta PagePro 1350W Laser Printer
Black streaks on paper
its either your heater is full of toner or your copy glass is full of dust either way you just need to clean it from the inside
Apr 27, 2012 | Konica Minolta PagePro 1350W Laser Printer
I can't get my Konica Minolta PagePro 1350W printer to print a Word document. The printer was working a couple of days ago. There is an "error" in the Control Panel window & the print window...
I take a picture using a screen capture program/app then print the picture. It also make it possible to overlay things such as the (faded) word (COPY) on top or underneath it, if you want. When I use the COPY method, I print the faded word COPY first then re-run the paper through to print the rest
Jun 05, 2017 | Konica Minolta PagePro 1350W Laser Printer
Streaks on printed page full length even after installing new cartridge
Check the glass (the one the paper rests on). The underside of the glass that is. This is what the light 'sees', so, it will print this!
Jun 03, 2009 | Konica Minolta PagePro 1350W Laser Printer
PagePro 1350W won't pick up paper
Clean the rubber roller that draws the paper in with isoproply alcohol, in future, blow dust off top sheet in paper stack before printing.
May 19, 2009 | Konica Minolta PagePro 1350W Laser Printer
i took out my drum and cleaned it with alcohol and then wiped down the inside of the printer anywhere the drum touches with a towel soaked with alcohol and the did about 40 prints and it fixed my pagepro (with each of these 40 prints the the quality got better)
May 15, 2009 | Konica Minolta PagePro 1350W Laser Printer
Pagepro 1350w prints with streaks on left side
Hello sir; Not thing you can use forever if lifetime is out you need to change otherwise the streak line not go away.
May 13, 2009 | Konica Minolta PagePro 1350W Laser Printer
Konica Minolta PagePro 1350W Laser Printer won't print anymore
Go to printer faxes check and it might change the default setting and it might default Microsoft Office Document Image Writer. When you print make sure that you are printing to a right printer you can select the printer of your choice by clicking the down arrow. If you select the right printer and it did not print I suggest that uninstall the print driver to the control panel, add or remove and install a new printer driver. make sure set as a default.
Jan 27, 2009 | Konica Minolta PagePro 1350W Laser Printer
Printer makes streaks down the side of the paper when printing
I called a local repair shop - the printer needs new components.
Thank you for the follow up.
Jan 14, 2009 | Konica Minolta PagePro 1350W Laser Printer
KONICA MINOLTA PagePro 1350W
the problem it might not be the printer. I encounter this problem before. the solution is uninstall the print driver to the control panel and re install the print driver using the cd print drive or you can download to konicaminolta web site..
Nov 21, 2007 | Konica Minolta PagePro 1350W Laser Printer
Konica Minolta PagePro 1350W Laser Printer Logo
333 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
