Question about Hitachi 51F510 51" Rear Projection HDTV-Ready Television
Auto focus doesn't work
Auto focus doesn't align. The only way to get close is to use the 117 point alignment. The 117 point alignment work well in the center of the TV but as you go to either side it wont align the red bars under the white.
  • Hitachi Master
  • 12,061 Answers
Http://www.retrevo.com/support/Hitachi-51F510-TVs-manual/id/371ci865/t/2/
http://www.scribd.com/doc/3401783/Hitachi-Service-Manual-TV-Plasma-42HDT5055-Chasis-PT3G
Above is your service manual, and above that is a user manual. This will assist you no end, this is the manual engineers use to troubleshoot and repair.
Posted on May 12, 2010
Wheel alignment-New Port Richey
#1 Wheel Alignment - Get your Car Aligned by Experts‎
Adwww.napaautopro.com/Alignment This ad is based on your current search terms. Visit Google's Why This Ad page to learn more or opt out. Call AUTOPRO for Wheel Alignment. Ranked #1 by J.D. Power · Official Web Site · 600+ Locations in Canada Goodyear Tire Center 4.1 (6) · Tire Shop 5038 US-19 · +1 727-849-7516 Closed today Website Directions George's Wholesale Tire 4.4 (10) · Tire Shop 8230 Florida 19 · +1 727-817-0905 Closed today Website Directions The Tire Choice 3.3 (12) · Auto Repair Shop 4710 Rowan Rd · +1 727-376-5493 Closed now
Two-Wheel Alignment Port Richey, FL ' George's Wholesale ...
www.georgeswholesaletire.com/.../wheel-alignment/two-wheel-alignment... Need a 2 wheel alignment? Schedule your next service with George's Wholesale Tire to keep your tires pointing correctly. We serve Port Richey, FL, New Port ...
Wheel Alignment in New Port Richey, Florida ' Tires Plus ...
local.tiresplus.com > Wheel Alignment > Florida Wheel alignment in New Port Richey, Florida from Tires Plus Total Car Care. Keep your ride running true with the help of our Smart Service technicians.
Front End Alignment in New Port Richey, Florida ' Tires Plus ...
local.tiresplus.com > Front End Alignment > Florida Front End Alignment in New Port Richey, Florida from Tires Plus Total Car Care. Travel straight and true with the help of our friendly tire advisors. Quality results ...
Wheel Alignment Hudson, FL ' Mancini Automotive
www.manciniauto.com/car-repairs/wheel-alignment.aspx Mancini Automotive provides Wheel Alignment services to Hudson, FL, New Port Richey, FL, Port Richey, FL, and other surrounding areas. Choose a service ...
Four-Wheel Alignment Hudson, FL ' Mancini Automotive
www.manciniauto.com/car.../wheel-alignment/four-wheel-alignment.asp... Schedule your next 4 wheel alignment today with Mancini Automotive. We align vehicles for Hudson, FL, New Port Richey, FL, and Port Richey, FL.
Jan 24, 2016 | Cars & Trucks
Magic focus not working colors not aligning
If Magic focus will not correct it (it is the limited auto convergence for this set) both the convergence chips which should be stk392-110 or 150 will have to be replaced, convergence is done with the original remote with set in the Decam ( tech convergence mode).
The parts are not that expensive and TVrpairparts.com sells kits with instructions for these sets by model number.
Dec 10, 2012 | Hitachi 51S500 51" Rear Projection...
Alignment off
Try to re-seat the cartridges in the printer. Open the printer cover > remove the cartridges > close the printer cover > re-brick you printer by pulling out the power supply - black box behind the printer where the power cord is plugged in, and re-plug after 10 seconds. When the printer turns on, reinsert the cartridges and close the cover. Try to print a document again to verify that the problem is fixed.
If that doesn't help, please try this approach:
  1. On your computer, go to Start menu.
  2. Go to Programs.
  3. Go to Lexmark 2600 Series folder.
  4. Select Lexmark Solution Center.
From the Maintenance tab, select Align to fix blurry edges. Your printer will then print a page and aligning your print cartridges. Try to print a document again to verify that the problem is fixed.
Dec 11, 2011 | Lexmark X7170 All-In-One InkJet Printer
Need to install a timing belt on a 2002 ford focus with a 2 liter zetec engine cant find the timing marks
No marks to align camshafts, set crankshaft at TDC, align camshaft as shown, to align, lobs on cylinder #1 have to be pointing out at 45 deg, on the other end of camshaft's will be a slot on each one insert some thing through both as shown, to hold camshaft's in place.
Aug 05, 2010 | 2002 Ford SVT Focus
Meade LX200GPS The scope does not complete the 'Auto Alignment'
Once the scope has taken a GPS fix and knows TIME, and SITE, and you do a two star alignment your alignment stars overide any automatic alignment issues.
You could turn off the GPS put in Time, Date, and Site, do a two star alignment and everything would be fine. Centering the alignment stars is the "trick". Apparently the scope also finds NORTH OK, or the alignment stars would be way off. Since you pre-level the tripod already the software can FAIL on "tilt" and you still get good gotos.
I would not worry about it, especially since your gotos seem perfectly fine.
May 28, 2010 | Meade LX200GPS Telescope
Auto focus button was pushed a few times and now our Apex TV won't focus at all.
likely a convergence failure. if you push the button over and over, sometimes it will throw the set out so far that it cannot align anymore.. the sensors need to see the lines to do the auto alignment. you probably need new convergence ICs, repair is tricky and requires soldering. estimate = 200-350 $
May 26, 2010 | Apex Digital GB4308 43" Rear Projection...
The camcorder will not autofocus when you have the zoom in the at Wide.
Are you set auto focus on position?
Sometime focus motor faulty or need to alignment it require a qualifier Tech to change and alignment with computer and light box, special jig and software from the manufactory
Cheers
Dec 05, 2008 | Cameras
Out of focus
Most times when the stk's are shorted the 5 amp cp fuse on the power supply opens. Check all of the cp's by the stk's and on the power supply.
Feb 26, 2008 | Sony KP-51WS510 51" Rear Projection...
Canon 350d problem
The only thing I could think of is theat the contqacts on the camera body are out of alignment or damaged through putting the alternative lens on. I ant see the camera so cannot say for sure You must eyeball it your self to see or get onto Canon It will cost of course -lots
Sep 13, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Hitachi 51F510 51" Rear Projection HDTV-Ready Television Logo
184 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
