Question about Cell Phones
Lost Memory Sandisk 6Gb. to 67 Mb.
I formatted a 6Gb Micro SD card in my LG Viewty Phone, now it's only giving me a volume of 867 mb. I checked the card in my PC through XP Disk Management and it shows that a partition has been created. It says online is 5.68 Gb. with 867 Mb. healty and 4.68 Gb. unallocated. How do I get the whole 6 Gb. to work again, do I have to delete the partition and how?
  • chickenpox Mar 28, 2008
    Unfortunately, I did try! Still after formatting it for at least 20 times the result stayed the same, 867 Mb. out of the 6Gb is recognized. The disk space is there, because I can see it in Windows Disk Management, but it shows the missing memory is "unallocated" (4.68 Gb. of it). The big question is, how do you "allocate" the unrecognized or missing memory since physically it's there? It just not being read or used or allocated!!!
  • 46 Answers
Use the pc to completely format the card, that will or should delete a partition too. format it like you would a floppy disk
Posted on Mar 28, 2008
SOURCE:
I have 4gb micro sd card whin i format it show me 3.69 gb
1 GB = 1024 MB (mega bytes)
1 MB =1024 KB (kilobytes)
1 KB = 1024 bytes
1 GB = 1024*1024*1024 bytes
1 GB = 1073741824 bytes
But manufacturers count 1GB as 1000000000 bytes, so it's normal that a sd card which advertise being 4GB is in reality 3.7GB (4000000000 / 1024 / 1024 / 1024 = 3.72 GB).
Jul 13, 2012 | SanDisk Electronics - Others
4gb card showing 30.1 mb unable to format
my sd card is of 2gb but its size is showing only 45.6 mb
please give me solution on [email protected] or on 9560709358
Nov 10, 2011 | SanDisk 4GB microSD High Capacity Memory...
Will 256mb micro card work in a diffrent phone once used in anoth
Depends on the phone but yes your pics will be there but depends on the card and the way it was formatted if the phone will reconise the card, but in general yes they will be available on the other phone.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jun 26, 2009 | SanDisk 4GB microSD High Capacity Memory...
Cannot copy anything to Memory card in LG Viewty
reformat your card through your pc. don't go for quick format. if it doesn't works after that also then get a software 4 low level formatting. if then also it doesn't works ask me again.
kindly rate my solution.
Jun 25, 2009 | LG KU990 Viewty
Micro sd 512 mb memory card isn't working right
remove ur memory card and format it with help of pc . then reinsert it in your phone and formar it again it will definitely work
May 20, 2009 | LG Lotus Cell Phone
Z3 will not accept a 2g card
The Dimage Z3 accept SD cards up to 1GB (Minolta says 512 Mb, and sold it with 16Mb). This camera is 4MP , and uses less memory on card, therefore a 512MB card will be enough for it.
SanDisk Flash memory card - 512 MB SD Memory ...
from $13 - 20 stores
PNY Flash memory card - 512 MB SD Memory Card ...
from $3 - 2 stores
SanDisk SD Industrial Flash memory card - 512 ... from $14
Here 1 Gb, try at your risk, but they normally work:
1GB micro SD memory card for Konica Minolta ...
£6.90 - www.mobile-laden.co.uk
1GB Flash Memory Upgrade Card for Konica ... £3.44 - Memory Express
Here review: Steves Digicams - Minolta DiMAGE Z3 -
Mar 31, 2009 | Konica Minolta DiMAGE Z3 Digital Camera
No sd card found in the phone
Have you tried using another memory card, or maybe using that same memory card on another phone and see if it works, because it could be either one othe them that could be malfuncioning, hopfully it is the memory card and not your phone.
But just in case if you find out it was the phone, try to reset settings to reset it back to factory settings and hopefully that will help, also check if the memory card slot is clean..Good luck
Dec 11, 2008 | LG KU990 Viewty
Need to reformat micro-sd card in up stage phone
max memory card the KU990 can handle upto 2Gb
Jul 21, 2008 | LG KU990 Viewty
Cell Phones Logo
162 people viewed this question
Top Cell Phones Experts
Ekse
Marvin
Marvin
Are you a Cell Phone Expert? Answer questions, earn points and help others
