Question about Mitsubishi WD-62525 62" Rear Projection HDTV
Light indicater keeps coming on light wont stop. mitsubisi brand
Light indicater keeps coming on light wont stop.cant tune on the tv. tryed unpluging the tv for 4 hours sometime half the day.sometimes it will shut off and can watch for 4 to 5 days sometimes 3 if lucky. again it did it again.
    Scholar:
  • 70 Answers
Have you had the bulb replaced in the unit yet? There is a timer in the unit that is set to a specific number of hours. If that is not reset when the lamp is changed you may still have this problem. The issue could also be unrelated to the lamp but in the power supply itself. I think you would be best advised to contact a repair shop about the unit.
Posted on May 12, 2010
Ive just bought a 22 inch lg tv, tuned in ok but remote is now not working, wont do anything, wont even put tv in standby mode. Any ideas?
unplug tv, take batteries out of remote. plug tv back in, replace batteries. best idea i have. sometimes that resets the devices. good luck
Mar 05, 2015 | LG 22LV2500 22" Inch 720p Widescreen LED...
The tv keeps turning its self off the red light comes on then we unplug for a while and it comes back on for a while
Not knowing the brand or model (not indicated here) the set is trying to make it from standby (part of the power supply that runs 7/24 if set is plugged to power) to On and having no success.
You have this posted as a projection set but there are hundreds of different brands or models.
Dec 06, 2012 | Televison & Video
LNT5265F when first turned on new, small red light came on, played a little tune, then picture came on. About 7 months ago, after the tune played the picture didn't come on, the red light would go...
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board...
If the capacitors is faulty your TV turn on after a lot of attempt until the TV is totally turn on...
In that case you need to replace the bad capacitors on the power supply..
How can you find where is the faulty capacitors? The bad capacitors is usually leak/bulged on top in that case you easily find it through visual check...
Sep 10, 2011 | Samsung Televison & Video
Mitsubisi wt-46809 will not turn on. i plug it in and it blinks 3 times then nothing. no error code when i hold menu and input
keep in mind if you unplug set it clears the error buffer.
Try to turn set on and if power light comes on and goes off then do the self check; menu and input for at least 5 seconds and release both buttons.
UNPLUG TV ANDTHEN PLUG BACK IN---TURNON---GREEN POWER LIGHT COMES ON FOR A MOMENT ANDGOES OFF.
PRESS AND HOLD "device" and "menu"buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protectthe Convergence IC or IC's is blown---set will detect no voltage to convergenceIC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES ANDTHEN TO GET IT TO REPEAT MORE YOUHAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and twoblinks--this is the most common and easiest to fix.
Before you rate this information let me know what you find.
SD TECH
Jul 20, 2011 | Mitsubishi WT-46809 46" Rear Projection...
Tv wont come on and a red light is blinking. I have a Sony Wide screen projection TV model kp-46wt520
Can you unplug the TV for about 15 seconds, and then plug back in and watch the stand-by light. Tell me how many time the stand-by light blinks in regular intervals. If it doesn't blink at all, you need to change a fuse on the g-board. Once this is done run back through the stand-by blink light process, and more troubleshooting can be done if problem isn't already solved. If the stand-by light just keeps blinking with a count over ten just tell me, and I'll look for other possibilities.
Oct 25, 2009 | Sony KP-46WT520 46" Rear Projection...
The tv only talk in Chinese characters! i am trying to tune in my TV in a new houe, an the language setting (on screen TV menu etc) has changed to Chinese. As i cannot read chinese, i cant follow any...
Try unplugging the tv for the night, or a day, it should reset the settings to defaults, if the settings are still in chinese, look for a reset button on your tv. there maybe a memory battery inside the tv that keeps the settings in memory. But its unlikely, so unplugging for a night or a day should get rid of the issue and it should go back into English, unless the tv was made and purchased in china or japan where the language would be the default, original setting..
Aug 03, 2009 | Televison & Video
My 32v434t television.
The TV was making the clicking noise and not turning on because an internal error was being detected.
Now things had got worse , and something had blown inside the TV.
The burning smell and high pitched noise is coming either from Flyback transformer or PSU board. Repair is a delicate matter and must be done by a technician.
Jul 05, 2009 | RCA TruFlat 27F520T 27" TV
Channel keeps changing
It sounds like a stuck button or switch. What happens when you hit the channel DOWN, does it still keep scrolling down?
Is this with or without the remote?
Have you tried it with the remote and or the TV?
Let me know whether you are changing the channels with the remote or the buttons on the tv and I can try to give you a couple more suggestions.
Mac =)
Feb 12, 2008 | Televison & Video
RCA Model 32V434T Ch. #ATC010A will no come on. You can hear a click when it is turned and the red indicater light blinks. If you push the menu button after awhile the red light will stay on and not blink....
Model 32V434T Ch. #ATC010A will no come on. You can hear a click when it is turned and the red indicater light blinks. Eventually the red indicator light stays red. Tried unpluging set. Is it the EPROM ?
Jan 19, 2008 | Televison & Video
TV keeps on trying to auto tune
I would try first unplugging the set for about 30 seconds to see if that clears up the problem. If not, then it could be anything from a bad connection or component inside the set, and with it being made by a 4 letter word company, pitch it and get a different brand set. Check out epinions.com before plunking down the money on another model first. May save some headaches later.
Dec 19, 2006 | Sony FD Trinitron KV-28FQ75 28" TV
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
115 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
