Question about Akai CFTD2083 20 in. TV/VCR/DVD Combo
Akai model ws-p28ntf-sf-d-gb (s) tv/dvd combo
The tv just went off last night and this morning tried switchin it on and the green power light just very slightly flickers but no tv comes on, you can very slightly here some clicking noise like its trying to turn on,but it doesnt. Eventually the power light just goes off and thats it . The TV just wont turn on. The light in front turns green when the power button is hit but it turns back red and no picture is displayed. How do I turn my TV back on?
    Genius:
  • 3,422 Answers
HI,
You will need a technician to fix this bcecause the power supply is the problem area. set has gone into protection mode. The clicking sound is the protection relay (could be a reed relay which produces very little sound) resetting and looking for power.
It may not be the board, however. It could be something as simple as the rectifier bridge shorted down or a couple of bad/gassy electrolytic caps (that may or may not be mounted on the board).
FEW TROUBLESHOOTING STEPS YOU CAN TRY:
ONE: Check the line cord. Wiggle both ends near the molded part.
TWO: Make sure you have power in the outlet by plugging a lamp into the same exact outlet.
THREE: Do a hard reset; merely unplug the line cord but leave it unplugged for 4 hours before powering up again.
FOUR: If still now power, listen for the clicking of a relay inside the set. If you hear the clicking sound you might hear two clicks; once when the power is first turned on and the second a fraction of a second afterwards. This is the protection circuit switching the set OFF to protect it from further damage. The protection circuit activates whenever there is a internal short in the set.
The whacking test is to just bang or smack the set with your hand on the back, side, top, etc., to see if there are loose connections or cold solder joints inside that are acting up. If so, the banging should knock them back to normal and the set should restore. You might have to use some creative banging and some have had to put a book or magazine under one corner to torque the chassis enough to get it to work reliably.
If this does not solve your problem then the problem then as i told you in the begining you will need a technician to fix this.
Goodluck,
Please don't forget to rate the solution.
Posted on Mar 28, 2008
  • Akai Master
  • 19,396 Answers
Disconnect it from power cable 30 mins, see if this reset works, for the rest sounds like you have a problem with the power unit.
We have a rear projection Mitsubishi TV, Model # WS-55511.We had a power outage last night and when the power came on this morning, we cannot get the TV 'ON'.There is however the TIMER light on the...
Thats a very common problem caused by weak caps on the DM board when power is lost they drain and then cannot recharge when the power is restored the WS55511 DM repair kit from www.tvrepairworld.com will usually solve that issue. The kit contains the caps and the cd with instructions.
Sep 09, 2011 | Mitsubishi WS-55511 55" Rear Projection...
Power Loss
You will find 4 swollen capacitors in the DM module of value 1000uF 16volt. Replace them.
Aug 31, 2009 | Mitsubishi WS-55711 55" Rear Projection...
AKAI 27in lcd/dvd combo
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi
You have power supply problem. Please go to ebay and buy cheaper price:
AKAI LCT2721AD MLT166A REFURBISHED IN CHAINA
Thanks
GEORGE
Jan 27, 2009 | Akai LCT3201TD 32 in. LCD Television
Tv won't come on. It has a flashing green light on by the power button.
the tv is not come on.it has a flashing green light on.tv model hd 1080.
Oct 19, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Last night the electric went off now my tv will not come back on all its doing it flashing a green light. my tv is a mitubishi big screen medallion model ws 55615
how many times is the led flashing or is it a continuous blink that doesnt stop? Pleaserespond to this same post and I will try to assist you with the problem.
Sep 07, 2008 | Televison & Video
I believe you either have a problem with your Power Supply inside your TV from a defective component in the circuit or you have a problem with the Picture Tube on your TV. I don't recommend you working on TV's by yourself unless you know what you're doing since you can get badly shocked. You need to discharge the Picture Tube on the TV before you work down any further. If you don't know what you're doing then you should get someone that knows what they're doing to work on your TV.
Jan 20, 2008 | Akai CFTD2083 20 in. TV/VCR/DVD Combo
Ws65813
Check threads for DM repair or ctechnicians.com
Jan 04, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Akai CFTD2083 20 in. TV/VCR/DVD Combo Logo
105 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
