Question about E-Machines 17" Widescreen Flat Panel LCD Monitor
I connected the monitor to a compaq hardrive
The screen keeps turning off and on and the anolog sign pops up too something about the resolution i try to confugure it but my computer resolution does not have the resolution it asks for
  • 560 Answers
Go to E machines web site and download the drivers . Your computer just doesn't have the drivers to run the monitor.
Posted on May 12, 2010
Change input timing for monitor when i can't do anything
Hi Austin
it sounds as though you have a problem with your graphics card drivers and your tv will not accept the lower resolution. Do you have another screen that you can connect to prove/disprove my theory? If your tv will not accept the lower resolution input then you need another screen to enable you to sort it out. Hope this is helpful.
Feb 19, 2013 | Computers & Internet
I have a compaq presario computer using a compaq monitor. I have a Gateway HX2000 LCD flat screen monitor (year 2009) that I want to us instead of my compaq monitor. I have disconnected the compaq monitor...
I'm guessing the different monitors are different sizes? The only thing a driver for a monitor will do will tell the computer the max resolution that the monitor will be able to go up to. However most 90% of monitors can use the built in windows driver without issues. Your best bet is going to be to change the resolution on the monitor. To do this you can either hook up the old monitor, lower the resolution, and then plug in the other monitor. Or you can boot the computer into VGA low resolution mode by pressing F8 as the computer starts up and selecting that option. From there you can lower the resolution, and then put it at something more desirable with the new monitor.
The other possibility being your Gateway monitor is actually malfunctioning and you just happened to hook up a bad monitor.
Mar 27, 2011 | Computers & Internet
Can I restore native resolution on my Compaq without a manual?
HA! ya'll should check this out!...
1. First, ignore any advice that you should disable any monitor driver that was supporting a second monitor. Keep your monitor driver(s) enabled, even though it means multiple monitor mode remains "on".
2. As long as multiple monitors is "on", your advanced settings dialog will have more available settings than otherwise (through Properties>Display>Settings tab> Advanced button). So instead of 4 tabs (in one row), you should see 12 tabs in two rows!!
3. Select the Displays tab and click on Panel. Un-check (a blue radio button) "Scale image to panel size".
4. Then select the Adapter tab. Click the button "List All Modes". The list will now include ratios: 640x480, 600x800, 1024x768, 1152x864, 1280x768, 1280x1024, 1600x1200, 1680x1050, 1920x1080, 1920x1200, 1920x1440, and 2048x1536.
Ta DA!!
Jul 21, 2010 | HP Compaq nc8230 Notebook
VS 11354. I keep getting a screen pop up that
yes it can be. What windows do you use so i an tell you how? Please give me good rating
Apr 17, 2010 | ViewSonic VG1930WM LCD Monitor
No signal anolg
good day,
maybe there's a problem with your VGA or the cable wire that connects the monitor and VGA....try to approach technician near to you.....
best regards,
kaybicks
Feb 22, 2010 | ViewSonic VA721 17" LCD Monitor
Out of frequency set resolution or see monitor
If you are getting a splash screen (COMPAQ) then video goes black, you can try this. Boot system in Enable VGA mode from the F8 menu and see if you get to the desktop. If you do, you can then go to display properties and adjust the resolution to the Optimal for the monitor.
If you do not get a splash screen, check you cable connections and ensure the Video cable is properly seated and no bent pins. If issue is occurring after the system was moved, also ensure that the correct video adapter connection is being used on the tower, as there may be 2
Oct 04, 2009 | Compaq 7500 17" CRT Monitor
Out of frequency range set lower resolution
reboot the system by pressing F8 if your using windows OS and select last good configuration.
you can try also selecting Enable VGA mode (press F8 while rebooting and select ENABLE VGA mode).
hope this helps, please rate.
Feb 06, 2009 | Compaq Computers & Internet
Screen keeps blinking showing a anolog sign in the bottom right corner
Perhaps you are using the Blue plug (VGA) instead of the White one (HDMI)?
Chris
Water Ionizers
Nov 28, 2008 | ViewSonic VX710 17" Flat Panel LCD Monitor
Resolution notifier v71lcd
go into the on screen menu, select the tools menu and you can turn the resolution notifier off.
Aug 12, 2007 | NEC-Mitsubishi Nec Display Solutions...
E-Machines 17" Widescreen Flat Panel LCD Monitor Logo
79 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
