Question about Huffy 20 In. Girls Celebration Single Speed Bike
Terrible instructions for installing caliper brakes
I just purchased a 20 inch Huffy girls bike with front & rear caliper brakes and the instructions are ridiculous. I'm sure once you've done it it's very simple but they don't have illustrations that show you the necessary steps. I've never set up caliper brakes before. can't seem to find out how to get more cable to pull through into the brake lever.
  • 21 Answers
The cable has a stop on it that threads thru the lever housing. It also usually has an external threaded nut for adjustment. You need to start the adjustment process by screwing the "nut" all the way against the housing. Then you move to the "caliper" itself. The cable is held in place by a compression nut. Pinch the caliper with your hand until it is almost touching the rim and then tighten the pinch bolt. You can then fine tune the adjustment by using the nut next to the lever housing. As you screw that nut out the brake pads will move in towards the rim and vice versa...hope this helps!
Posted on May 14, 2010
Where to find brake cables for a huffy bike with serial number 24513 ?
The serial number has nothing to do with the type of brake cable your bike uses. In most cases they are the standard brake cables with the dot end. A way to see what is needed is to take a cable off the brake handle. There are 2 major kinds. A barrel end and a dot end. Some packages come with both ends on a cable, just cut the end you don't need off and install the new cable. These are a bit more than the single end cable. A single end cable can be purchased at any bike shop, on the internet, at ebay for instance. Even Walmart is carrying them now. I would take your old cable into the local bike shop, the clerk or service person can assist you in finding the right cable
Sep 03, 2014 | Huffy 24-Inch 15-Speed Girls Granite Bike...
Missing front rim where can I order new one?
go to your local bike shop, they can get you a 20" wheel that is much better quality than what was originally spec'd on the bike for about $30. Huffy doesn't sell OEM replacement parts for their bikes.
May 07, 2014 | Huffy So Sweet Girls 20-Inch Bike
Girls skeleanimal bike brake is stuck so back wheel won't move
It's a Huffy. 'Nuff said.
Manuals here - http://www.huffy.com/Support/OwnersManuals.aspx
If the cable isn't passing freely inside the cable housing it won't relax brake pressure when the lever is released.
http://www.parktool.com/blog/repair-help/linear-pull-brake-service-v-brake-type
Jun 19, 2011 | Schwinn 20 Inch Girls Starlet Bike
Brake system. how to install the brake system for huffy disney princess 16
The link below will take you through the brake assembly and how to use the brakes on a huffy princess bike. Go to page 30 and page 31. A diagram shows how the brake arm should be secured.
http://www.huffy.com/pdf/ownersmanuals/e0664c94-726b-49d6-8322-5e053dca5b0a.pdf
For more information on bicycles, bike safety or bicycle accessories, visit my website: Huffy Bikes
Dec 25, 2010 | Huffy Disney Princess 16 in. Girls Bicycle
THE WRONG MANUAL CAME WITH THE SO SWEET BIKE. I NEED TO KNOW HOW THE HANDLEBARS AND SEAT IS INSTALLED.
go to my tips and tricks page. There is a link to Huffy to get a new manual for the right bike.
Dec 21, 2010 | Huffy So Sweet Girls 20-Inch Bike
How do i attach hand break on huffy 16 inch princess bike
Huffy's general manual addresses only how to adjust brakes that have already been assembled (under the heading on page 20 it states "Adjustments". I noticed this problem and it took me a while to realize the single sheet of paper that came with the bike (not part of original manual), that acts as an addendum. It's called "Brake Cable to Brake Lever Assembly Instructions." Why this section hasn't been incorporated into the manual is beyond me.
Jun 08, 2010 | Huffy Disney Princess 16 in. Girls Bicycle
How to assemble back tire barrens and other parts pic of how inside parts go 20 inch huffy
I'm guessing this bike has a rear coaster brake. I really don't suggest overhauling a coaster brake hub and it is unlikely a diagram for your huffy exist but here is a link to a general coaster brake hub diagram. It should be very similar to what you are working on.
http://www.wtlw.net/ff/suntour/
Hope this helps!
Jul 18, 2009 | Huffy So Sweet Girls 20-Inch Bike
Brake assembly help!!!!!!!!!
1. the other end of the brake cable with the stopper,insert to the handle brakes.there is a guided slot for it.
2.go to the brake assembly.loosen the nut and find the small hole at the shaft of the flat head bolt.insert the cable.
3. adjust the brake.pull the cable until it is in the best tension,slowly rotate the brake nut to keep the cable in place.
4. try to grip the brakes and try pushing the bike while testing the tires if it skid.try to ride it to so that your weight will be calculated with the brakes.
5. adjust the brakes by repeating the above instruction until desired brake adjustment is achieved.
May 31, 2009 | Huffy So Sweet Girls 20-Inch Bike
How to assemble the front tire to hannah montana 20 in. bike
hi,
When you try to put the wheel in, is it getting caught on the brake, if it is, the brake caliper unhooks from the cable
Are the forks bent, you can tell because if one of the fork legs line up with one side but not the other then the chance are that the forks have been bent somehow.
Dec 25, 2008 | Disney Hannah Montana 20-Inch Girls...
Huffy 20 In. Girls Celebration Single Speed Bike Logo
189 people viewed this question
Top Huffy Cycling Experts
 Mikey
Mikey
Are you a Huffy Cycling Expert? Answer questions, earn points and help others
