Question about Dryers
My electric fan is not rotating? what is the problem on it?
    Problem Solver:
  • 10 Answers
Check your connections first look for some loose wiring or check if the plug is properly fitted or inserted into the outlet. If it doesnt solve the problem you may try to check if the fan is stock by spinning its shaft..put some oil into the bushing... If the fan is still not working the problem could be an open circuit on the magnetic wire probably due to overuse /overheating but if it has an overload protection you can try to twist its wire together and the problem is solved or maybe just replace it with a new overload protector.. or if worst u will have to replace or have a service for the rewind its motor.
Posted on May 12, 2010
My electric LG dryer's drum is no longer rotating,
more than likely the motor fan jammed by a sock (or something of that size) that made it around the lint filter; sucked down into the fan. probably not a belt.
May 29, 2011 | LG DLE5977 Electric Dryer
Flame does not flicke in my electric fireplace
if flame not flickering and you can see the globes lighting flame its the fan that moves the ribbons is faulty unless it has fuse to it which may have blown, but how the flame works is by globes lighting through ribbons that are moved by a fan to give a flicker effect unless its rotating glass wheel like some, that turn with the globes behind that give you a flickering effect its always better with electrical to have an electrician look if it was the globes yes that is an easy replace but to change a fan or rotating glass wheels
Nov 28, 2010 | ACE Dimplex (r) Compact Electric Fireplace...
My canon clc 1150 is continously showing e 804 ?
• The operation of a fan (indicated
by detail code) is faulty.
• The CPU PCB is faulty.
• The DC driver PCB is faulty.
0001 The electrical unit fan (FM8)
has stopped to rotate in error.
0002 The IP cooling fan (FM7) has
0003 The exhaust fan (FM2) has
0004 The ozone suction fan (FM5)
0005 The toner suction fan (FM6)
0006 The laser scanner motor
cooling fan (FM4) has
0008 The primary charging
assembly fan (FM3) has
Aug 02, 2010 | Canon CLC 1150 Color Copier
1999 jeep grand cherokee laredo is engine fan belt driven or electric?
The radiator cooling fan used on the 4.0L engine is
an hybrid fan design. The hybrid fan system consist
of a low speed viscous driven mechanical fan and a
electrical fan.
The hydraulic fan used on vehicles equipped the 4.7L engine, replaces both the electric fan and the engine driven mechanical fan. The hydraulic cooling fan is integral to the fan shroud and is located between the radiator and the engine. The power steering pump supplies the hydraulic fluid and pressure to rotate the cooling fan blade, while the electrical part of the fan is controlled by the JTEC. The hydraulic fan drive (motor) consists of the three major components:
- Steering flow control valve
- Fan control valve
- Two stage G-rotor hydraulic drive
The hydraulic fan and drive is not serviceable.
Therefore any failure of the fan blade, hydraulic fan
drive or fan shroud requires replacement of the fan
module because the fan blade and hydraulic fan drive
are matched and balanced as a system and servicing
either separately would disrupt this balance.
Oct 29, 2009 | 1999 Jeep Grand Cherokee
1st two speeds not working
If the fans rotate on high, then they can rotate on low. So it's either the remote or the receiver that's not succeeding in adjusting the speed. You might try changing the dip switch settings to a different combination and see if that helps. Otherwise, my first guess is that it's the receiver since it has the "brains" of the unit. Also, with electronics it sometimes helps to completely remove all sources of electricity for a minute in order to reset everything. That would mean turning off the circuit that powers the fan for a minute then flipping it back on.
Apr 27, 2009 | Minka Aire F602-BNCH Gyro? Fan
Ceiling fan some time not rotating
First note that there are often two switches: one on the wall of the room with the fan and one on the fan itself. If that doesn't solve the problem, there may be an electrical problem and the fan may need service (it could even need lubrication if it is stuck from a long period of non-use). Also note that electrical problems can cause fires, so it may be necessary to get the fan fixed by a competent service person. Hampton Bay is a pretty good brand but nothing lasts forever and most of us tend to use fans for months and months without servicing them.
Apr 13, 2009 | Hampton Bay 46056 Callaway II Ceiling Fan
Intertherm model P853A5 older style AC unit fan will not start to rotate when thermostat control set to cool.I have a feeling that it might be the electric motor. I removed the screen and rotated the fan...
This is most likley the capacitor. Be very careful when changing it out!!!!! Make sure to use an insulated device to discharge it first before touching it!!!!!!! To discharge it place insulated device across the two spade connectors on top.
Aug 26, 2008 | Intertherm Heating & Cooling
42" ceiling fan
1. Try to rotate it by free hand and see it is free machanically. If not, it ball-bearing/bush should require lubrication or replacement.(Note at this satage there should be no electric supply to fan.)
2.If it is free, rotate it fast by hand, then immediately switch it on.
a)If it continue to rotate, then there is fault in capacitor.Replace it.
b)If not, ask me.
Nov 25, 2007 | Quorum Ceiling Fan - 138880
Dryers Logo
1,132 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
