Question about Hannspree HannsG HG281DP 28" LCD Monitor
Monitor flickers and sometimes spontaneously turns ''off''
I am having the same problem as djpyro_lyric and the issue is very difficult to search due to its lengthy descriptive nature. I have ''snow'' in the form of white dots, forming vertical lines, about an inch apart. I also get the ''blotchy'' flickering effect with colorful rectangles and squares. Sometimes the monitor just goes ''off'' (black completely, no inverter glow, yet the blue indicator light is still on as if it is receiving signal properly).
SOURCE:
SOURCE: monitor won't stay on
Hey. This problem is caused by the Backlight bulb(s) blowing up.
This is fixable. You have to get into the monitor and remove the LCD screen to see what bulb you need. This is a moderately difficult job and fragile parts will easily get broken.
However by all means have a go but this is the problem that you guys have been experiencing
Gareth162
Posted on Sep 02, 2008
SOURCE: Hannspree HF229H monitor and Windows XP. Images stretch to fit.
I had this same issue.
Go into the monitors menu, go down to "Image Settings", go to "HDMI Mode", select "PC Mode"
Hope this fixes it for you. It worked for me.
Posted on Apr 28, 2009
  • 3278 Answers
SOURCE: My Hanns-G hw191d monitor quit coming on. The
First, flip the switch for your power surge protector, to see if that resolves. Then, test the monitor on another computer and see if it works. If the monitor still doesn't work, look for another one. Hope that helps.
Posted on Jul 06, 2009
Nakl
  • 54 Answers
SOURCE: Hanns G HW191D flickering. Monitor works fine but
Go into your monitor properties and change the refresh rate to a lower setting.
Posted on Jan 14, 2010
  • 80 Answers
SOURCE: The monitor goes black while on
Open it up and look at the capacitors. The round "tin can" looking components. If the tops appear bulged, then replacing them may help. Check out the YouTube video... and web site...
http://www.youtube.com/watch?v=9Q6_TgNJvQw
Good Luck!
Posted on May 15, 2010
I am looking for the words to a gospel song titled Purple Robe.
here it is
Purple Robe lyrics chords ' The Stanley Brothers
www.classic-country-song-lyrics.com/purplerobelyricschords.html
  1. Cached
  2. Similar
Purple Robe lyrics and chords are intended for your personal use only, it's an excellent country gospel recorded by The Stanley Brothers. This old song isn't difficult to learn to play, the chords are simple. ... The man who wore the scarlet purple robe.
Purple Robe Google Search
Nov 28, 2016 | Audio Players & Recorders
Picture flickering and faded on left had side of the screen
if rebooting the monitor would do no good, try to get a spare monitor cable if the same flickering issue took effect. If it is so, then call your pc provider to repair your monitor..
Nov 26, 2011 | Philips 47 in. LCD HDTV
Monitor is flickering
Welcome to Fixya Support,
I am happy to assist you.
Monitor Flickering May due to following Reason
1. Deffective LOT
2. Deffictive Filter IC or Deffective horizontal IC
To fix this issue,you have to check LOT, if LOT working fine, you have to search for burn out capacitor along with filter IC and replace with new one. After this your monitor must work properly, without any flickering.
Thank you for using Fixya Support. If any problem leave a comment or feedback we will deffinately help you.
Have a Nice Day!
Best Regards
Fixya Expert
Chandrashekhar.
Dec 06, 2010 | LG 700M 17" CRT Monitor
LG Flatron W2234S 22 purple tint problem
your LCD monitor has bad ccfl lamps or inverter circut..
May 08, 2010 | LG 22" FLATRON LCD Monitor
Samsung monitor flickers on digital but not analog
1. this may be due to cable select and or cable not being secure at connection point
2.check your instruction manual for proper setup for digital signal to the LCD monitor and the to your video source.
Mar 27, 2010 | Samsung SyncMaster 204B 20.1" LCD Monitor
My Hanns.g monitor 1080P HDM1 has a power problem, when it's turned on either by the power switch or when it's activated by the keyboard, it flashes on & off several times & then goes off, playing...
nfleurat, If nothing wrong with the "on"/"off" switch, then must be the "switch-mode-power-supply"/"CCFL inverter supply" circuit card inside of unit. Look for a possible "thermally intermittant solder connection" and then resolder it. Also, inspect unit for possible "swollen" electrolytic filter capacitors on power supply board. Read more of my responses to other owners in my FIXYA profiles for more options you can use to solve your LCD display problem. 12fixlouie aka louie12fix Good luck on the repair.
Jan 05, 2010 | Hanns.G Corporation Computers & Internet
MONITORS TURNS BLANK OCCASIONALLY AND THEN COMES SPONTANEOUSLY BACK TO NORMAL. ONCE THE IMAGES STARTED FLICKERING. I HAVE THE IIMPRESSION THAT THE MONITOR NEEDS TO "REST".. THE TURNING BLANK HAPPENS...
it seems to be the power management
right clik on desktop click properties
click on screen saver tab
and from there click on power
ther you can adjust monitor stanby mode
Jul 24, 2009 | Computers & Internet
Os-winxp
I had that same problem with my 17 inches LCD monitor. The problem why it
does that is due to the video card having trouble to catch up with the LCD
monitor. I set the mhz on the video card to 75 hertz and the problem went
away. set your LCD monitor at 1280 x 1024 and you won't see the flickering.
Sometimes, It is the video card that is causing the problem or interference from
magnetic waves in the house.
Thanks for using Fixya.
May 28, 2009 | Princeton Digital VL1916 19" LCD Monitor
Monitor flickers and image is reduced and squeezed
Heat related dry solder issue Horizontal output side.
Apr 02, 2007 | HP Compaq FS7600 17" CRT Monitor
Open Questions:
Hannspree HannsG HG281DP 28" LCD Monitor Logo
269 people viewed this question
Top Hannspree Computers & Internet Experts
 Mike M
Mike M
Steve Allison
Steve Allison
DBurstiner
Are you a Hannspree Computer and Internet Expert? Answer questions, earn points and help others
