Question about Whirlpool 5' Jacuzzi Tub Bathtub Cetra 532 H525-969
Jacuzzi doesn't work...no voltage to outlet, checked braker box, reset it..still not working...any ideas?
  • 349 Answers
Maybe a GFCI outlet that it's pluged into may be tripped . check any other GFCI outlets through your house and make sure none are tripped.
Some tubs have access doors with GFCI outlets near motor at tub may be tripped.
Posted on May 12, 2010
Testimonial: "thank you so much..it was only a GFC that tripped...sometimes you can't see the forest for the trees...easy fix.. thanks again!!!"
Need to know where the reset button is on Kohler jacuzzi tub
The only place I'd expect to find a reset button is on the motor itself. That is, unless it's a ground fault problem, in which case it might be on another ground fault outlet somewhere in the house (possibly a bathroom or garage outlet) OR on the breaker - check the breaker box to see if the breaker's tripped or the GFE button needs to be reset.
Aug 02, 2017 | Jacuzzi Home
After replacing my PC board in the hot tub it does not work
A couple of things could of happened here;
1. Most common issue I see is customers do not reset the brakers right. A GFCI braker, when tripped, must be switch all the way to the off position then back to on. When a GFCI braker is tripped it looks to already be in the off position.
2. Check your system fuse. You can check for continuity or if you check the voltage, putting a lead on each side of the fuse while it's installed, it should read 0 voltage if it is good. If it reads 120vt replace it. You can get them at home depot or lowes for less than $20.00
3. You shorted out the circuit board using a magnetic tip screw driver. It happens.
4. You bought a rebuild board from e-bay. In this case if the seller quits responding contact paypal.
Aug 11, 2013 | Pool & Spa
Just put in this nautilus dishwasher which worked fine in the other house is not working now. Where is the manual restart?
check wiring is the plug in working is check gp outlets are they all reset,check brakers is the cord ok ,were the cord goes to dish washer is it secured?
Aug 29, 2010 | GE Nautilus 24" Built-in Dishwasher
After lightening strike, Aqualink control panel reads 6700 rev c. All lights on, none work. Outside, power center won't work. No lights. Reset doesn't work. Battery good, fuse appears good. Any ideas?
ok check all the braker even the one for the house .turn them off all and back on if this do not fix check for 220 v if voltage is present the board is bad need replacement get the number from the back to check for prices
Sep 05, 2009 | Jandy AQUALINK RS TELELINK KIT
2001 Hyundai elantra. Headlights, electric
check for any circuit brakers near the fuse box, if theres any of them reset them by introducing a paperclip in the small hole and press, you will hear a click.
Jul 20, 2009 | 2001 Hyundai Elantra
"Jacuzzi j-400 series" hot tub- F1 code flashes on control panel
Your circulation pump isn't working you should see the flow awitch closing if you have the visible model and hear the pump running.. If its the smaller circulation pump model it needs replacing
May 18, 2009 | Jacuzzi Bath Nova H530 917 Black Soaking...
Built in Convection Microwave Oven KBHS109SSS
no reset buton persay but fuses and control boards. MICROWAVES emit and store HIGH VOLTAGE nad should only be access and repaired by trained proffessionals. NO JOKE HIGH VOLTAGE. like your DEAD VOLTAGE
Nov 20, 2008 | KitchenAid Architect Series KEMC308KSS...
Will not start
All jaccuzzis must have a GFI breaker or outlet where it plugs in. Find either and reset
Oct 04, 2008 | Jacuzzi Amiga Whirlpool JAC-N888...
Whirlpool 5' Jacuzzi  Tub Bathtub Cetra 532 H525-969 Logo
525 people viewed this question
Top Whirlpool Home Experts
Craig Butler
Craig Butler
john h
Mike
Are you a Whirlpool Home Expert? Answer questions, earn points and help others
