50h71 how can i enter in convergence service mode i changed de eeprom on it now i do have to enter in service
  • joaorocha73 May 15, 2010
    realy good help thank you
  • joaorocha73 Jun 03, 2010
    i have a cf-35d50 toshiba have a vertical problem.there is about one inch of picture and in seconds the piture opens slowly and works fine i put new vertical ic all caps aroud and new video prossessor resolder all and still the same.please help
    Top Expert:
  • 14,553 Answers
I will post instructions here on how to enter but would like to know the reason you replaced the eeprom?
With a new one you are going to have to adjust geometry and a complete alignment will take hours.
Here are instructions
With the set on press MUTE on the remote.
Then press and HOLD mute for several seconds and while still holding it on the remote press Menu on the front of the set.
A (S) should appear in the upper right corner of the screen. (It means you are in the Service mode)
Press menu again on the front of the set
7 on the remote will call up the convergence grid
3 on the remote will change the color to adjust from red to green to blue(do not adjust GREEN)
You navigate the grid with 2, 4, 6, and 8 buttons.
To stop the cursor from blinking so you can adjust at any point use the 5 button—to move again use the 5 button.
Once the cursor stops blinking you use the 2, 4, 6 and 8 buttons to adjust. 2 should adjust upwards, 8 down, 4 to the left and 6 to the right.
When you finish you exit by hitting 7 on the remote again.
Sometimes you have to try a few times to get into the menu—I have had my problems but once in it is easy.:
Posted on May 12, 2010
  • 4 more comments
  • joaorocha73 May 12, 2010
    this tv came with the 2 stks bad and 2 resistors 1,8 bad then the butom left corner is full of lines and curb i change the convergenge eeprom on the digital convergence board and it is fine but the convergence adjust on the menu it is not 100%
  • SD Tech
    SD Tech May 12, 2010
    Have you already tried with the instructions I posted gone into the technical menu and tried to adjust convergence there?
    Note the instructions were posted when I answered this problem--if you cannot see them let me know and I will post them again.
    SD TECH
    i again ok. my problem now is the front panel it is locket and i dont now the passeword what can i do?
    i cant use the menu at the front of the tv because it is locked ande is asking for 4 digit passeword and idont now
  • SD Tech
    SD Tech May 13, 2010
    You may have to contact Toshiba----each of these sets has a way to enter a specific number which will release the lockout but it is different on different models and I do not know the code for this set.
    This seems to be a different issue than what we started with--hopefully the problem did not happen because you pressed a wrong button while in the tech menu.
    SD TECH
  • joaorocha73 May 13, 2010
    no the owner cant rebember the pass. i did lock the panel because of the children
How to reset eeprom(service menu settings)
This is the reason I am careful about walking people into the tech menu on sets--one wrong move and poof!
If you by a miracle find the full service manual it would have the information needed (if set has this) for a hard reset---other wise you would have to try to with the manual reset every setting to factory one at a time...........
Apr 10, 2012 | Samsung HCP4252W 42" Rear Projection...
I have a 52" rca hdtv. the screen looks like its in 3d. can this be fixed? model# hd52w67
It seem like a convergence trouble. I tink it is a ITC222 chassis in this set. If it is, you probleme is eeprom for convergence need to be reprogrammed and cause no power on convergence board.
Apr 22, 2010 | RCA R52WM24 52" HDTV Projection Television
Double image in 2 colors one color red ofset above and at about 30 degree angle
The convergence needs to be repaired. The 50H71 convergence kit works in your model as well. You can get the kit at the following link which contains the parts and instructions.
http://servicemanuals.vstore.ca/product_info.php/pName/toshiba-50h71--50h81-convergence-repair-kit/cName/convergence-repair-kits
Jul 11, 2009 | Toshiba 43HX71 43" Rear Projection...
Getting 2 images on top of each other on Toshiba 50H71
How To Enter Service Menu is what you need to know and replace both of your STKs these ic chips control convergence.If they are STK392-110s use STK392-180s better ics.
Dec 18, 2008 | Toshiba 50H71 50" Rear Projection...
42H83 Convergence
Yes the convergence ICs need to be replaced, however so dont the six 1.8 ohm 1watt resistors as Toshiba recomends replacing those six resistors when the ICs are changed. You can get the 50H71 / 50H82 Convergence repair kit as the 42H83 is identical to the 50H71 series, so the kit will work for your model. Heres the link where you can get the kit.
Aug 10, 2008 | Toshiba 42H83 42" Rear Projection...
ICS Convergence
Did you also check to make sure both pico fuse are good ?
Jun 09, 2008 | Toshiba 50H71 50" Rear Projection...
Toshiba 50H71
you need to replace both the convergence ICs they are STK392-110 you can get new replacement ICs at the following link and they will provide free instalation instructions with pictures so you can do the repair yourself. Heres the link.
May 29, 2008 | Toshiba 50H71 50" Rear Projection...
Toshiba 50h71 red light after fixing the convergence chips
Did you check to be certain none of the resistors were burned or open that power the ICs ? This is fairly common for one or two of the convergenvce resistors to be open when the ICs go out. Also double check the iC pins to insure that none of the pins are bridged with solder. If you need more assistance please let me know.
May 19, 2008 | Toshiba 50H71 50" Rear Projection...
Toshiba 50H71 50 in. Rear... Problem
set most likely has bad convergence ics J.D.W.
Mar 26, 2008 | Toshiba 50H71 50" Rear Projection...
Service mode for convergence
You enter the service menu by using the remote. Press DISPLAY, 5, VOL+, POWER in rapid succession. Once the screen appears, you should notice green letters and numbers at the top of the screen. Your remote acts as a navigation tool to allow you to select and change values. Keys 1 and 4 change the Item, keys 2 and 5 change the Category, and keys 3 and 6 change the Value. MUTE enters the write function, and ENTER executes it. Power exits the service menu. Keep in mind that while in the convergence mode, the keys have different functions, which we'll get to in due time. The service manual will also have this information.
http://tv.groups.yahoo.com/group/Ws500/
Feb 16, 2008 | Sony KP-51HW40 51" Rear Projection...
 Grubhead
Grubhead
