Question about Jet 3 Ultra Power Chair
Jet 3 power chair will not run. We put in new batteries and still nothing. The light on the control arm comes on, but just keeps flashing. It is about 5 years old.
  • kmb582 May 16, 2010
    Very helpful but we are still working on the problem. Thanks!
  • 560 Answers
Hi. Please click here to see the manual. Please refer to page 2 to see flashes codes, probable cause and possible solution.
Charging your battery for 10hours straight may also help.
Let me know if you need further assistance. Thank you for using Fixya support.
Posted on May 12, 2010
    Thank you for your help. Here is the email my brother sent to me.
    "I saw the codes, but they don't apply to him, he has a continuous blinking light.
    It said to check the fuse, the connections, and the actual battery terminals."
    We are both in a different town from where the chair is and haven't had a chance to go there to check it out further. Thanks again for your help!
Shoprider power chair won't move and 8 Battery LED Lights are flashing
Code 8: Controller problem. Also, check to see if your gearbox levers are engaged - if you can roll the chair by hand the gearbox is not engaging the motors.
Mar 20, 2013 | Pride Mobility Products New Pride Mobility...
When I turn on controller power the speed lights flash slowly. Joystick does nothing and chair is dead. Chair is Pride Jet 3 Ultra.
Do all of the speed lights flash at the same time or do they ripple from left to right? If they ripple from left to right the chair is in lock mode and you can use the unlock procedures from my tips to unlock. If they are all flashing at the same time you have an internal joystick problem and the joystick needs to be replaced Hope this helps
Apr 27, 2011 | Pride Mobility Products New Pride Mobility...
Jet 3 flashes "code 7".
The VSI joystick controller of the Jet 3 with a flash code of 7 LEDs flashing on the battery condition display indicates a possible joystick fault.
The most likely problem is with the joystick gimble. You can also get a 7 bar flash if the joystick is out of the neutral position at start-up.
Run the joystick in a circle and back and forth feeling for any sticky or broken/dead spots. Check to see if the spring and gimble come back to center when you release it. Turn off the VSI and try centering the joystick. Turn the VSI back on and see if you can get the fault to clear.
The only recourse is to have the unit rebuilt or replaced . A rebuilt VSI will run about $500 and a new one about $1600. For this reason it is best to check with your insurance before performing the work to see if its a covered item. Hope this helps
Nov 30, 2010 | Jet 3 Ultra Power Chair
WHIN TURNING ON BOTH LIGHTS START FLASHING AND WILL NOT DO ANYTHING IS THERE A WAY TO RE SET WHITH CONTROLS . WE PUT NEW BATTERIES IN DID NOOT HELP.
The chair might be in lockout mode. Check the owners manual to see if they tell you how to get it out of lockout. Hope this helps
Aug 21, 2010 | Jet 3 Ultra Power Chair
Jet 3 power chair power lights just flash, no sequence of flashes
hold joystick back, press on button, move joystick forward, then let go.
Feb 17, 2010 | Jet 3 Ultra Power Chair
With a full charge chair stops working and won"t power up
I have a Jiffy Jet3 . the problem is when I charge the batteries
the light indicator just blinks but chair doesnt run.
I just put new batteries and still doesnt run,,,thanks J.J.F.
Feb 12, 2010 | Jet 3 Ultra Power Chair
The chair suddenly lost power and now the lights flash continuously. The chair won't take a charge. A repairman tried fixing it at a local shop and said he put a new battery in and it sizzled. Now he is...
If he put in the batteries (2) properly, they should never sizzle. Some will emit a very minute spark when the final connection is made, but that is normal. There are fuses coming off of each battery to the power controller that will blow at 40 to 100 amps or so, depending on the chair; these will blow before the chair frying, or the circuit breaker will trip, or the controller will fry and all will be quiet on the chair, so I am going to say that the batteries weren't properly hooked up, otherwise on of the above items would have shut everything down. Continuous flashes indicate trying to start the chair while it is still on the charger, or with the joystick off-center. Make sure it is unplugged and notohing is resting against the joystick. If it's still a no-go, then you have either a joystick issue or controller issue. You will need to test those by replacing with known good controller/joystick, which a dealer should be able to do for you. Good luck.
Jul 17, 2009 | Jet 3 Ultra Power Chair
Lights just flash on controller and wont move jet 3 wheel chair
Do they flash in series? Like ten flashes then a pause then ten flashes?
Mar 27, 2009 | Pride Mobility Products New Pride Mobility...
Jet 3 Ultra Power Chair Logo
85 people viewed this question
Top Jet Health & Beauty Experts
Colin Taylor
wcdoc1953
wcdoc1953
MobilityRepairSpecia...
Level 1 Expert
Are you a Jet Health and Beauty Expert? Answer questions, earn points and help others
