Question about HP Compaq nc6000 Notebook
Battery Problem? I have a compaq nc6000 laptap that is about 4 years old.It's plugged into a wall outlet most of the time because the charge is only good for about 15 minutes.Now I'm having trouble turning the laptap on and when I am able to start it,it freezes when I pick it up or move it around .I assume that a new battery will fix this problem?
    Genius:
  • 1,019 Answers
HI,
Compaqs rely on a decent battery.
You could try removing the battery and see if it boots at all.
If it does,nt this will answer your question.
Suggest e-bay for a replacement, the chinese sellers offer great items for replacement, usually cheaper than U/K sellers. shipped and received within 10-14 Days.
Regards mike @ compurepair.
Posted on Mar 28, 2008
SOURCE:
Htc droid incredible 2 won't charge
FOr changing the charging port you have to take it to an authorized service center. it could be a software issue also.
Dec 08, 2017 | HTC Droid Incredible 2
I have a durabrand portable dvd player and I can not get the battery to recharge. I have unplugged it from the DC in jack and the cord from the wall. Reinserted the battery, then inserted the AC adaptor...
If your portable DVD player work with the AC power adapter in the wall outlet.100% the litium battery doesn't take any more holding charges.The litium battery should last u about 2 years with minium usages 2-3 hours a day.But that the DVD player and the litium battery must keep in very well conditon and wheather wise.Not in the heat or cold and the humitnity well shorten the lituim battey life very quickly and also could damages the portable DVD player too dosen't matter how much u used it.Tries webites like Amazon.com,Partstore.com,Ebay.com to buy a new litium battery or a compatible one.
Aug 25, 2011 | Durabrand PDV-709
My lg laptap battery is problem create so pl reply me
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Dec 06, 2010 | LG Computers & Internet
My compaq nc6000 did not start up. The proplem happen when I shut down for 4 days. anyone help!
Leaving a computer switched off for any length of time shouldn't matter. I have had laptops that have not been powered up for 5 years and they power up without a problem once the battery has charged and the BIOS backup cell is replaced.
I would suggest that if you were to press F8 when it is booting up, just at the point when the BIOS menu closes and choose Safe Mode,. Get it to boot from there and it may recover itself. If it doesn't do the same action but choose Recover as an option and follow the prompts.
I hope that helps.
Nov 28, 2010 | Compaq NC6000 C Notebook
How do I charge my scooter I have lost my instructions
Look in your manual if you lost it then, go to razor.com and request one. But the simple answer is to:
1. Turn off the scooter
2. Plug charger into wall outlet.
3. Find the hole on the side that matches the charger plug(not the wall outlet plug) .
4. Plug the charger into the scooter.
5. Wait until the charger turn off ( if the charger is a smart charger), typical charging time is 4-6hours.
*If not a smart charger you can calculate the charge time by using an online battery charging time calculator.
Jul 02, 2010 | Razor E100 Electric Scooter
I charge the MP3 player and it still shows "low battery" message.
There is a trick to charging the battery in these small mp3 players. It won't charge if it is turned on, and it won't charges if it's turned off. Here's what to do...
1. plug the player into your USB port. or wall charger
2. switch the player on using the mechanical switch (on the side)
3. turn it off by either holding down the play button, or selecting "System" from the menu
4. The screen will go black and the battery will begin charging.
That is if the battery is still chargeable after all this time. The battery may well require replacing.
Apr 19, 2010 | Creative Labs ZEN V Plus MP3 Player
Hi,My HP Compaq nc6000 just developed a problem of not coming on. I have checked the battery and its okay. I have blown its internal parts and it remained off. It only indicates the orange light for some...
try taking the battery out completely and see if the laptop runs of the main power from the outlet, if so then the battery may have a bad cell in it and would need to be replaced.
Primary Batteries
6-cell Lithium-Ion (4.4Ah) – standard
8-cell Lithium-Ion (4.4Ah) – optional
Power SupplyExternal 65 watt AC adapter
from looks of it the battery has gone bad
http://www.laptopbatterystore.com/product/2151/compaq-business-notebook-nc6000-batteries?utm_source=GoogleProducts&utm_medium=CSE&utm_campaign=Compaq/HP&utm_term=HP18S6-Compaq-Business-Notebook-NC6000-Battery
Aug 20, 2009 | HP Compaq nc6000 Notebook
Recently got a new battery for the nc6000. charged up and had no problems. then i was downloading some software to allow me to read mpeg3 files; i was converting a file and it was taking forever so I left...
Pull the batery out and unplug the power as well. Let it sit for a few minutes, re-connect and see if it works then. If not, try to borrow another compatible power supply and see if that works. If not, then you probably have a bad motherboard You can also try running on the power brick with the battery removed just to make sure it's not battery related,
Don't forget to check the power cord to the brick from the wall and to also make sure you are plugged into an outlet in the wall that works. I'm embarassed to admit that I've wasted time on both of these in the past.
Jul 06, 2009 | HP Compaq ProLiant ML370 G3 Server
Laptap problem
hi there,
The problem here was the battery becoming partly dislodged - even though the machine is running from the mains when in the office it can still happen. All to do is to remove and reinsert the battery - problem cured. Only happens every so often but can be annoying.
Feb 11, 2009 | HP Compaq nc6000 Notebook
HP Compaq nc6000 Notebook Logo
136 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
