Question about Sierra Designs Omega Tent - 2 Person, 4 Season 07
Elastic cords have streched in my tent poles.
The elastic cords have streched in my tent poles and I want to be able take the tips off and cut the cords. How do I do that without totally trashing my poles?
  • 10,319 Answers
Use a cutoff wheel to remove the tips if made of plastic or metal It sounds like the cords are attached to the tips from the inside I assume. If so use JB Weld for a secure grip which will work forever if the cord is a good one
Posted on May 12, 2010
How do I set up my 2 room Campmate tent?
Lay it out flat. Steak all of the corners down. Firm but not to tight. put your shock rods together and string them through the loops made for them on the top the tent and secure them at the corners, probably a pin on the corners that need to be inserted in the shock rod pole bottom. Once you have them all up then you can put up the rain fly. Use the shock rods to do this and place the canopy over the top and secure the elastic cords to the corners and you are done.
May 11, 2016 | Sport & Outdoor - Others
HOW CAN I REPLACE THE ELASTIC CORDS,ON MY SHOOTING STICKS?
Rafael, I am not aware of any camera repair station that will do this...., but as these tripods use the same type of bungee materials as tent poles..., I would contact a company in your area that does repairs on backpacking tents. I suspect that they can probably fix this for you.
Oct 04, 2014 | Stoney Point STON F2B33R1X FLDNG BIPOD...
I have a ten year old tent hardly used that has somehow now minus its tent pools can i get replacement ? how ? and How much
Sporting goods stores normally carry generic replacement poles- you want to find pole of the same diameter. These can carefully be cut to size by securing the cord between the first & second pole, cutting the knot at the end of the pole, then sawing off the end of the first pole that does not have the metal coupling. This is easier if you wrap masking tape around the pole at the cut location to help prevent the fiberglass from splitting. Put the cord back through the first pole, tie a couple of figure 8 knots, and you are good to go.
Nov 25, 2013 | Sport & Outdoor - Others
I need assembly instruction for 8 person cabin dome tent with screen house
Clean the ground of any rocks, logs or big sticks. Open the stuff sack and pull out all of the contents. Pull the poles out of their pole bag and set them aside. Remove the tent stakes and set them next to the tent.
  • 2 Lay out the tent poles and assemble them. Push the rod blanks together to make the tent poles that will support the mesh tent body.
  • 3 Unroll the mesh tent over the cleared ground. Take care not to step on or walk on the mesh panels. Avoid sticks and snags, as the mesh rips easier than nylon tent fabric.
  • 4 Clip the Timbertop tent pole clips to the poles. There are no tent pole sleeves because Timbertop uses external pole clips for its mesh tents. Criss-cross the tent poles and push the tent pole tips into the metal holes at the end of the pole clip lines. The mesh tent will now be standing upright.
  • 5 Place one tent stake into the ground and through a pole strap stake hole. Pull the tent out as you insert the stake to keep the mesh panels tight. Stake down each pole strap around the perimeter of the tent. Unzip the doors to enter the tent. Zip up the doors quickly after entry to keep bugs and insects out of the tent.
  • Oct 23, 2011 | Coleman 10' X 10' Sundome Tent 9160K101
    No instructions giving to erect our tent 6 man regatta hyperdome model no 927/5887
    I bought one of these yeaterday. The instructions - for what they are worth are sewn inside the carry bag. So I decided to put it up today. Not as easy as i would have thought, but then this is my first tent of this size. ( saw a nice Outwell Montana 4 in Millets for 225.00 which would have been my tent of choice). But at half price in Argos I couldn't argue that one.
    So to put it up.....
    lay out the fly sheet in the approximate final position. put poles in as per instructions ..blue to back red to middle and blue to front.. across the tent. ( the pole guides are all colour coded.) Make sure poles are in pins at the base of fly sheet (bending gently to attach). these are attached by the black elastic straps.put in porch pole, put in front to back poles left and right.
    Anchor back of tent temporarily with pegs. Lift from porch forward to lift tent. Temporarily peg base of poles, straighten out so that the straps inside tent are approximately perpendicular to each other. Move poles to tension flysheet and tighten anchor points on flysheet using straps buckles to pull flysheet down as far as possible ( to help prevent draughts)., anchor guy lines when happy with final position.
    Put up inside ground sheet and attach to points on inside of flysheet. put up rooms starting with the rear yellow hook and work around to front red hook.
    These instructions were not specifically provided but this was our first try and probably could be improved on. It requires 2 people for speed if nothing else.
    Enjoy
    Jul 31, 2011 | Sport & Outdoor - Others
    Hello. I have a disney princess bed tent that my daughter recieved for christmas. We went to go and set it up and the instructions are missing. Is it possible to get a copy faxed/emailed to me?
    I just put one of these up today with no instructions so I am going to share my experience. In my Disney bed tent there were two long sets of poles held together by an elastic string. 1) put these two sets of poles together. Now you should have two long poles. 2) Turn the three way brackets all the same direction on both long poles. 3) Lay out the tent and look in each corner of the tent for a little pocket to insert the end of a long pole...taking the other end insert into pocket, not diagonally, straight across the long way. 4) Do the same with the other side of the tent and long pole. 5) Now take your ten short poles and attach two together making 5 medium sized poles 6) Push these into the brackets along the long pole, kind of has a ladder effect. You are done!! I use mine with a full size blow up bed, the elastic gets stretched but I can set it up easily outside, or in the livingroom. Enjoy Nancy
    May 19, 2010 | Toys
    I have a Ryan's Room tent, and some of the plastic pieces that make the frame of the camping-style tent broke. How can I get a replacement part?
    We had the same issue. Here's my solution.
    Each tent pole is composed of 49.5 inches of half inch pvc pipe cut into three 16.5 inch pieces. This can be purchased at any hardware store. You can cut it into three pieces like the original and string an elastic line through it or just keep a piece of 49.5 inch pipe in storage to use when needed.
    G Barth -- gb4cities@comcast.net
    Mar 16, 2010 | Small World Home Sweet Home By Ryan's Room
    The elastic cord of the tube poles of the rainfly of my camping tent broke. The ends have a hard rubber or plastic cover that seems to be permanently attached. How can I remove them so I can replace the...
    Those stretchy tent poles are at walmart, real cheap, Buy a couple and you will have a spare. If you want to fix the old one, I would try a couple solvents to loosen the glue, then remove the tip. Goo gone, or one of those to start, then move up to the mineral spirits, then the laquer thinner, If that doesn't do it, Nothing this side of fire will do it. Laq thinner is the strongest solvent available. Be carefull.
    Feb 15, 2010 | Coleman Sport & Outdoor - Others
    I need a complete set of poles for my timberline 4 tent, how much do they cost?
    Not sure how much they cost. If the elastic is gone, you can replace elastic line and this should be a cheaper alternative, if the poles are broken, then you'll probably need to replace all.
    Nov 10, 2009 | Eureka Timberline 4 A Frame Tent
    I have a greatland tent item #15710. This is a two room tent (not dome) with a screened porch. The poles have numbers and some numbers are blue and some red. I cannot identify whether the numbers go in...
    I am looking for a manual for Greatland Outdoors 2 room tent with screen porch item #15710, however, I guessed how the poles go together. I set up the tent by myself, but I recommend 2 people or more, especially if it is windy.
    Start by stretching out the bottom of the tent into a square, and stake all of the perimeter tentloops to the ground, starting with the corners, with the stakes directed at a 30 to 45 degree angle under the tent, so the tent cannot easily pull them back out. Leave the yellow cords attached to the tentloops loose, so you can use the cords to help pull up the stakes when you take down the tent.
    Now assemble the poles going through the loops across the front of the screen porch. Insert one end of a pole #1 into a pole #2 and thread them through the loops over the entrance to the screen porch. Put the long end of a curved pole #3 through the loops starting from one side, and attach to either side of the 1/#2 you made. Put the long end of another #3 through the loops starting from the other side and attach to the loose end of the #1/#2. You should tie the loose green cords on each corner of the sceen porch to the silver metal rings at the curved end of each #3.
    Later, you will do the exact same assembly with a #3 on each side of a #1/#2 for the poles going across the back of the tent and the poles going through the pocket across the middle/top of the tent.
    Now insert the small end of pole #4 into the curved end of a #3, then insert the small end of a #5 into the open end of the #4. There should be a rubber foot on the bottom of the #5 pole. Do the same thing for the other side of the porch. With help, you should be able to prop up the front of the sceen porch, pulling aganst the stakes holding the rear floor of the tent, and place the rubber feet of the #5 poles close to the center loops of the floor on each side.
    Now prepare the #1/#2 poles for the rear, and attach a #3 to each side and tie the loose green cords to the silver rings on the short ends of the #3s. Prepare a #4/#5 pole the same as the front, and prop up the back of the tent, putting the feet near the side loops of the floor which are about 1/3 from the rear of the tent.
    Make another #1/#2/#3, and push it through the pocket across the middle of the tent, and connect the last #3 from the other side. The side supports for the middle are pole #8 with the white clamp on the bottom, and pole #7 slid into pole #8 (The #7 was scraped off both of mine). Leave the #7 mostly inserted into the #8 until after the center is lifted up. The #6 goes on top of #7, and insert the #6 into the curved end of the #3 poles which are already in the center pocket, and tie the loose green cords to the silver rings at the short end on each of the #3s. Now lift up the center with someone helping on the other side, and put the feet of the #8 into or near the yellow loops at the center of each side. Loosen the white clamps and extend the #7 poles until the peak of the tent is at proper height.
    Move the feet of the #5 poles closer to the tent, until all is tight, and you should be done!
    Jul 21, 2009 | Sport & Outdoor - Others
    Sierra Designs Omega Tent - 2 Person, 4 Season 07 Logo
    32 people viewed this question
    Top Sierra Designs Sport & Outdoor - Others Experts
    Are you a Sierra Designs Sport and Outdoor - Other Expert? Answer questions, earn points and help others
