Question about Ricoh Aficio CL3500N Laser Printer
Vertical lines printing on one side of the page
When printing vertical lines appear on right side of page
  • 1,110 Answers
9 times out of 10 this is coming from one of the two drum (photoconductor) units. Just open the right side door, release the waste toner box, and remove the 2 drum units. The larger one is the color drum unit and the smaller one is the black. Look down thru the slot in the top of the unit (3 slots in the color drum) and look at the green colored drum surface. On one end or the other you should be able to see the same lines on the drum surface that you are seeing on the paper. One of the 2 drum units should have the lines and that will tell you which one will need to be replaced. Hopefully it will be the black drum unit as they are relatively cheap. The color ones are $350 to $400
Good Luck and Thank You for using Fixya.
Posted on May 12, 2010
  • Edwin Martens
    Edwin Martens May 13, 2010
    Did you intend to give him 4 thunbs up and me none?
    Brigadier General:
  • 4,090 Answers
Tr4y cleaning the rollers in the paper path. they are contaminated with toner powder.
Please rate my help++++Thanks for using FIXYA
Testimonial: "great suggestions--thanks"
There are streaks on the side of the printed page
Are the Streak lines vertical or horizontal ? Most likely it could be due to Toner issue, Try to remove the toner and clean it and re-install it
Regards,
Suhail
May 15, 2012 | Ricoh Aficio SP C820DN Laser Printer
Thick black vertical line appears on the right hand side of the page
PLACE A PLAIN PIECE OF WHITE PAPER IN MACHINE AND TAKE A COPY. IF NO LINES ARE ON IT THEN THE LINES ARE COMING FROM THE MACHINE THAT IS SENDING TO YOU BUT IF U DO HAVE THE LINES THEN PRINT HEAD IS PROBABLY FAULTY OR DIRTY.
Sep 13, 2010 | Brother FAX-1020e Plain Paper Thermal...
I have a Samsung 1710 laser printer. It prints the text fine but there is a 1/64 (aproximately)wide vertical line of broken printing on the right side of each page. Also, the paper does not appear to be...
Sounds like the printer cartridge is bad. The first thing I would try is replacing that and then see where you are. The broken line on the right side is likely due to a worn imaging drum coating, common with Samsung.
Feb 05, 2010 | Samsung ML 1710 Laser Printer
Vertical lines printed on right side of every page
Would be helpful to know the brand and model of the printer. Sometimes this is caused by not returning the slide used to clean the primary corona wire to its original position (usually to the extreme left side of the toner cartridge) after cleaning the corona wire. If you haven't cleaned the corona wire, you should follow instructions and do that first.
Jul 22, 2009 | Dell 3000cn Color Laser Printer
HP Laserjet 3330 printed dark page especially around the middle
Does this happen both when copying and printing?
For printing solution, try another toner cartridge.
If lines continue to appear when copying (primarily through the automatic feeder) then lift the auto feeder, and clean the glass -mainly the narrow piece on the left side.
please rate solution :)
Apr 07, 2009 | HP LaserJet 3330 All-In-One Printer
A series (10) vertical lines on print outs
See Charge roller my be dirty or Catriges PCU Units
Jan 22, 2009 | Ricoh CL3000E Laser Printer
Black vertical lines on printed pages
check the "photoconductor unit" (pg 37 in the Maintance manual)
ours was doing it with the magenta and saw a faint 'scratch' on the roller. will attempt to replace and report back if this fixes it.
Apr 09, 2008 | Ricoh CL4000DN Laser Printer
Vertical line down right hand side
crop toy jpg or bmp file from that side and then try I faced smae type of problem that process helped me you also try.
Mar 18, 2008 | HP LaserJet 1012 Printer
Print Problem - vertical lines
If the problem only occurs when using the document feeder, the problem is not usually caused by the drum. When using the document feeder, try to notice where the scanner (the light assembly under your scan glass)stops just before the paper is being fed. Some multifunction machines have a small piece of glass that is separate from the large scan glass and the scanner assembly stays parked underneith it as the original is being fed over it. Most likely there is something on the glass where the scanner parks as originals are being fed thru the feeder. When putting your original on the large scan glass to copy, the mark on the glass will only show as a spot, but will show as a vertical line thru the whole copy when using the feeder.
Feb 23, 2007 | Brother MFC-7820N Laser Printer
Ricoh Aficio CL3500N Laser Printer Logo
1,027 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
