Question about Clarke Power Products Inc AC2001 2HP 4 Gallon Pancake Tank Compressor
Don't know how to adjust differential pressure on air compresor
The compresor has a kedu qks12 regulator. I would like the regulator to come on at 100 psi instead of 80.
    Scholar:
  • 169 Answers
Most of the cheaper compressors use a switch that is not adjustable.
Posted on May 12, 2010
Can I get 80 psi with dials set at 40 psi
this compressor should be able to fill your tires to 80 psi. Look for a pressure switch and adjust it so the motor shuts off at a higher pressure. Do not exceed 100 psi.
Sep 08, 2014 | Air Tools & Compressors
Regulator outlet pressure too high ondd55146 type2
The pressure switch needs it's cut off pressure adjusted.
Feb 23, 2013 | Air Tools & Compressors
Compresor will not hold pressure
Some are push down to lock so you need to lightly pull up on the knob before trying to turn it. If the regulator itself is bad the correct one is part #AB-9051116 and is less then $10. Any Bostitch or DeWalt (the companies merged) can get this part for you. Here is a link to the parts diagram. It is item 108 and is called a pressure reducer.
Bostitch CAP2060P diagram
Aug 19, 2012 | Stanley Bostitch 2hp 6gal Air Compressor...
1990 subaru legacy wagon fuel injectors are not getting fuel to start it
Check the pressure to the fuel rail then check it at the line before the fuel pressure regulator, it should be between 55 and 80 psi at the rail and 100 psi before the regulator, if you don't have pressure before the regulator then you have a fuel pump issue, if the rail pressure is low then you may need to replace the regulator.
Jul 17, 2012 | 1990 Subaru Legacy
A/C unit no longer cooling. Showing pressure at 100 psi.
did you use a manifold gauge, HI and LO side, if your compresor is not engaging probably due to a low charge, because your gages must read about 15F below ambient temperature that translate to on a 80f day uyour gage must read about 95psi on hi and lo (no compresor running)with compressor runing your lo side must be around 35psi and your hi side around 200+ psi depending on amount of air cooling your conderser, also note charging amout tag to not overcharge system, on other hand your problem may be a electricall, check your fuses and MG/C cluth relay by pass it to confirm your compresor is in good working condition.
Jul 08, 2012 | 2000 Toyota Celica
Compressor reaches 125 psi but does not shut down
Depending on how old your compressor is, usually inside the pressure regulator cover are instructions on how to adjust the turn-on and shut-off pressures. If not, it usually invloves turning a nut or screw to lessen the pressure on the spring that keeps the contacts closed. Try adjusting the pressure down. If it won't come down to a safe level you will be better off replacing the pressure switch. The number you give above is the Campbell-Hausfeld (they are Husky) part number for the pump and motor assembly so I don't know which CH pressure regulator you need. They are easy to find and easy to replace.
Jun 21, 2012 | Square D 9013FHG14J52M1X Air Compressor...
Evolv 2 brad nailer no power
If you can check nailer on another compressor. If it works check your compressor, if not the nail gun is in need of repairs. Otherwise, reading the two guages on the compressor, check that the pressure in the tank is around 100psi and the regulated pressure is between 85 and 90psi. If not, regulated pressure is adjusted by the knob on the front of the housing. With a blowgun on the end of hose, connect the other end to the compressor. If you don't get any air the regulator may be broken and not letting air through. If you have air at the blowgun the problem may be with the nailer.
Apr 08, 2012 | Craftsman Air Tools & Compressors
Need to find and replace the DPFE-15 sensor. Dealership diagnosed when service engine light came on and saaid this is what needed replacing. Problem is I do not know where to find it on the engine.
Exhaust Gas Recirculation (EGR) System The exhaust gas recirculation (EGR) system is designed to:
  • reintroduce exhaust gas into the combustion cycle.
  • lower combustion temperatures.
  • reduce the formation of oxides or nitrogen (NOX).
The amount of exhaust gas reintroduced and the timing of the cycle varies by calibration. Timing and volume are controlled by the following:
  • engine rpm
  • engine vacuum
  • exhaust system back pressure
  • engine coolant temperature
  • air charge temperature
  • throttle position
The EGR valve (EGR valve) (9D475) is vacuum-actuated. The vacuum hose routing diagram is shown on the Vehicle Emission Control Information (VECI) decal. The EGR system is a differential pressure feedback EGR Sensor system. Differential pressure feedback EGR Sensor is a subsonic closed loop EGR system. The differential pressure feedback EGR system:
  • monitors EGR flow rate by the pressure drop across the metering orifice located in the EGR tube.
  • uses a differential pressure feedback EGR sensor as the feedback device.
  • uses the EGR valve only as a pressure regulator, rather than a flow metering device.
  • controlled pressure is varied by the valve movement using vacuum output of the EGR vacuum regulator solenoid (9J459).
  • allows for a more accurate assessment of EGR flow requirements.
Differential Pressure Feedback EGR Flow Diagram
Differential Pressure Feedback EGR Sensor Removal
  1. Disconnect engine control sensor wiring (12A581) from Differential Pressure Feedback EGR Sensor.
  1. Disconnect Differential Pressure Feedback EGR Sensor hoses from EGR valve to exhaust manifold tube (9D477).
  1. Remove retaining nuts or bolts (depending upon application) and EGR Differential Pressure Feedback transducer.
Installation
  1. Follow removal procedure in reverse order.
  1. Tighten retaining nuts or bolts (depending upon application) to 5-7 Nm (45-61 lb-in).
    Differential Pressure Feedback EGR Sensor, 3.0L (2V) Engine
    Differential Pressure Feedback EGR Sensor, 3.0L (4V) Engine
    Item Part Number Description 1 6049 RH Cylinder Head 2 - Differential Pressure Feedback EGR Sensor 3 - Nut (2 Req'd) 4 - Stud Bolt 5 - Bolt (2 Req'd) 6 - Differential Pressure Feedback EGR Sensor Bracket A - Tighten to 5-7 Nm (45-61 Lb-In) B - Tighten to 8-12 Nm (71-106 Lb-In)
    Engine Emission Control Component Location-3.4L SHO Engine
    Item Part Number Description 1 95607-05200 Nut 2 - EGR Sensor Hose 3 - EGR Sensor Hose 4 95027-08016 Bolt 5 - Differential Pressure Feedback EGR Sensor 6 9J433 Differential Pressure Feedback EGR Sensor Mounting Bracket 7 9D474 EGR Solenoid Vacuum Valve (2 Req'd) 8 A4670 Vacuum Tube Assembly 9 9424 Intake Manifold 10 9J459 EGR Vacuum Regulator Solenoid A - Tighten to 5-7 Nm (45-61 Lb-In)
Hope this helps
Aug 14, 2011 | 1999 Ford Taurus
Do I adjust the staple depth with the pressure from the regulator?
there should be a thumb screw behind the trigger. turn it clockwise for a deeper depth and counter clockwise for shallower.
Let me know if this helps
Feb 26, 2011 | Surebonder 9600 Pneumatic Fine Wire Staple...
The compresor is not building up the pressure, it only reaches like 15 PSI .. and is not the drain valve
check the regulator valve. the black cap must be pulled out slightly to allow it to turn. adjust that while watching gauge for change. there is also another pressure release near the pump be sure it is seated fully.
Jan 16, 2011 | Craftsman 3 gal. Air Compressor, 1 hp,...
Clarke Power Products Inc AC2001 2HP 4 Gallon Pancake Tank Compressor Logo
283 people viewed this question
Top Clarke Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Clarke Air Tool and Compressor Expert? Answer questions, earn points and help others
