Question about Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television
While tv was on there was a popping noise then the tv went off. I turned it off for a few minutes and turned it back on but the tv is completely dead.
    Brigadier General:
  • 4,090 Answers
OHH NO! You are possibly the victim of blown capacitors on the Sustain boards This is not a matter of swapping boards as most times the problem involves more components than jsut the obvious, what caused it in the first place? overload on the pwoer board or the other Sus board?? It is not a DIY without the knowledge of handling HT electricity, radiation, reading a circuit diagram and having the right tools to trace, repair and retune. Otherwise why would we need to train TV techs for 3 years? Any that have attempted to play board swap jockey are still on this forum trying to fix what coulod have been done cheaper if they had taken it to a professional. If its under warranty get it there fast.If you have household insurance and recently experienced a storm with lightning claim fusion.
Please rate my help++++Thanks for using FIXYA
Posted on May 12, 2010
Testimonial: "There is no way to verify the solution but since you replied so quickly I assume you have seen this problem before and so I trust your judgment and will not pursue further action for the cost probably be prohibitive. Thanks again "
Samsung HLS5086WX/XAA made popping noise and shut off, then made whirring noise.
When my TV did this in the past it ended up being the color wheel. I had someone replace it and it worked fine. I asked it if had to be calibrated after it is installed and he said no. Also make sure the door switch is pushed down when you install the back bulb door. Sometimes this switch can go bad as well.
Jan 10, 2013 | Samsung HLS5086WX/XAA
Tv goes on and off a few times then turns off
Thats a common symptom which is usually caused by the Small signal board. You can get a replacement small signal board from www.tvrepairworld.com
Jul 16, 2010 | RCA HD52W66 Projection Television
I have a LG rear projection 64 Inch TV and the other night it made a POP noise, and then the screen went black, so i quickly got up and turned it off for a few minutes, then back on again and it didnt...
Hey, its always better to give your model number from the back of the tv to get more relevant answer. However, it appears that you have a DLP TV and its TV Lamp has gone bad. For Sacramento area check on www.fixurtvs.com for more answers and repair cost estimates. The bulb gets worn out in 2 to three years and at times operates intermitted for few minutes to some hours. So if you have a DLP TV and its more than 2 years old, change the Lamp. Its easy and most people can do it as described in the owner's manual.
Feb 26, 2010 | Televison & Video
Vizio GV47L not turning on after a pop noise
screen went black due to power supply failure. check also inverter.
May 30, 2009 | Vizio GV47LF Television
Tv went out after loud pop and has clicking noise does not turn on
If you have a Sony DLP, then the loud pop you heard is your lamp.  The lamps last approx. 4K-6K viewing hours.  Read your manual for replacement part number to reorder and very simple to replace yourself.
Apr 22, 2009 | Televison & Video
check your power board, most likely that's the part that is causing the problem.
Feb 09, 2009 | Vizio GV47LF Television
TruTech 19" LCD TV+DVD
I have a sansui 19" LCD TV+DVD
I had to attempt multiple times turning the TV on to get a picture. The sound was fine. This kept happening when I would go to turn on the set the TV kept playing fine with picture & sound but after the 2nd attemts I turned it off & then tried to turn it back on which took multiple attempts, it kept playing for a few minutes then the picture went out but the sound was still there.
The set is not yet 2 years old.
Mar 13, 2008 | TruTech PLV1615T 15 in. LCD Television
Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television Logo
160 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
