Question about Hamilton Beach BrewStation 47224 Coffee Maker
Brews finw but won't keep coffee hot
I've had it for over a year now and it's been great
lately it brews fine but won't keep coffee hot
Hamilton Beach Brew Station Delux 47454
    Genius:
  • 1,667 Answers
Could be the thermostat sensor, or the warm mode heating element, or the section of the control module for the warm mode. The details are model dependent.
If the coffee maker is out of warranty, it may not be worth servicing.
Jerry G.
Posted on May 12, 2010
It will not make coffee in either the Keurig pods or regular ground coffee. It says PURGE, or NEEDLE after I clean it and use paper clip to remove grounds. What else can I do?
Customer Reviews: Hamilton Beach 49995 FlexBrew Single ...
www.amazon.com/Hamilton-Beach...FlexBrew.../B00...
Amazon.com, Inc.All in all, the Hamilton Beach FlexBrew Single-Serve Coffeemaker is an ... exhibit the same exact problems using the K-Cups recommended by Hamilton Beach.
Hamilton Beach FlexBrew Troubleshooting Common ...
? 3:39
https://www.youtube.com/watch?v=yA2dlGKUBKM
Sep 7, 2015 - Uploaded by Ronald Kretz
Hamilton Beach FlexBrew Troubleshooting Common Problemmust see if you ... Hamilton Beach Single ...
Customer Reviews: Hamilton Beach FlexBrew Single-Serve ...
https://www.walmart.com/reviews/product/21130276
WalmartProblem the model I purchased was the only one they made that uses K Cup. ... MyHamilton Beach FlexBrew Single-Serve Coffeemaker was truly a wonderful ...
FlexBrew® Single-Serve Coffee Maker (49995R) - Hamilton ...
https://www.hamiltonbeach.com/all-coffee-maker...
Hamilton Beach BrandsThe FlexBrew® Single-Serve Coffeemaker allows the flexibility of brewing freshly ...Not sure how much coffee grinds to add when brewing your next cup? ... and thenrunning 2-3 cycles of cold tap water before making the next round of coffee. ... 2016Hamilton Beach Brands, Inc. Trademarks by Hamilton Beach Brands, Inc.
Hamilton Beach FlexBrew 49995 - Consumer Reports Online
Jan 05, 2016 | Hamilton Beach 49995 FlexBrew Single Serve...
Hamilton Beach BrewStation 12 cup Coffee Maker, coffee leaks into the bottom water reservoir after brewing.
there is a small rubber flap valve in the tank. if you carefully clean that on a regular basis your problem should end.
Dec 26, 2011 | Hamilton Beach BrewStation
Hamilton Beach brew station dispenses very slowly. I have cleaned it twice but still takes a long time to fill a cup!
Try to have a look whether there is a limestone layer built up on the element.
That will slow it down, while most probblems will stop it alltogether.
Remove by leaving white vinegar in it overnight.
Sep 04, 2011 | Hamilton Beach BrewStation Deluxe 47474...
Hamilton beach brew station spring problem
The spring goes at the top of the stem, under the filter basket. This keeps tension on the basket, so it will pop up when you remove the cover.
Oct 11, 2009 | Hamilton Beach Coffee Makers & Espresso...
Keeps shutting off after one cups is brewed even if filled for 10 cups
Hi, this is a common problem with Hamilton Beach on several models. There are also a host of other problems with them. There is no fix for these coffee makers. They are "throw aways" have owned them myself in the past and understand your problem. Sorry to sound so negative but Many people are disappointed with Hamilton Beach.
Good Luck.
Aug 17, 2009 | Hamilton Beach BrewStation 47214 Coffee...
I have a hamilton beach brew station, and the coffee won't get hot. Any suggestion?
There is a Thermal Protector Fuse at one end of the brewing element that overheats and is designed to fail(Either at 128C, 140C, or 228C).
It is likely that one of these is the culprit.
Some coffee makers have 2 different ones. The part costs about $1.70 at a local electronics supply or online. Taking apart the coffee maker is a chore, but can be done if patient. The fuse must be soldered back in place carefully. Getting it too hot will ruin the new one. If you have no technical background, I wouldn't suggest trying to fix it yourself.
Alternatively:
If the coffee maker is less than 2 years old, you can call Hamilton Beach and they will give you instructions on how to RMA your coffee maker.You need to give them the code # on the bottom of the unit. They will request that you cut off just the plug and send it to them with a check for return shipping costs.
May 19, 2009 | Hamilton Beach BrewStation 47224 Coffee...
Stops brewing before all water empties from reservoir
I went to Hamilton Beach site and read the troubleshooting. I followed there cleaning instructions and reduced grind time on my coffee and the machine is working perfectly again. I stressed over this problem for a long time before following their operating instructions. Have had the machine for over two years now and it's back to working perfectly. i.e. Run a pint of white vinegar through it. Wait 30 minutes and run another full vat of water....wait again and run another full vat of water. If you're grinding your own coffee, you may be grinding it too fine. Otherwise Hamilton Beach recommends the kind of coffee to use. Also the problem maybe too dense of a filter. This is all info I got on the H. Beach troubleshooting site. Good Luck !!! Mine is back to working great !
Jul 24, 2008 | Hamilton Beach BrewStation 47214 Coffee...
My brewStation 47214 stopped pumping water today, even though the warming element continued to get hot. A half dozen screws later I discovered a second heating element inside the coffee maker. The internal element is what heats the water and forces it into the basket. This element was burned out, religating my brewstation to the garbage. Probably last 3+ years.
Jul 11, 2008 | Hamilton Beach BrewStation 47214 Coffee...
Hamilton Beach BrewStation 47224 Coffee Maker Logo
201 people viewed this question
Top Hamilton Beach Coffee Makers & Espresso Machines Experts
Jerry Greenberg
Jerry Greenberg
Greg Cann
Greg Cann
Are you a Hamilton Beach Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
