Question about Keurig Platinum B70 Coffee Maker
I have a Keurig platinum brewer and the clear plastic water reservoir is cracked. How or where can I order a replacement? The Keurig web site does not have a parts catalog.
    Sniper:
  • 67 Answers
I know of a site that sells all kinds of keurig parts for discount prices check it out i have used them before http://stores.ilikenew.com
Posted on Nov 17, 2010
    Champion:
  • 213 Answers
If you’re looking for Keurig Parts, you can find them on this website.
http://www.igotsweetdeals.com or http://igotsweetdeals.ecrater.com/
We have most parts for Keurig b30, b40, b50, b60, b66, b70, and b77.
If your parts not listed just send us an email and let us know what part you need. In most cases we can have the part pulled and shipped the same day!
Our parts are used and the prices are exceptionally fair. Ask about our scratch and dent parts to save more money!
If you have any questions about your Keurig or your having a problem just give us a call and we may be able to help you.
Posted on May 14, 2010
How do I remove the bad Plastic Smell & Taste from my Keurig B70 Platinum coffee brewer?
That should not happen. Return for a replacement. The heating resovour may have factory material in side the unit.
Jan 21, 2013 | Keurig Platinum B70 Coffee Maker
Won't pull water up into k cup, instead hot water flows back into the reservoir.
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Sep 13, 2011 | Keurig Platinum B70 Coffee Maker
Water reservoir does not hold water cracked how do I get a new one
Here is a tip that I wrote about how and where to get replacement parts foryour Keurig Coffee Brewer
Keurig CoffeeBrewer Replacement Parts
heatman101
Sep 11, 2011 | Keurig B60 Coffee Maker
I have a puddle of water that is leaving out of the coffee maker from the bottom. (underneath)
Here's what I discovered about my Keurig B60: The water reservoir has a valve in a nipple on the bottom that slides into a clear plastic fitting within the base of the unit. Water from the reservoir is supposed to pass through the fitting and into the pump, which is also in the base. Over time, hard water deposits can build up on the nipple or the mating fitting (or both) such that a good seal is not made when the reservoir is in place and water slowly leaks out the bottom. To fix this, I removed the five screws on the bottom of the Keurig and then removed the two screws which hold the fitting in place. I gently cleaned both the clear plastic fitting and the nipple in the bottom of the reservoir with white vinegar. After rinsing both with clean water and drying both, I applied a small amount of silicon faucet grease (available at any hardware store) to both parts. I haven't had any more leaks since, although I assume I will have to repeat this operation periodically.
Aug 28, 2011 | Keurig B60 Coffee Maker
We recently obtained a used B70 coffee pot from my mother-in-law. There is a charcoal filter, but I am not sure where to put it. It is in some kind of holder that has 1 through 12 on it. Do I just drop...
Keurig has the manuals for their coffee makers here: http://www.keurig.com/customer-service/brewer-registration-and-support/user-guides-and-help . The B70 is their Platinum Brewing system. The direct link to the manual is http://www.keurig.com/customer-service/brewer-registration-and-support/~/media/DD2E19AE632A45BDAA55D72706420B74.ashx .
You need to put the filter into the reservoir at an angle (caddy-corner to the reservoir). According to user comments, it works best going from the front left corner and back to the right. Others find they need to wet the filter for 30 minutes and then squeeze out some of the excess water to loosen the filter. This site has comments on using the filter with the Keurig brewers: http://www.keurig.com/accessories/water-filter-starter-kit .
I hope this helps.
Jul 19, 2011 | Keurig B70 Coffee Maker
We have just descaled our Platinum unit and reset all the functions. When attempting to make a cup of coffee, it says it is brewing, but NOTHING is happening. What do we do?
If your brewer is not brewing the full amount selected, it may be caused by the following:
The exit needle is clogged by coffee grounds or cocoa mix. Please refer to the K-Cup Holder cleaning instructions.
The brewer may need to be de-scaled. Please refer to the de-scaling instructions.
The removable water reservoir was removed during brewing. Place the water reservoir back onto the brewer and perform a cleansing brew without a K-Cup.
First try to make a descale maybe repeat it the next day.
http://www.keurig.com/customer-service/brewer-registration-and-support/~/media/FD69E91A51CA41BEBF4CCAA138325BBF.ashx
Then try also this helpful tip
http://www.youtube.com/watch?v=DqRs4Ott21s
Jul 04, 2011 | Keurig Platinum B70 Coffee Maker
My keurig stopped pumping water through to make coffee. water just flows back into the reservoir.
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
Jan 21, 2011 | Keurig Platinum B70 Coffee Maker
Coffee tastes like rubber / plastic - brand new Keurig Platinum - any suggestions?
After getting in touch with the Keurig folks - I tried their solution. And... it worked! The coffee this morning tastes wonderful! Here is what they said:
To get rid of the "new brewer taste", we recommend you flush three reservoirs of water through the system. Please add 2 tablespoons of white vinegar to the first reservoir of water. To do this, follow these simple steps:
~ Open and close the handle to simulate a brew cycle (without a K-Cup)
~ Press the largest cup size and brew a cup of water.
~ Repeat the process (opening and closing the lid, then brewing) until the reservoir is empty.
~ Flush two more reservoirs of water through the brewer in the same way.
This process will clear any lingering odors or flavors and allow you to enjoy an unadulterated cup of coffee.
Aug 19, 2009 | Keurig B70 Coffee Maker
Keurig Platinum B70 Coffee Maker Logo
428 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
