Question about Brother GX-6750 Typewriter
How do I type to the end
I need to reset the right hand margin
  • 240 Answers
To reset the margins you need to first release the margins. Once you have released the margins you will be able to set the left and right hand margins.
Thanks,
Pat
Posted on May 12, 2010
3 Suggested Answers
Geno111
  • 183 Answers
SOURCE: What keys do I use the change the left and right margins?
You set the margins by putting the printhead where you want the margin set, and holding down the CODE key, push the key under where L MAR or R MAR is printed, (above the top keys on the keyboard) depending on whether you want to set the right or left margin.
If you want to set the left margin to the left of where it's set, hold down the CODE key and push the key under MAR REL. Then using the Backspace (or spacebar, if you backspace too far) position the printhead where you want the mar. set and holding down the CODE key, hit the key under L MAR.
Setting the right margin works the same way.
Posted on Oct 28, 2008
  • 3594 Answers
SOURCE: MARGINS
Try a little light oil on the silver shaft that the carrier slides on, if that doesn't do it then the carrier motor needs lubed, it is under the case on the R. rear corner.
DickyO
Posted on Apr 13, 2009
How do you reset the margin on SC-XE6000 when right margin is stuck mid-page width?
Press and hold margin release key while sliding carriage to the left using the carriage release on the end of the carriage, behind the platen (roller) knob, there is one at each end. Put the carriage where you want it and press margin set to reset margin position.
Nov 20, 2014 | Office Equipment & Supplies
Need manual for SC -XE6000 and the right margin is stuck as if locked in the end of a label position about 3/4 across the page. Just purchased at a garage sale.
reset the margin or look for something interfering with the movement try turning it off and manually move the carrier to the left and right it should move with only a slight resistance
Nov 09, 2014 | Office Equipment & Supplies
Need to change the pass word
p.p1 {margin: 0.0px 0.0px 0.0px 0.0px; font: 13.0px Arial} p.p2 {margin: 0.0px 0.0px 0.0px 0.0px; font: 13.0px Arial; min-height: 15.0px} p.p3 {margin: 0.0px 0.0px 0.0px 0.0px; line-height: 16.0px; font: 13.0px Arial} p.p6 {margin: 0.0px 0.0px 0.0px 0.0px; line-height: 16.0px; font: 12.0px Helvetica; min-height: 14.0px} li.li3 {margin: 0.0px 0.0px 0.0px 0.0px; line-height: 16.0px; font: 13.0px Arial} li.li4 {margin: 0.0px 0.0px 4.0px 0.0px; line-height: 18.0px; font: 13.0px Arial} li.li5 {margin: 0.0px 0.0px 4.0px 0.0px; line-height: 15.0px; font: 13.0px Arial} span.s1 {font: 13.0px 'Lucida Grande'} span.s2 {font: 11.0px Arial} ul.ul1 {list-style-type: none}
the only way to change the password is to either login to the router and
All Belkin Router's ship without an admin password. If you require an admin password then follow the below instructions.
Setup steps:
  • Connect the computer to one of the four LAN ports on the router.
  • Open a web browser on the computer.
  • In the address bar of the web browser, type http://192.168.2.1
  • Click Login in the upper right-hand corner of the page. The router does not ship with a password, so just click Submit.
  • Click on System Settings under Utilities on the left-hand side of the opened page.
  • You will see a feature called, "Administrator Password". Type in your current password (default leave blank).
  • Click "Apply Changes". Your new password is now active.
if you dont know your password then you have to reset the router to factory settings
Setup steps:
  • Locate the reset hole on the router. The button will be on the back or side of the router.
    See images below:
  • Leave the router powered on.
  • Use a paperclip (or similar) to press and hold in the reset button for 10 seconds.
  • Remove the paperclip.
  • Wait approximately one minute for the router to restart.
Mar 06, 2011 | Belkin (F5D5231-4) Router
L.C. Smith & Bros. typewriter No. 5 Margin setting
Make sure the carriage lock switch isn't on (presuming it has one). A carriage lock switch prevents the carriage moving when in transit (say, inside its case). These switches are usually located on the right hand side of the carriage, slightly underneath.
Gordon
Jul 19, 2010 | Royal MS 25 Typewriter
R margin is not in the right place
Not positive about but many electronics you must press and release the mar rel key for it to function.
DickyO
Apr 05, 2010 | Brother EM-530 Typewriter
How to clear margin when in use
Left margin...use the code key (colored)
Move the carriage to where you want the margin, use margin release if you have to go beyond the present margin, and use the margin set key to set.
You have to reset a margin. can't just clear one.
Can set margins at each end of the typing line, then you will have no margins.
Hope this helps!!!
Dec 16, 2009 | Smith Corona Wordsmith 100 Typewriter
MARGINS
DickyO
Apr 11, 2009 | IBM Wheelwriter 30 Typewriter
Left margin
It may be that the rail is sticky, put a little light oil (sewing machine oil will work) on a cloth and wipe the rail end to end with it then work the carrier left to right with the return and tab keys this should free it up.
Jun 03, 2008 | Swintec 7040 Typewriter
Margin Release for Brother GX-6750 Typewriter
Typewriters have alimit to how far to the right or left that you can set margins. Once you use the alt & 6 key to bypass the current margin setting then move to the new setting then hold the alt key and touch the 7 key to keep it in the new position.
Mar 09, 2007 | Brother GX-6750 Typewriter
Brother GX-6750 Typewriter Logo
267 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
