Question about Rv Motorhome Dual Co & Lp Gas Alarm Detector
I have a 1998 venture popupcamper but I don't know how to turn on the heater and the refrigerator they are both lp
  • 6,674 Answers
Can you see any make and model numbers on fridge (inside door) , and remove front cover of furnace and look for make, and model number as well. I'm also assuming the propane system has been checked for safety by a certified technician?
Posted on May 16, 2010
I have a 2000 chevy venture.just replaced heater core and still have no heat.whats the deal?
There is a damper that routes the air across the heater core or AC coil (don't know why one is a core and the other a coil, same tech). Its actuator has probably failed.
Please repost this problem to Cars and Trucks and you will find a better answer. Other choice is to go to a GM blog site for Ventures and someone there will give you exact instructions. Should be free to join and they have tons of data.
Oct 07, 2012 | Chevrolet 2000 Chevrolet Venture
03 chevy venture rt.front parking light&turn light don't work replace bulb&socket
The rapid flashing occurs because of the light problem. If the 20A PARK LP fuse in the underhood fuse block is OK, the front marker lamps and the park lights should turn on when you set the headlamp switch to PARK. If the 10A T/SIG fuse in the instrument panel fuse block is OK, and the ignition switch is on, moving the turn signal multi-function switch to signal a right or left turn should cause the turn signals to flash. If this doesn't happen, check for a missing ground connection to the socket you replaced and check to be sure the replacement lamp was not forced into the socket backwards (it happens).
Sep 17, 2012 | 2003 Chevrolet Venture Passanger
I have a problem with my Ruud LP heater. The gas valve is model VR8440M2024. Does anyone know what the M2024 means? I have found VR8440 valves on line but don't know if they will work with my unit....
The Robertshaw 720-079 is a universal type replacement valve. It comes with an LP conversion kit. You will probably come out better off using this than trying to locate the OEM part.
Sep 26, 2011 | Ruud UBHC Air Conditioner
Heater has power but flashes code L.P
• The low-pressure switch senses the refrigerant pressure in the sealed refrigeration system to protect
against certain conditions that could be detrimental to compressor life. The switch turns the heat
pump off in the event of loss of refrigerant, fan motor failure, evaporator freeze-up, or airflow
blockage. The heat pump will automatically reset the switch after the system pressure rises to the
normal operating pressure. The display will show "LP", if this switch is tripped.
For more info, look at page 7 on this manual:
http://www.hayward-pool.com/pdf/manuals/Manual280.pdf
Either you need to defrost the coils, clean the air-flow chamber, get a new air-flow switch or you are running low on refridgerant.
Dec 09, 2010 | Hayward Pool & Spa
I have a Dometic RV refrigerator Model # NDR1062 and it works with the electric power with the generator on (not on battery)but will not work on gas. The gas unit clicks like it wants to start but will not...
My best guess without seeing it is you are not getting gas to the unit
Break the gas supply line at the gas valve with the LP turned on and see if you are getting LP gas
Without the proper water column inch meter it is impossible to tell if you are getting the right pressure, but if your stove top, heater and water heater work then I sill guess you have rubber hoses feeding your refer. Propane and rubber build an oil that will over time plug the supply line and not allow LP to reach the refer. They have to be cleaned out and it is a messy job
Dec 19, 2009 | Dometic NDR 1062 Refrigerator
Frost builds up in freezer compartment. The freezer coil is clogged with frost/ice
not knowing the model number
i would venture to guess there is a problem
wiith you defrost system
that includes
heater
terminator
timer
Oct 08, 2009 | GE GSS25JFM Side by Side Refrigerator
Need the removal procedure for the G6A-8E RV water heater.
SHUT OFF ALL ENERGY SOURCES TO HEATER. REMOVE ELECTICAL SUPPLY LINES AND TAPE THEM OFF. DRAIN WATER FROM HEATER. REMOVE AND CAP WATER LINES. TURN OFF LP. REMOVE AND PLUG LP LINE. REMOVE SCREWS FROM OUTSIDE CIRCUMFERENCE OF HEATER. PULL HEATER OUT.
Aug 27, 2009 | RTO Atwood Water Heater - 6 Gal LP
Norcold n1095 not working on AC...works fine on LP
Yes. LP is direct heat to the exchanger. The thermistor operates through the control to the electric heater.
Apr 22, 2009 | Dometic NDR 1292 Refrigerator
Rv Motorhome  Dual Co & Lp Gas Alarm Detector Logo
132 people viewed this question
Top Camper Vehicle Parts & Accessories Experts
Jim Goldsmith
Jim Goldsmith
Mike
Are you a Camper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
