Question about GE Profile Spacemaker Over-the-Range Microwave
Can you get a replacement for the vent fan cover? the plastic has broken in several places and it has fallen off
    Brigadier General:
  • 4,090 Answers
Well you could try SEARS to see if they can help, ( if you own a bank)
or as no one said it has to match the model you could buy a car fan ( type that fits into the cig lighter) and remove the front cover from it and place over the M/Wave fan region to give the blades some protection. This approach is a few dollars rather than a truckload.
Your local auto shop would be able to supply one of these for about $10.
+ $2 for some sellys glue to hold it in place.
Please rate my help++++Thanks for using FIXYA
Posted on May 12, 2010
I have a ge advantium speedcook oven #SCA1000Hww01. The top vent is broken and has fallen off and I need to replace it but can't figure out from the manual what the part number is. I'm sure
The service manual (with exploded views, disassembly info, and part numbers) is here.
You can order GE parts from the Pros here, our favorite supplier.
Jan 16, 2013 | GE Advantium SCA1000H Convection /...
Broken vent door/flap
Go to www.ebay.com Type: make and model of microwave, refine search to vent flap you might get lucky, if no luck, have a handyman come in and fashion a part.
May 09, 2012 | Jenn-Air JMV8186AA Microwave Oven
Fan and light buttons pushed in, how do i install new buttons.
I just fixed mine. Same problem.
  1. remove the top vent (like replacing filter) w/ 2 or 3 screws on the top of the unit
  2. Remove the one screw on the top of the clock/control unit.
  3. Remove the clock/control panel by sliding up then out
  4. See circuit board at the bottom for the 3 switches. Hopefully it just popped out of place.
  5. pop it back into place and re-assemble
  6. if it's broken, you'll have to find the replacement part here: http://www.geappliances.com/service_and_support/
  7. If the actual buttons (black plastic) are broken, you have to replace the whole plastic housing for the electronics. Probably a big project and/or you'd replace the whole bit for hundreds of dollars, but even still, it's a pop-out, pop-in.
Good luck,
-tj
Nov 16, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Sharp 1470 over-the-range microwave - no power on panel
Did you unplug any wires when you took it apart?
Otherwise, I would think one or more of the connectors got unplugged when you removed the control panel.
Another thing that can happen on these models is a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under thebottom edge of the switch. It's usually the top door switch.
You can find the wiring diagram at our site here.
After you look into this, if you still need help, please write back with more details.
Oct 12, 2008 | Sharp R-1610 Microwave Oven
GE JVM1860SF001
Be sure the oven is unplugged.
There are two Phillips head screws on the very top of the outside of the cabinet above the vent.
When they're removed the vent grille just snaps out.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Sep 12, 2008 | GE JVM1860 Microwave Oven
Microwave handle replacement
How to replace handle on GE Advantium SCA1001DSS.
Remove two screws on top at front in order to remove plastic front vent grill. Then the door lifts off pin hinges. Lay door flat on surface. Plastic trim snaps off with gentle prying (start at bottom middle and bottom hinge side). Then remove six screws holding notched metal section with door latch. This piece will also snap out (several visible clips holding it around edges). Then remove door handle screws, Replace handle and reverse process to put back together.
Jul 29, 2008 | Microwave Ovens
Problem
This is the waveguide cover and it should not be broken. You have to replace it.
Jul 19, 2008 | Panasonic NN-S540BF Microwave Oven
Glass Surface Light Lens Cracks from Halogen lights use
The lights do get very hot, so they must be a sufficient distance from the lens. Was there an instruction sheet with the new lens? You may need to adjust the sockets upward. You might call a local GE-authorized servicer to see. Concerning the vent fan, this is a problem with the control panel assembly, which we repair nationwide for $39.95. Details are at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Aug 06, 2007 | GE XL1800 1100 Watts Microwave Oven
Front vent fell off
This should be a very easy fix. I assume you are talking about the plastic vent grill on the top of the oven above the door. There should only be a couple of screws holding it in from the top. The grill then should tilt out from the top first then from the bottom to remove. Since you said that it had fallen off, it sounds like the tabs where the screw holes are have broken off. This is a common problem. You can buy the part by ordering from the manufacturer, or from most repair websites. All you need is the model number from the microwave. Good luck.
Jun 19, 2007 | GE JVM3670 Microwave Oven
GE Profile Spacemaker Over-the-Range Microwave Logo
109 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
