Question about Magic Chef CDB1500AW 24 in Builtin Dishwasher
Where is the rinse aid container and how do I open it?
  • Magic Chef Master
  • 12,061 Answers
  • sandi
    sandi Apr 23, 2014
    I see no place to add rinse agent in my DU2000W dishwasher
  • 8,197 Answers
The rinse aid is on the door.
To add rinse aid, turn the dispenser
cap counterclockwise and lift off. Pour
rinse aid into the opening until the
indicator window looks full. Replace
the dispenser cap and turn clockwise.
Make sure cap is fully locked.
Now if your dishwasher is the magic chef CDW1500AW you can get the manual on the link below. If not can I get the make and model # to get you the right one.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/User%20Instructions%20-%20W10157795.pdf
Posted on May 12, 2010
  • 423 Answers
SOURCE: cant find rinse aid container
Many old dishwashers don't have a drying aid dispenser. If you have one, your will find some sort of cap to remove in the door, near where you place the detergent powder.
If you don't have one, you can buy an alternate vesion fo drying air, which is this little "basket" that you hang from the top rack. Avaiable in most stores.
Posted on Apr 04, 2009
  • 9 Answers
SOURCE: I want to change my rinse aid product
run it through a couple of empty washes or use it just to wash dishes without rinse aid. this should allow you to add rinse aid into the container after each wash there after just add more rinseaid. it could take a while to get full rinseaid coming out but eventually there should be only rinseaid in the container.
Posted on Apr 11, 2009
  • 864 Answers
SOURCE: can the rinse aid dispencer become clogged and can it be opened
Manual does not say anything about possible clogs. Since the dispenser can be removed you might try soaking it in hot water and rinsing it out. Check the openings to see if there is any buildup that can be removed.
Here is the manual:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%208535039.pdf
Posted on Jul 09, 2009
  • 457 Answers
SOURCE: Greetings from Downunder, i have a
the rinse aid compartment has to be one of the biggest things in your unit. it helps with drying process or you will have wet dishes, helps with spots, and also with the cleaning process, this is what you can do . add jet dry or rinse aid not soap .fill compartment then close door ,then raise and lower door 3times then open the compartment door and add more repeat this process until you cant add anymore. this will pull all of the air out of the dispenser and allow you to fully fill compartment . the light should go off .
Posted on Mar 04, 2010
SOURCE: I have a Bosch dishwasher with a rinse indicator
Phone Bosch 08448 928 979 for a step by step solution. Program select at 12 o'clock. Press ON/OFF and Time Delay button together. Press time delay button, display should change from 1 to 0, indicating warning light is inactive.
Posted on Jul 14, 2010
Dishwasher cloudy glasses
I do not have enough information to be able to answer with hundred percent certainty.
From my experience, the most common problem is the improper handling of the appliance. Driven by overwhelming commercials we often pass from detergent to tablets. The largest number of tablets contains rinse aid that we already have in the dispenser. Practical adding a double dose of rinse aid resulting in poor washing results and glasses look like washed in milk. The solution is to open the dispenser and put the dosage rinse aid to minimum. In electronic dishwashers new generation is even possible to completely exclude the dosage rinse aid if you are using tablets.
Dado
Aug 26, 2014 | Indesit Dishwashers
Where to put rinse aid in cdw10 dishwasher
Rinse aid makes dishes sparkle more as it improves their drying. The rinse aid container is situated on the inside of the door. You should fill the rinse aid container when indicator lights up on the container and the rinse aid indicator light on the control panel flashes. You can use simple vinegar as a rinse aid (white is best but apple or malt is fine).
Adding rinse aid.
To open the dispenser, turn cap anticlockwise. Take care when you pour in the rinse aid to avoid it overflowing. You can regulate the amount of rinse aid used by the dishwasher, move the adjuster which you will find under lid. The amount of rinse aid needs to be increased if the dishes appear dull or you can see circular stains. The amount of rinse aid needs to be reduced if the dishes are sticky or see white streaks.
You can choose from six different positions. It is normally set to 4.
Jun 07, 2014 | Hotpoint 24 in. FDW60 Free-standing...
What do these lights mean there not going off
The top light is apparently to indicate that the salt (!) has run out.
The bottom light is apparently to indicate that rinse aid has run out.
For the record, that seems to be a Zanussi DE-6854 dishwasher, and I found the manual here: (link)
"Special salt can be added in one of two ways: 1) If you are using dishwasher detergent that already contains salt, the detergent including the salt is placed in the detergent compartment. - In this case the water softener must manually be set to 1 and electronically to 1 to ensure that the special salt is taken from the detergent container only. 2) If you are using dishwasher detergent and salt separately, the special salt is to be put into the salt container. - In this case the water softener must manually be set to 1 or 2 and electronically between 1 and 5 (depending on the water hardness in your area) to ensure that the special salt is taken from the salt container only. Only use salt specifically designed for use in
dishwashers. All other types of salt not specifically designed for use in a dishwasher, especially table salt, will damage the water
softener. Only fill with salt just before starting one of the washing
programmes. This will prevent any grains of salt or salty water, which
may have been spilt, remaining on the bottom of the machine for any period of time, which may cause corrosion." (Page 6)
"Only use branded rinse aid for dishwashers. Never fill the rinse
aid dispenser with any other substances (e.g. dishwasher
cleaning agent, liquid detergent). This would damage the
appliance." (Page 7)
The manual also explains how to turn the Rinse Aid light off permanently if you do not wish to use rinse aid.
Mar 23, 2013 | Dishwashers
Hobart CHF 40 dishwasher water coming back into container and flooding
You don't need to use regular dish detergent. Use dish washer detergent. Check seal around door also.
Mar 03, 2013 | Hobart Dishwashers
The "Rinse Aid" red light
The rinse aid light is just an indicator to let you know the rinse aid is low. You fill it in the container next to where you put the detergent. Just push the yellow button and the lid will pop up. rinse aid is more important on the newer miele dishwashers, as they dont have "active drying" like the older dishwashers did. They depend on the rinse aid to sheet the water off the dishes at the end of the cycle. They are designed this way to reduce energy consumption. If you choose not to use rinse aid, and you dont mind wet dishes at the end of the cycle, either disregard the red light, or fill the rinse aid dispenser with water to trick the machine into thinking it is full.
If you are not going to use the onboard water softener, you can turn it off. Refer to your owners manual, or call miele tech support at 800 843 7231 and they can walk you through the programming to disable the water softener. these are not fault lights, they are simply reminders that you need to fill the containers.
Jul 20, 2011 | Miele Dishwashers
I have a Bosch dishwasher with a rinse indicator light. When the light is on it's supposed to be indicating that the rinse aid is emptybut my rinse aid container is not empty even though the light is on....
Jun 25, 2010 | Dishwashers
Greetings from Downunder, i have a HDWSE12 dishwasher Rinse aid light flashes all the time and it won t go. I put dish liquid in rinse aid container - still flashes. Don't normally have to use rinse...
Mar 04, 2010 | Dishwashers
Dishwashing liquid was added to the rinse aid, how
Get a squeeze bottle of warm water and flush the container out.
Feb 21, 2010 | LG LDF6810 Built-in Dishwasher
Apr 10, 2009 | Maytag 24 in. DWU7402 Built-in Dishwasher
Magic Chef CDB1500AW 24 in Builtin Dishwasher Logo
483 people viewed this question
Top Magic Chef Dishwashers Experts
240cpa
Are you a Magic Chef Dishwasher Expert? Answer questions, earn points and help others
