Question about Whirlpool GEW9250 Electric Dryer
Smells like burning and trips the breaker - Whirlpool GEW9250 Electric Dryer
  • yadayada
    yadayada May 12, 2010
    DO NOT OPERATE THIS DRYER, CALL A SERVICE TECH ASAP!
  • Whirlpool Master
  • 12,061 Answers
This is very bad, please disconnect from the wall.
http://136.166.4.200/contents/Laundry/DLE8377/DLE8377_Service_Manual.pdf
Above is a service manual, so you can troubleshoot and identify your problem.
However, in my professional opinion, I think, you would be best to call a professional.
Posted on May 12, 2010
When a electric water heater smoking and it gits turned off at the breaker box will there be a chemical smell after
No. A water heater is a sealed system it needs to be addressed for the original problem. High sulfur content has been a complaint as far as smell,and I remove the anode and replace with a brass plug because of. Shallow wells in the area largest complaints.
Nov 27, 2014 | State Water Heaters 40 Gallon Select SL...
Kitchenaid Dishwasher trips the 60-amp main breaker but not 20-amp.
Its possible that there may be load on that circuit from other appliances. Had an issue myself with stove and laptop on same circuit.
Check other appliance attached to the 60amp circuit (microwave, stove, kettle etc)
May 13, 2012 | Electrical Supplies
During self-cleaning cycle we heard a loud pop and it tripped the breaker. Oven and stovetop (ceremic) still work but we smell the same smell from that cleaning cycle like electrical burning? Is there any...
If any appliance trippes the breaker there is a problem that has to be looked into, no appliance should trip MCBs or RCBs (trips), ISOLATE THE MAINS POWER BEFORE REMOVING ANY PANELS
A visual inspection of the rear is required, also the electrical mains connections. Look into this do not use the appliance until you have resolved the problem, it may turn out an amount of food had been stuck beside one of the heating elements, and causing a smell, better to be safe.
Let me know if you require any further assistance.
John
May 20, 2011 | Frigidaire Ovens
My dishwasher smells of burning and it tripped the electric
There are couple of things it could be...the most likely is that the motor has gone bad...they will smoke first and then trip the breaker...if you get under the dishwasher you will be able to follow your nose right to the motor is that is the problem...
The other possibility would be that the heating element went bad and melted something before it shorted and tripped the breaker...that to your should be able to see rather easily in the bottom of your dishwasher...
At either rate you should be able to smell the problem or see the burn marks...
heatman101
Sep 15, 2010 | Dishwashers
Comes on and kicks breaker smells like something is burning
if you smell burning then i would say the transformer is burning and if will trip breaker . some times the mag has failed causing over load to trans and both will have to be replaced. this is a big buck repair . you may want to replace ..
Jan 04, 2010 | Hotpoint RVM1435 Microwave Oven
Electric shock from cooktop, didn't trip breaker,
Where did you smell the smell was it from the fan switch. turn the power off and take the screw out of where the fan switch is and check the wires to the switch and the switch itself. sometimes the jennair cooktops have issues with that switch. let me know how it goes
Sep 20, 2009 | Jenn-Air JED8230 Electric Cooktop
Dryer trips circuit breaker smell almost like something burning coming from dryer
In order to trip a circuit breaker, there is almost for sure, a dead short to ground. Takes quite a bit to trip a breaker. The smell is most likely something electrical burning. Stop resetting the breaker and have it checked out. Continous resetting and tripping can cause more damage. The breaker is doing it's job.
Jul 30, 2009 | GE DVLR223 Dryers
Dryer keeps tripping breaker. slight burning
The heating element is shorted. This is an electric dryer, right? replace the heating element. Make damn sure it's un-plugged when you work on it!
Jul 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Electrical Burning smell when agitating, trips breaker.
Send your complete model number, just to make sure we are working on same washer.
First check the lid latch switch by unplugging washer first and remove the font panel. Look up to where the switch is mounted. I am not positive that is your [problem but know there has been many problem with that switch. It will begin to melt ad cause the power to motor to be lost in a bad connection.
Mar 24, 2009 | Kenmore Washing Machines
Hoover HDC7FM condensor dryer starts then cuts out
Open the dryer door (right after the breaker trips) and check for a burned smell. If it smells in the dryer, you probably have a direct short in the dryer wiring. Check for a burn smell at the wall socket. There may be a short in the socket itself, but not likely unless a mouse is lying across the contacts in the wall.
If everything checks ok replace the circuit breaker if this is an older home. Circuit breakers weaken after years of use. A 30 amp circuit breaker will trip at a much lower amperage after a period of years especially if it has tripped often.
Mar 12, 2009 | Hoover HDC7FM Dryer
Whirlpool GEW9250 Electric Dryer Logo
124 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
