Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
Green screen when changing channels. Works find most of the time but on occasion when changing channels with the remote a solid green screen comes over the entire screen. You can still get sound, and you have to cut the TV off and back on to clear the green screen. Sometimes if you continue to change channels, the screen will return to normal. We have broadband cable. Thanks!
Hi Betty, I have the same problem and am researching it so far I have read a variety of solutions not sure what to believe however here are a few of them. 1.Conections on a little white ribbon strip/cable inside the tv needs to be cleaned 2.Change your HDMI cable to a better one and or use standard RCA jacks 3.Unplugging the tv for 10 minutes then plugging it back in. 4. T-Con or video board going out 5. Factory reset? I hope someone has a solution fo this.
Posted on May 14, 2010
  • jphill1 Sep 18, 2010
    I have the EXACT same issue on my Sharp purchased 2/6/2010. Model LC-60E77UN.
    Did any of these suggestions work?
    Thanks for your help.
Viera tc-32lx600 when power is turned on the screen goes from solid red to solid green to solid blue to solid white to solid black and then repeats. the sound works and you can change channels but stays in
Reset this TV. To do this, you have to enter its service mode options. Visit the site named 'Electro-help' for more details. Check this link and select the site. View it in 'Flip card' option, which can be selected from the drop down box menu at the left top corner or the display window. It will make search easy. Some times, the ads attached with each posts might help you to find the availability of spare parts. There are more than 550 posts to different brand TVs.
Aug 11, 2012 | Panasonic TC-32LX600 Television
I have a Panasonic TV CT-34WX50 every time I change channels
it sounds that have problem in the chroma board ( video board ) a small board that hooked up in the neck of the picture tube. if the color is greenish the cause is dead in red video driver transistor or open resistance. hope this can help good luck.
Jul 26, 2012 | Panasonic CT-34WX50 34" TV
The tv was working fine the other day. I turned it out today and the screen just stays black. If I press the channel button up or down the channels change and sound comes out. The audio works fine, but the...
Turn it off/on a few times within a few mins each times.U get a flashes of picture about 10 to 20 sec?Than ur LCD inverter board is dead.Tries Websites Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for the replacement.It usally a long PC board in shape.
Apr 16, 2010 | Polaroid FLM-3232 Television
Can you buy a universal remote for TV 2 to change the channels? My remote for SAT DISH stopped working the lights on the top come on but I can not change the channel, view the guide etc...
The remote is an Ultra High Frequency remote and most universals are IR MAKING THEM INCOMPATIBLE.
Take the TV2 remote into the TV1 location and using the TV1 remote press MENU-MENU. You will now have a screen up that has remote addresses at the bottom. Take the TV2 REMOTE AND PRESS AND HOLD the SAT button on the upper left of the remote until all lights on top illuminate and release. Now key in a two digit number between 1-16 that is not either number on the screen currently and press the pound sign. The SAT button will flash three times now press the record button until the remote addy for tv2 changes to the new number.
You can cancel out of all of these screens with the TV1 remote. Now go to TV2 see if it works. If not try at the receiver. If it works there have Dish send you a new remote.
Thanks for using Fix Ya.
Feb 01, 2010 | DISH Network IR Remote Control
Works on occasion.
I believe this set has two relays in the power supply. One for standby power and one for full power. I have seen cases where the full power relay drops out or not energise causing the same symptom you describe. Lightly tapping on the relay sometimes identifies the culprit.
Hope this helps
Skyassoc
Jun 20, 2009 | Hitachi 53UDX10B 53" Rear Projection...
When I adjust the volume on the remote control it changes the channel, but not on every occasion.
Hey,
This could be due to the accumulation of dust inside the remote control. You can try to open up the controller and just clean it up.
Thanks
Apr 15, 2009 | Televison & Video
Channel keeps changing
It sounds like a stuck button or switch. What happens when you hit the channel DOWN, does it still keep scrolling down?
Is this with or without the remote?
Have you tried it with the remote and or the TV?
Let me know whether you are changing the channels with the remote or the buttons on the tv and I can try to give you a couple more suggestions.
Mac =)
Feb 12, 2008 | Televison & Video
Sharp Aquos LC-42D62U VOlume Control
OK guys I'll save you. The tv is in hotel mode. To get it out from there you have to go in service menu but DO NOT CHANGE ANY OTHER THING IN THERE, only what i tell you. With the tv on and the K letter on the screen press in the same time vol- and ch- on the tv set. Now you'll be in service mode. On the remote press down arrow (not -channel) and you'll see up industry init. go there with ch- and press vol+ and enter. let the tv like that for few seconds and the tv will go green and hopefully industry init succsesfull will be on the screen. After that unplug the tv and replug it. Done!
Oct 19, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
42" Plasma TV Problem
same frustrating symptoms on brand new 42inch here! tv just turns itself off sometimes without warning or if changing to certain channels. leaves red light flashing for a while then red light goes away. any attempts with remote gives flashing green liht on tv. manual power off and on restarts tv but auto off again. found while manual power on keep changing channel on remote till stable picture appears. then use remote to shut down tv - solid red light indicates standby mode. then use remote to turn on again... till next time it happens. but what is technical fault??
Aug 18, 2007 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Black Box appearing on my screen
Shut off the closed captioning and your problem will be gone.
Jun 26, 2007 | JVC AV-27F702 27" TV
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
726 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
