Question about Casio Atomic Timekeeping WV58A 9AV Watch
Got mine yesterday and its set on eastern time zone, i need pacific time zone and it will not sync, how to manually adjust ime
    President:
  • 2,501 Answers
You should be able to set your watch to the Pacific time zone.
f you haven't got instructions on how to do this, you can get
instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
You shouldbe able to find the setting method in the manual.
Posted on May 12, 2010
Silicon scientific atomic watch
Should be 4 buttons, 2 on left and 2 on right. Press bottom left 3 times and hour offset digit will be displayed. Press and hold top left until hour offset digit starts to flash. Press either top or bottom right to adjust offset hour to correspond with your time zone. Eastern -5, central -6, mountain -7, pacific -8. These are negative numbers, not positive. Then press top left button once, then press bottom left button to return to time display.
Jul 31, 2016 | ATOMIC Watches
I want to change time zones on my casio edifice. I can't work it out.
Press the button on the top left-hand side of the watch until the display shows the current hour and the letter "P," "M," "C," or "E" which indicates the current time zone. (Pacific, Mountain, Central or Eastern.) If the time zone is not correct, press the button on the top left-hand side of the watch until the correct time zone is displayed.
Feb 28, 2011 | Casio Watches
Set time zone on centrios atomic clock
1. In the normal time mode, Press MODE key to enter the alarm time mode .
2 Press SET key to change the time zone, P is pacific, m is mountain c is central and e is eastern.
Nov 26, 2010 | Watches
How do I reset the time when I move into a different time zone
mcdevito75 here, You re-set the time in a different time zone the same way as you do for the time zone your in now. The different time zones in the USA ru from 1 to 3 hours before the time in the Eastern part of the USA, example, Eastern time 3 PM, then going West, you have Central time 1 hour before, then Mountain time, 2 hours before , then Pacific time 3 hours before eastern time.
Aug 10, 2010 | Timex Automatic Watch
Eddie Bauer wireless thermo clock - Time zone problem
TIME ZONE SETTING
The cefault time zone is PACIFIC. lf your location is not in the Pacific zone, set the
time zone as follows:
1. In normal time mode, press the "[,4ODE" key to enter the alarm time mode. 2. ln aiarm time mode, press and hold the ADJ . 'Cl"F" key for 2 seconds to enter
the time zone setting mode.
3. Press ihe "ADJ "C/'F" key to select the proper time zone: P=Pacific
M=Mountain C=Central E=Eastern 4. Press the f,'lODE key to save and exit the time zone setting mode, or let it exit
automaiically 30 seconds later without pressing any key.
Mar 08, 2009 | Watches
Cannot delete
My watch has a tiny letter just to the right of the signal strength indicator. In my case it is a C because I live in the central time zone. Perhaps you live in the eastern time zone? The E may not be short for ERROR but instead stands for EASTERN. Its called the E/C/M/P indicator.
I don't know if you have had a chance yet, but the manual that I talked about previously does show this feature on the first page. Its called "Operation Guide 2608 2638 2688". Your watch almost certainly has a 2688 module.
I hope that was the E that you were talking about.
As for the signal sign, you want it to be there. You need to worry when its absent. :-) I think all waveceptors are like that.
I hope that helps.
Dec 27, 2008 | Casio G-Shock GW500A-1V Wrist Watch
Silicon radio control watch, what # is the eastern zone
It depends which way you are looking at- West or East.
5th time zone on West is for: Greenland, Canada, USA, Bahamas, Jamaica, Columbia, Peru.
On East: Russia, Kazakstan, Uzbekistan, Afghanistan, Pakistan, India, Maldives.
I just do not understand why you do need this. All radio controlled watches are receiving the signal from the place in country where watch is worn- in my case its Rugby in England.
Use your user manual to sort this out.
Dec 11, 2008 | Bulova Watch
Analog will not sync with digital
I just bought a 4756. Hard to follow that manual.
In the end I used these parts of the manual
Step 1 was to set the correct time zone (off PT or pacific time to ET eastern Time.)
Step 2 was to do a manual receive of the radio time.
Step 3 was to Home all the analog hands so they all pointed to 12. see manual
Step 4 then I hit B button - top right by the 2 and everything spun around to the right time received from the manual received time.
Dec 21, 2007 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Timex T5E881
You have to get in the right time zone, that’s why you are an hour off (and this may also occur if you are in an area that switches between daylight savings time each spring and fall).
Press mode until ZO appears on the watch face.
Press and hold ADJ. Time zone will begin to flash.
Select start/stop or adjust to get to the right time zone P, C, M, E (pacific, eastern, Mountain, central)
If desired , press mode to select DST (daylight savings time) and press start/stop or adjust to turn it on or off.
Press adjust when done.
Nov 10, 2007 | Timex 1440 Nylon watch
Daylight Saving Time will not set correctly
Use this page to download a copy of CASIO watch manuals in PDF format. To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
http://world.casio.com/wat/download/en/manual/
You will need a pdf reader on your pc, you will find all instructions in there.
If you don't have a pdf reader you can get one from
http://www.foxitsoftware.com/pdf/rd_intro.php
Nov 08, 2007 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Casio Atomic Timekeeping WV58A 9AV Watch Logo
306 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
