Question about Sharp Viewcam VL-Z3U Mini DV Digital Camcorder
VL-Z3U DEW and E007
My VL-Z3U will not eject the tape and displays DEW and E007 when I turn on play or record mode.
I am very good at fixing things. Please tell me exactly where these two solder tabs are.
As I face the tape mechanism, on the bottom right, on top of a tiny motor, I see two solder tabs. Are these the ones?
They appear to be leads to the motor. Why would shorting the motor help anything?
4 Suggested Answers
SOURCE: E007 and DEW indicator
Few restarts fixed this for me but I know this is going to come back again soon.
Posted on Jun 24, 2007
SOURCE: driver
send me driver for it
Posted on May 02, 2008
SOURCE: My Sharp VL-Z3U show a message that says,:Unit In Safe guard Mode
I was able to reset camcorder and problem cleared up. Thanks.
Posted on Nov 22, 2009
My cam say in the display dew and shut off
It sounds like you have moisture in the camera. Place it in a warm dry place for about 24 hours. Also make sure you take the battery out of the camera too.
Regards.
Apr 12, 2010 | Sharp Viewcam VL-Z3U Mini DV Digital...
Nov 20, 2009 | Sharp Viewcam VL-Z1 Mini DV Digital...
Sharp VL-Z1 will not load the cassette...
Modification is available to fix this problem, contact sharp repair facility.
Oct 18, 2009 | Sharp Viewcam VL-Z1 Mini DV Digital...
What doe DEW mean? The "DEW" sign keeps coming on and then shutting off..
DEW sign indicates high humidity level inside the camcorder. What you experiencing has nothing to do with humidity, It is a faulty connector on a junction board. Sharp has fix for it.
Jul 12, 2009 | Sharp Viewcam VL-Z3U Mini DV Digital...
"Dew" sitting on my Video Camera
Dew Formation
What is “dew formation”?
When cold water is poured into a glass,
dew drops form on the glass. This clinging
of water drops is called dew formation.
When dew forms in your camcorder.
Dew will gradually form on the head drum
of your camcorder and make the video
tape stick to the head. This causes
damage both to the head and the tape.
When dew forms, recording and playback
may not function properly.
Dew is likely to form in the following
circumstances:
—When moving the camcorder from a
cold place to a warm place.
—When placing the camcorder in a cold
room which is then heated rapidly.
—When moving the camcorder outdoors
from an air conditioned room or car.
—When placing the camcorder in the
direct path of air
blowing from an air
conditioner.
—When placing the
camcorder in a
humid room.
How to prevent trouble.
When using the camcorder in a place
where dew is likely to form, allow the
camcorder and the video tape to
acclimate to the surroundings for about
one hour.
For example, when bringing the
camcorder indoors after skiing, place it in
a plastic bag.
1Be sure to tightly seal the plastic bag
containing the camcorder.
2Remove the bag when the air temperature
inside it reaches the temperature
of the room.
“Dew” warning feature
If dew forms, the word “DEW” flashes on
the screen, and the power will automatically
turn off in approximately 10 seconds.
Plastic bag
1If “DEW” flashes, remove the cassette,
leave the cassette compartment open,
and wait for a few hours to allow the
camcorder to acclimate to the
surrounding temperature.
2To use the camcorder again, turn on the
power after waiting for a few hours. Be
sure that “DEW” has disappeared.
3Do not insert a cassette while “DEW” is
flashing; this may result in damage to
the tape.
4Since dew forms gradually, it may take
10 to 15 minutes before the dew
warning feature engages.
Mar 13, 2009 | Sharp Viewcam VL-Z5U Mini DV Digital...
Sharp viewcam
my sharp viewcam model no VL-E650U CAN NOT PLAYBACK IN COLOUR AND SOUND
Apr 18, 2008 | Sharp Viewcam VL-Z3U Mini DV Digital...
Sharp Viewcam z
either it has moisture in it (let it dry), or the dew sensor is bad and needs to be replaced.
Nov 29, 2007 | Sharp Viewcam VL-Z3U Mini DV Digital...
Dew indicator
look inside the camera to the front.wou will see 2 solder bloba,run a line of solder between them to by pass the dew,it works
Nov 04, 2007 | Sharp Viewcam VL-Z3U Mini DV Digital...
Dew liht comes on and camcorder shuts off
I had the same problem with a VL-Z3U, there was no home fix, the dew sensor needed replacing costing $130 CAD
Jun 18, 2007 | Sharp Viewcam VL-Z1 Mini DV Digital...
Mar 30, 2007 | Sharp Viewcam VL-Z1 Mini DV Digital...
Sharp Viewcam VL-Z3U Mini DV Digital Camcorder Logo
Top Sharp Video Cameras Experts
NOEL
NOEL
David Payne
David Payne
Are you a Sharp Video Camera Expert? Answer questions, earn points and help others
