Question about Boating
I'm trying to figure out if my 1985 bayliner with volvo penta 125hp has power tilt/trim on it???
  • 2,926 Answers
It should have power trim. In the engine compartment, either on the left or right side you should see a hydraulic pump with a tank to hold the fluid. There will also be hoses running to and from it. There should also be a switch at the helm that allows you to raise and lower the drive.
Posted on May 12, 2010
Testimonial: "thanks for the help i think i found where its at but i'm missing some hoses, looks like the previous owner took them off and didnt replace i wonder how much it will cost to get it back in order??"
Bayliner boat cabin cruiser 1986 26 ft with gm motor and volvo penta carburator Need owners manual
What engine? 4cyl, 6 cyl, 8 cyl? 2.1 2.3 2.5 3.0 3.8 4.3 5.0 5.7 7.4liter?
Jul 31, 2017 | Volvo Boating
How do I find where the hydraulic pumppower trim is on a Volvo penta ad31 boat motor
Mounted to the inside transom. Usually on the starboard side.
Oct 16, 2016 | Volvo Cars & Trucks
Volvo penta wiring diagrams
Go to boat manufacturer and ask. However you might first check your ground connections at the motor and at the dash for corrosion or just loose.
Jul 14, 2014 | Health & Beauty
I need to find a free repair manual online for a volvo penta motor 1979
i have a fivehorese penta outboread engine is it water cooled or air cooled
Apr 01, 2011 | Volvo Boating
I have a 1985 bayliner with a 125hp volvo penta with 270 outdrive... i have 2 Q's 1. today the boat overheated pretty quickly, i think the thermostat has had it. after talking with some local boaters they...
It could be the thermostat is stuck in the closed position, but if you hear a troubling noise coming from the outdrive, I suspect the water pump impeller that is located in the outdrive is in need of replacement. A bad impeller in the outdrive will not assist in pumping water up to the engine, and will cause an engine to overheat quickly. The rough sound could be directly related to the impeller also, but could also be a different problem with the u-joint assembly or another outdrive internal component. Overheating can be caused by several things; Defective outdrive impeller, defective thermostat, clogged riser or manifold, defective engine mounted water pump assembly. These are the most common areas, but since there is a noise coming from the outdrive, I would concentrate trouble shooting this problem starting with the outdrive impeller assembly.
May 25, 2010 | Boating
1985 bayliner Volvo Pents 125hp 270 tilt/trim
Ebay will be the place! Especially this time of year, sellers will be getting rid of good parts. You will have to search the listings very frequently to see what comes up from day to day.
May 12, 2010 | Boating
Volvo penta 740 lower unit will not go down.
Kind of sounds like the trailer switch is in control. Many of these switches have lockouts and if you move the outdrive past the trip point the other solenoids are dead. Watch fingers. There may be a tilt switch on the water side of the transom in the pivot housing.
Jun 26, 2009 | Boating
Volvo-penta aq271c, trim will go down, but not up.no pwr at relay
First check the switch-- does it have power, then check the solenoid to see if it works-- there are two. One is for down, One is for up. If you get power from the solenoid-- outgoing-- check connections going to pump motor.
Mar 28, 2009 | Boating
Boating Logo
227 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
