Question about Minolta magicolor 2300W Laser Printer
I did a refail on three of my cartridges on Minalto color 2300 printer.Now the machine is printing blank. What is the problem
  • memi123 May 16, 2010
    It is now printing but jammed at the exit roller. I have replaced the exit roller but it still jams. It is trying to print color, but because of the jam at the exit roller, I cannot see a complete printout.
    Brigadier General:
  • 4,090 Answers
Often this is caused by cartridges that are over filled. Try tapping the cartridges to settle the powder down below the detection level. That should do the trick
aqlso change/empty the waste toner bag
Please rate my help++++Thanks for using fixya
Posted on May 12, 2010
Testimonial: "Thanks for your help. It did work for me."
The pages are not printed
sometimes in this case the dram needs to change (
Mar 01, 2015 | Samsung CLX 3185FW - multifunction fax /...
Color cartridge is not printing in color
Hi, According to your problem first check and make sure that the color cartridges are not blank and also make sure that the cartridges are moving properly. First clean the cartridge head and align them. Check the printer settings also. some time it may happens after two or three times refilling. in that case you have to replace the cartridges. IF the before job doesn't solve your problem then replace the cartridges.
Jul 05, 2011 | Office Equipment & Supplies
Cannot get it to print in color
Hi, According to your problem first check and make sure that the color cartridges are not blank. some time it may happens after two or three times refilling. in that case you have to replace the cartridges. First clean the cartridge head and align them. Make sure that the cartridges are moving properly. Check the printer settings also. IF it doesn't solve your problem then replace the cartridges.
Jul 05, 2011 | Lexmark X1270 All-In-One InkJet Printer
Color printer won't print color
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Dec 31, 2008 | Dell 922 All-In-One InkJet Printer
HP Laserjet 1500 Color, Print out Blank
Hi devi960:
Pages print, but all
colors do not print or
the pages are
completely blank.
One of the print cartridges might be
low or empty.
Run an engine test and see if all four colors print. If
not all colors print, replace one or more of the print cartridges. If the
engine test is successful, replace the formatter.
If the printed pages are completely
blank, the file might have blank
pages.
Check the file to make sure that it does not contain blank pages.
A print cartridge might be low or
empty.
Check the printer control panel for a Supplies Status message,
print a Supplies Status page, or use the embedded Web server
(HP color LaserJet 2500 series printers only) to see the levels
remaining in the print cartridges. Replace any print cartridges that
are low or empty. Messages are not created for non-HP print
cartridges.
If you are using non-HP print
cartridges, one or more print
cartridges are low or empty. The
control panel lights do not indicate
low or empty for non-HP print
cartridges.
Replace one or more of the print cartridges.
Font DIMM might be selected but the
font DIMM is not physically installed in
the printer. (This issue applies only to
printers using an Asian-language font
DIMM.)
In the settings for this printer, clear the Font DIMM check box on
the Configure tab if no font DIMM is installed in the printer. Select
the Font DIMM check box only if the font DIMM is physically
installed in the printer. If you think that the font DIMM is installed,
make sure that it is installed correctly.
The paper curls when
exiting the top output
bin.
The paper needs to print to the
straight-through paper path.
Open the rear output door to print to the straight-through paper
path. Remove each sheet as it exits the printer.
The stack was slightly curled when it
was placed in the tray.
Turn the stack over in the tray.
The paper does not meet
specifications.
See the user guide for information about print-media specifications.
If you are printing on light media, the
Type setting might not be correct.
Select Light in the Type is field in the printer driver.
Nov 13, 2008 | HP LaserJet 1500L Printer
Hp 2300 new cartridge printing black lines
There good printers its just who you use to get the cartridges from. We sell some but there not refills and we have good prices if your interested.
Unlike Ghana our can be returned if they don't work.
Jun 24, 2008 | HP LaserJet 2300 Printer
Can we print with other three Color ink cartridges when Black Ink cartridge is emptied?
hi,
as u have ran out of ink you cant print anymore... you have to replace a new ink cartridge.... this is because when u print something, the colors will get mixed to print the exact color.... even if u are printing only in black, some other colors wil get mixed to produce the black color on the paper... so u need to change the ink cartridge.... u cannot run with a blank filled ink cartridge.... and the selection of your printer is very good...
thanks and regards
agnel
Mar 19, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
Minolta magicolor 2300W Laser Printer Logo
85 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
