Question about Acer TravelMate 4101WLMi Notebook
Reboot? My laptop reads Load Error! Press a key to reboot... , but it does nothing after that. I have back up disc but it won't even load . Plese help
  • Acer Master
  • 5,569 Answers
You will have to access the CMOS setup to reassign the boot source to your CD/DVD drive otherwise your backup disc won't be seen.
Check your manual to see which key(s) must be held at power-on to access your setup.
Posted on Mar 28, 2008
2 Suggested Answers
SOURCE:
ginko
  • 19396 Answers
SOURCE: Reboot
You need to reinstall system
My os boot disc isn't responding is the disc bad or the hard drive bad
What error do you get?
Are you talking about the System CD or harddrive that gives an error?
Jul 17, 2009 | Toshiba Satellite A45-S151 Notebook
Reboot
Mar 28, 2008 | Acer TravelMate 4101WLMi Notebook
Acer Aspire 3600 only background picture, nothing loads.
you operating system is corrupted...causes :- improper software installation...O/S too old..and many other causes...you can try
go on pressing key "F5" as soon asyou switch on then a menu will appear select safe mode...
Need More to Know?..then please reply
____________________________________________________
Please Don't Forget Fo Rate Me "Fixya - Blue Boxes" For My Help
Sep 06, 2008 | Acer Aspire 3680 Laptop
Aspire 9500
Try to set bios to factory defaults, then save. Should be OK. If not reinstall system.
Aug 16, 2008 | Acer Aspire 9500 Notebook
Desperately need to fix my laptop
Yes this can be fixed however it will require reformatting the drive. If you have any vital information on your laptop take it to a professional as you will not be able to recover after you proceed.
Use any bootdisk (Ubuntu, XP, Disk commander) that you have at your disposal. Assuming you still your XP disc, change your BIOS to have the CD as the first boot device. If you have a proper XP disc (non-OEM) it should display a blue setup screen that will disappear after a few minutes. Then press R to enter Recovery Console, press 1 and then enter. Type fixmbr and press enter, then press y and enter again. Type exit and enter, the computer will reboot. Now follow through the install process.
Jun 15, 2008 | Compaq Armada M700 Notebook
Got following error: Load Error! Press any key to reboot
This problem is indeed caused by a faulty MBR but there are solutions other than zero-filling the drive.
If you can get access to a RipLinux CD there is a little utility called Testdisk that will write a new MBR code to the first block of the drive. I just did this on a Sony PCG-K15 this morning (after cloning the drive just to be safe) that was giving the same error of "LOAD ERROR- Press any key to reboot" and it worked like a charm. The machine booted right up.
Hope this helps...
May 09, 2008 | Computers & Internet
Load error
check your hard drive
May 09, 2008 | Acer Aspire 3000 Notebook
If the computer after power on is checking the drives ie the CD and/or floppy to boot from then it is a software problem. You need to put in your recovery CD/disk and hope fully it will allow you to just fix the errors within the boot up files and not have to install os.
Your norton could help - try booting from that or the ones you produced by using Norton.
If you have to reload then do not format just save old - it should give you that option.
Jan 30, 2008 | Computers & Internet
Start up problem
hi steve,
can you get into the BIOS?
if so, would u make sure the boot orders are following:
1st. boot from hard drive,
2nd, cd rom
3rd, floppy,
4th, network adaptor?
save changes and try restart.
i hope you do have OS installed.
if not change 2nd part to 1st, and 1st to 2nd.
i have gotten the same error with my laptop. my computer was trying to load window from network, through network adapter.
hope this information helps.
Dec 21, 2007 | Linare Desktop, AMD Sempron 2200,40 GB HDD...
Acer TravelMate 4101WLMi Notebook Logo
70 people viewed this question
Ekse
Alun Cox
