Question about Nintendo DS Lite Console
Nintendo DS Lite No Poer Up
Nintendo DS Lite does not power on -- recharge light is on (and plugged in), but power switch does not start the unit.
Should I trash it -- or are there a few quick things to check out?
  • ptryan123 Mar 29, 2008
    Yes it does.
    Sergeant:
    Champion:
  • 250 Answers
Does the power button have resistance? If not it is broken. Don't trash the unit if you decide you can't fix it. Sell it to someone like me who can fix it.
Posted on Mar 29, 2008
6ya staff
SOURCE:
DS Lite Will Not Power On
There is a possibility that your battery has developed a short circuit or is so bad that it pulls down the charge voltage on the charger. You are therefore left starved of a power and therefore no function.
If possible, disconnect the battery and run the DS on the charger power alone. If the DS starts to work, I suggest replacing the battery.
Sep 05, 2014 | Nintendo DS Lite
Hi, I can't get my Ds Lite to turn on. I plug it ...
you must have loose part into unit or power switch , it needs to be go to the tecnica l store
May 19, 2010 | Nintendo DS Lite Console
Nintendo DS won't power-up
It sounds like a faulty battery. As it is under 1 year old, it is still under warranty. Return it to the origional place of purcase, who will either fix or replace it.
Aug 19, 2009 | Nintendo DS Lite Console
It can't be recharged
The DS's battery has a limit to how many times you charge it,but then again the charger's wire inside it might be disconnected.
Try to buy a new DS charger and see if its the wire,if its not then try to call nintendo to see if they might be able to replace the battery(for a fee).
Mar 06, 2009 | Nintendo DS Lite Console
Nintendo DS Lite Purchased in the USA
Remove battery clean contacts on battery and game using pencil eraser. Then try charging. Or replace the battery
Dec 26, 2008 | Nintendo DS Lite Console
Nintendo DS Lite will not charge
GET A NEW CHARGER HAPPENED TO ME BEFORE my bad caps lol
Jul 18, 2008 | Nintendo DS Lite Console
Nintendo dslite wont turn on.tried charging it wit 3 different charges and it still wont charge
Ensure that you are properly recharging the battery.
1. Insert the small end of the adapter into the external extension connector (labeled "5.2V=IN") on the back of the Nintendo DS Lite, just next to the SLOT 1 Game Card opening.
2. Swing the prongs on the AC adapter until they lock into place, then insert it into a standard (120 volt) outlet.
The plug should be mounted vertically or on a floor outlet (such as a power strip).
3. Once the adapter is properly inserted, the unit will begin to charge (the orange charging light will display).
4. Once the DS Lite is fully charged, the orange charge light will go off.
Check the AC Adapter for damage (such as bent prongs or split wires). If you see damage to the AC Adapter, purchase a replacement from Nintendos Online Store.
Try plugging the AC Adapter into another wall outlet. Its possible the outlet is not working properly and has not been charging the Nintendo DS Lite.
If you are unable to get power to your Nintendo DS Lite, despite trying to properly recharge the unit, then your system will need to be repaired.
Nintendo offers convenient repairs, fast turnaround times and, for all systems repaired, a new one-year manufacturer's warranty.
Jul 14, 2008 | Nintendo DS Lite Console
Nintendo ds lite
YOU need to call NINTENDO customer service for assistance,
basically what they do is to ask you for the little bar code and to send the unit to them , they will replace it for a new one in
most of the cases , so good luck and give them a call. hope this helps & please rate , thanks AJ
Jul 01, 2008 | Nintendo DS Lite Console
DS lite
I'd suggest removing and then re-inserting the battery (this should at least switch the power off).
Is the power switch loose? If so it's been broken and needs replacing (not an easy job).
Alternately it could just be stuck in sleep mode which happens when the DS is closed while powered on but should awaken when re-opened.
HTH
Mar 03, 2008 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Ekse
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
