Question about Acer TravelMate 4101WLMi Notebook
Reboot My laptop reads Load Error! Press a key to reboot... , but it does nothing after that. I have back up disc but it won't even load . Plese help
  • Acer Master
  • 19,396 Answers
You need to reinstall system
Posted on Mar 28, 2008
  • Ginko
    Ginko Mar 28, 2008
    You will probably need to reinstall windows on your system.
    First thing to try is a reset of the laptop, unplugging power adapter and removing laptop battery for few minutes. Put everything together and restart so to reset the laptop.
    If it did not work try restarting in safe mode, pressing f8 key during startup.In safe mode do system recovery to last time system worked.
    This probably still didnt work, if it didn't it means the system has gone.
    Most common case is windows corrupted. in this case you need to reinstall the system.
    If you have factory recovery disks, this may be the best solution. Start laptop with recovery disk 1 in, boot from cd and restore system. You may have lost your data depending if you can make a partial recovery or you are forced to total recovery.
    If you do not have recovery disks you will need to get a windows setup disk to install windows.
    The worst scenario is when hard disk drive is corrupted. If hard disk drive is faulty you may have lost all date. In this case you will need to replace the disk and reinstall the system from recovery disk or windows setup.
Assus recovery problem
During the boot process you will see on the screen to press a certain key usually delete or the F2 key to enter setup
depending on your which bios you have it will differ
Press and hold that key during the boot up process to enter BIOS using the arrow keys navigate to load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
hope this helps
Jun 15, 2012 | ASUS Computers & Internet
When turned on screen lights up with apple logo but nothing else happens
reboot while holding the option key down. It should show you available hard drives from which you can startup.
Choose the drive and then press return or enter.
Then restart.
If nothing happens, turn off the laptop and insert your Mac OS disk and then reboot while holding down the C key.
The computer will load the system on the disc instead of your hard drive. Then instead of reinstalling the system software, look at the top menu and find the Disk Utilities program and run a repair on your hard drive.
Then reboot without the disk in the drive.
May 10, 2010 | Computers & Internet
How to fix a load error problem on a laptop
Find your DVD that came with your computer, reload your Operating System and system should work after that.
Oct 05, 2009 | Toshiba 15.4-inch 1.6GHz 40GB Laptop PC...
Acer Aspire 3600 only background picture, nothing loads.
you operating system is corrupted...causes :- improper software installation...O/S too old..and many other causes...you can try
go on pressing key "F5" as soon asyou switch on then a menu will appear select safe mode...
Need More to Know?..then please reply
____________________________________________________
Please Don't Forget Fo Rate Me "Fixya - Blue Boxes" For My Help
Sep 06, 2008 | Acer Aspire 3680 Laptop
Aspire 9500
Try to set bios to factory defaults, then save. Should be OK. If not reinstall system.
Aug 16, 2008 | Acer Aspire 9500 Notebook
Got following error: Load Error! Press any key to reboot
This problem is indeed caused by a faulty MBR but there are solutions other than zero-filling the drive.
If you can get access to a RipLinux CD there is a little utility called Testdisk that will write a new MBR code to the first block of the drive. I just did this on a Sony PCG-K15 this morning (after cloning the drive just to be safe) that was giving the same error of "LOAD ERROR- Press any key to reboot" and it worked like a charm. The machine booted right up.
Hope this helps...
May 09, 2008 | Computers & Internet
Load error
check your hard drive
May 09, 2008 | Acer Aspire 3000 Notebook
Reboot?
You will have to access the CMOS setup to reassign the boot source to your CD/DVD drive otherwise your backup disc won't be seen.
Check your manual to see which key(s) must be held at power-on to access your setup.
Mar 28, 2008 | Acer TravelMate 4101WLMi Notebook
If the computer after power on is checking the drives ie the CD and/or floppy to boot from then it is a software problem. You need to put in your recovery CD/disk and hope fully it will allow you to just fix the errors within the boot up files and not have to install os.
Your norton could help - try booting from that or the ones you produced by using Norton.
If you have to reload then do not format just save old - it should give you that option.
Jan 30, 2008 | Computers & Internet
Acer TravelMate 4101WLMi Notebook Logo
52 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
