Question about Samsung Televison & Video
2005 Samsung DLP HLP6163WX/XAA. Replaced Color
2005 Samsung DLP HLP6163WX/XAA. Replaced Color Wheel less than a year ago. TV will turn on, may have picture (for some time) may not but picture is slower to come on screen when it does now. May stay on for 5 mins, may stay on all day. Getting worse about picture not coming on at all. The only way to turn it off is to unplug it. Already changed Bulb but no difference. Strange thing is that now once turned on, no green or red lights on on/off button center bottom of tv and the remote won't turn tv on or off, volume control on remote won't work either. Control module buttons on side of tv don't work either, even when tv is on and sound is working. Something's haywire and I am bound and determined to fix it myself but am in need of some advise. Any ideas? Ballast? Temp module? No strange noises to indicate color wheel again. Could there be something else causing the internal sensors to not read remote and controls on side of tv? I am lost but not giving up.
Samsung 61
If using a cable or sat box try a DVD etc when set cold, a box can cause lockup issues via signal.
Not a color wheel is correct, more likely a DMD which is rather pricy and almost as much as the entire light engine which comes with it.
Oct 12, 2012 | Samsung HLP6163W 61" Rear Projection...
Chnaged the color wheel and lamp. stanby/temp and
YOU MAY STILL HAVE A BAD BALLAST OR POWER SUPPLY BOARD.Samsung recommends replacing the ballast and power supply board at the same time.
Jun 04, 2010 | Samsung HLP6163W 61" Rear Projection...
TV won't stay on
Hello Fonzell!
Regarding the tv turning, my question is, do you hear a clicking sound? if so, it's most probable tio be your ballast, that might not have enough voltage to keep on with your lamp, and that's why it shuts off.
You could try replacing it and seeing if it resolves your issue, I believe they're running around 70 dlls..
have a great one ! :)
Apr 21, 2009 | Samsung DLP HL-P5663W 56" TV
My Samsung 50" DLP HDTV keeps humming when the DLP lamp comes on.
Hi, you have one of two problems, either the color wheel is going or one of the cooling fans are going, the color wheels are a very common problem in samsung dlp`s, sorry I can`t nail it to a specific part but I`d bet it`s the color wheel as they are notorious for failing in samsungs, video-tek
Mar 17, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Replacement color wheel for samsung 50'
I am having the exact same issue with the exact same TV. They no longer make that color wheel, so I am looking for a replacement part as well.
I am looking at the 01103A as well from here:
http://www.partstore.com/Part/Samsung/Samsung/BP9601103A/New.aspx?ModelMfgName=Samsung&ModelBrandName=Samsung&ModelNumber=HLR5078W
I think I might just order it, and if it doesn't work just return it.
Jan 15, 2009 | Samsung Televison & Video
Model HLP6163WX / XAA DLP Samsung
Sounds like the color wheel shattered. If you google it, you should find information about replacement parts and installation. I had to go through the same thing a couple years ago.
Aug 08, 2008 | Televison & Video
Samsung HLS4266W 43" dlp
Power issues (Tv not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
Dec 24, 2007 | Samsung DLP HL-P5663W 56" TV
Televison & Video Logo
183 people viewed this question
Jerry Greenberg
Jerry Greenberg
