Question about Microwave Ovens
Noisy turntable - Microwave Ovens
    Guru:
  • 351 Answers
Hmm .. if it is the turntable that is making the noise, then remove the plate and the guide ring. Wash all the parts, and the track that the guide ring sits in and then all back together ..
Posted on May 12, 2010
Coleman EB15A - Buzzing noise from transformer area, no heat or fan
see this causes and proceed. God bless you
Magnetron If the microwave is loud or noisy only when cooking, the magnetron tube might be defective. The magnetron uses high voltage, high current DC power to generate the microwave frequency that cooks the food. Under normal circumstances the magnetron is nearly silent. However if it is damaged or nearly burned out it can begin emitting high pitched or growling noises. It's not normally dangerous to use a microwave oven when it makes these noises, but they are an indication that the magnetron is almost dead and will need to be replaced.
Exhaust Fan Motor If the microwave is loud when running the fan motor might be
Stirrer Motor If the microwave is loud or noisy the stirrer motor might be worn out. The stirrer is a metal blade which slowly turns around, deflecting the microwave energy in a random pattern inside the microwave oven. As the motor nears the end of its useful life it begins to make grinding noises. The microwave will not heat food evenly without this stirrer, the motor should be replaced.
Turntable Motor If the microwave is loud or noisy the turntable motor might be worn out. This is a common problem and relatively easy to replace.
Oct 18, 2012 | Microwave Ovens
GE microwave TURNTABLE slow-erratic and noisy JVM 1860 SD 002
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Jan 03, 2009 | GE XL1800 1100 Watts Microwave Oven
LG over the stove model lmvm 1935
In some cases, cleaning them helps. Lubrication is not recommended.
To order Goldstar / L.G. parts, visit Vance Baldwin Electronics.
Dec 07, 2008 | LG LMVM1935 Convection/Microwave Oven
The turn table goes clockwise sometimes & counter clockwise sometimes.It also makes a groumbling noise.
The motor for the turntable in these ovens is bi-directional. This is normal.
As for the noise, it is very common that the main turntable wheel track-ring under it is dirty at its wheels, or its pin-pushings have some wear. It is also posssible that the main turntable motor has become noisy from use and age.
I have had microwave ovens make a grumbly sound when one of the cooling fans are going defective.
Jerry G.
May 14, 2008 | GE Microwave Ovens
Turntable issues
As you say you are clueless about fixing anything, I suggest you take it to the service center and get it done. Replacing a electrical part has to be done properly, and fixing a turntable prob can be tricky.
Jan 06, 2008 | Frigidaire PLMV169DC Microwave Oven
Noisy when running - not the usual humming noise
check turntable motor or bush, this very easy problem, you can use oven no problem..
Nov 11, 2007 | Whirlpool GH8155XJ Microwave Oven
Microwave oven is noisy during use
Sounds like you have a failing turntable motor. You can contact LG / Goldstar about parts or service at 800-222-6457.
Apr 07, 2007 | Goldstar MA-790W Microwave Oven
Noisy turntable
I has this problem with a Sears unit. The repairman simply removed the glass tray, cleaned all the wheels and the 3 toothed driver wheel in the middle and it became quiet. He explained that if any buildup keeps the plate from properly seating on the gear, it gets very noisy.
Mar 25, 2007 | De Dietrich DME112X Microwave Oven
Noisy turntable
You can see exploded views and order parts here: http://tinyurl.com/gv383 The motor is reference # 42 on the drawing and parts list. Be sure to enter your FULL model number.
Jan 06, 2007 | GE JVM1842 Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
