Question about Proscan 19LA20Q LCD TV
I want to know about the power input - Proscan 19LA20Q LCD TV
I want to use theMackie as a sub mixer into a powered "all in one" Peavy mixer, where do I come out of the Mackie into one of my powered mixer line inputs?
Take the main outputs into a stereo input (or a pair of mono inputs) on the Peavey - without knowing which Peavey I cannot tell you further info re set-up but as you'll be sending line level signal you'll need to back off the gain on the channels you input to on the Peavey
Nov 17, 2016 | Mackie Music
Does anyone knows why an orange led flashes 3 times on the FB1 board that seems to trigger a reset of the TV's POWER ON SELF TEST causing the set to go into a cycle of booting and re-booting.
you always power on external boxes
wait till they settle then power on the TV etc
and look up the box on its input or switch the box to standby
power on the tv
then power on the TV and wait like 1 min
then power on any scart or hdmi input
then any TV will auto switch to the last detected input
Mar 26, 2015 | Sony Bravia XBR-Series KDL-40XBR4 40-Inch...
Need a replacement power supply for a Evernote scanner
Sorry Gregory, gave you the wrong number.
You could try something like this. Various voltages and currents with different adapter plugs. This is on Ebay UK but I would think there are others, don't know where you are.
Ebay item number: 201154296095
Specs:
1.Rated Input Voltage: AC 110V or AC240V
2.Vibration Input Voltage Range: AC95V-265V
3.Input Rated Current: 0.4-0.6AMP
4.Input Power: 90W
5.Efficiency: >88%(TYP)
6.Out Power: 90W
7.Output voltage: 15V/16V/18V/19V/20V/22V/24V(0/+0.5V NOLOAD): DC15V-24V
8.Output voltage: 15V/16V/18V/19V/20V/22V/24V(-0.4/0.5V@rating load): DC15V-24V
9.Output current: 15-20V/4.5A@22V-24V/4.0A: 4.5AMP(max)
10.Overload protection: YES
11.Short Circuit Protection: YES
Dec 17, 2014 | Office Equipment & Supplies
Input power for a Buslink dvrw812d-u2f
DC output 12V - 2A / 2.5A. Center tip positive.
Link to purchase a power supply:
http://www.buslinkbuy.com/product.php?prod_id=281
Mar 13, 2014 | BUSlink Computers & Internet
03 grand am powers up "lights,radio,etc.turn the key nothing
Why would you do 10 minute key trick ? Is the SECURITY light on steady ? Just a code reader ? Checks just Engine PCM codes ! Need a professional type scan tool to check codes in the BCM - body control module ! Don't know what and how much you know about these GM vehicles ? The ignition switch is a low voltage input to the BCM ! To determine power mode , off ,ACC , run , crank
On vehicles that have several control modules connected by serial data circuits, one module is the Power Mode Master, PMM. On this vehicle the PMM is the BCM. The PMM receives 3 discreet ignition switch signals to differentiate which power mode will be sent over the Class 2 Serial Data circuit.
To determine the correct power mode the PMM uses the following circuits:
• Ignition 0
• Ignition 1 voltage
• Ignition 3 voltage
Discrete Ignition Signals
Those modules that have discrete ignition signal inputs also remain in the state dictated by the last valid PMM message received on the serial data circuits. They then check the state of their discrete ignition input to determine the current valid state. If the discrete ignition input is active, battery positive voltage, the modules will fail-safe to the RUN power mode. If the discrete ignition input is not active, open or 0 voltage, the modules will fail-safe to OFF-AWAKE. In this state the modules are constantly checking for a change status message on the serial data circuits and can respond to both local inputs and serial data inputs from other modules on the vehicle . If you don't know anything about this your best bet , take it to a GM dealer . Without knowing what state the BCM is in or seeing from the ignition switch or if DTC'S - diagnostic trouble codes are stored , can't give you any sound advice . Would only be guessing !
May 31, 2017 | 2003 Pontiac Grand Am
I don't know which power adapter to use and I can't locate my user manual. What is the DC input? My problkem is I need to make sure I provide the right DC input - I have several adapters - what is the...
Most externals are 12v input voltage so as long as you have a adapter with this input voltage your be fine, and the hard drive should operate.
Let me know if you need more information.
Thanks
Jason
Oct 15, 2010 | SimpleTech SimpleDrive Pininfarina 320GB...
The CD Player I'm installing in my Accent says to connect one of the wires to an accessory terminal in the fuse block, Can this accessory be the power antenna?, the one with the pink wire? Regards and...
No - this is the positive key power input. Connect to the input power that was connected to your old CD tuner.
The antenna wiring will be separate. You will also have a battery power input. The battery power input will provide continuous power so that your presets don't get forgotten and your CD will play from the same place when you turn your car on and off. The accessory or key power lets your CD player know that you've turned your car on and it should also wake up.
Hope this helps, Sherwin
Jan 02, 2010 | 2001 Hyundai Accent
Power input
12 watts.
If you want to know more of the specifications in this flatbed scanner visit this link.
http://www.umax.com/support/knowledge/specifications.jsp?model=Astra+2000P
Jan 09, 2009 | Umax Astra 2000P Flatbed Scanner
Proscan 19LA20Q LCD TV Logo
82 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
