Question about HP OfficeJet 6110 All-In-One InkJet Printer
The unit won't turn on becuse of a scanner error. The direction is to turn the printer off, then on again. Makes a clicking noise for about a minute until the error message. Any ideas?
    Novelist:
  • 142 Answers
Please perform the steps provided in the following HP web link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00787271&cc=uk&lc=en&dlc=en&product=79477
:) Dr Tony
Posted on May 12, 2010
Laser scanner unit error. Turn off the printer,then contact the store you purchased the printer inform them of the error code displayed and symptoms. Error Code: E100 0000
that is what you should be doing as it is a warranty repair problem, not contacting fixya because you have a direction of what to do
Sep 19, 2016 | Canon LBP3300
Epson 610 Workforce Printer Error; Light Bar won't reset
Sound like the scanner is the issue, is it under warranty? OR the Scanner may be locked, check for the scanner release device unlock it,.
Dec 17, 2012 | Epson Workforce 610 All-In-One InkJet...
I have an HP 3055 all in one printer. When it's turned on and the scanner bulb is warming up it makes a clicking noise (like something is stuck) and an error 5 message comes up and says to turn it...
You can try this procedure that I wrote for the 3380. It works the same. click here
If this does not resolve the problem it is likely that you would need to replace the scanner mechanism.
May 08, 2011 | HP LaserJet 3055 All-In-One Printer
E100
The e100 would be a scanner unit error on the print engine. Turn the unit off and wait 10-15 minutes and turn it back on again. If the error comes back I would advise taking it to a repair depot the scanner unit would not be a user replaceable part.
Jul 21, 2010 | Canon LaserBase MF3220 All-In-One Printer
Scanner mechanism stuck, making loud clicking sound
I've just got this problem after a powercut, whilst it was not being used but on. If you have only had it a few months send it in warranty.
Think I will have to take this apart and see if the scanner cable/ribbon/drive belt is caught on something or been stretched too much and can be replaced at all.
Its like at one end its caught and wont move the scanning head being stuck somehow, caught on something (doubtful tho').
Apr 14, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Epson SX100 Scanner makes a loud clicking noise!
On the back of the Epson Perfection 1660 Photo there is a lever that shows a lock and a unlock by where you plug in the wire to the computer. It must be in the unlocked position otherwise it will make that loud clicking noise and not work. Hope this helps.
Apr 07, 2010 | Epson Office Equipment & Supplies
My cx3200's control panel reads scanner error. I unlocked the transportation lock, turned off, turned on. It stayed off for about 2 minutes then came right back on. While the error light was off tried to...
The only things that can cause a scanner error on this unit is a complete scanner harware failure or the scanner lock. With the unit on lock the transport lock and unlock it a few times quite forcibly. Then leave it in the unlocked position and power off and on again. If the light returns then at his point I think a new printer will be needed.
Jan 18, 2010 | Epson Stylus CX3200 All-In-One InkJet...
Scanner Failure message on my HP 6110
have you tried plugging into a wall socket, sometimes using power supply or powerstrip or surge procter will not let enough elect through to the unit.
Jul 22, 2009 | HP OfficeJet 6110 All-In-One InkJet...
HP Printer Color LaserJet 2840 Printer makes clicking noise and shows on display: Scanner bulb warming up - scanner error 5 Turn off then on but this does not work. Is it mechanical problem or software...
I Have A HP Laserjet 2820 on power up went through to scanner bulb warming up then made a clicking noise comming from scanner unit it was trying to escape the case. if this is the same as yours the problem is that the scanner unit can't find the home position strip mounted betweent the gray case wide piece right hand side as you look down on scanner unit with lid up & the top of the scanner glass inside the scanner unit to get to it you must remove top section of the scanner unit & cleean underside of scanner glass please E-mail me if you want full instruction.
Oct 13, 2008 | HP LaserJet 2820 Printer
Start up problem with printer
Your scanner glass is get dirty and all scanners make a self diagnostic program when we turn on the printers.
At this point, you will hear a little noise from the scanner carriage lamp, witch is doing self calibrating. In this calibrating time the scanner unit "read" the white and the black levels, and the white (in your case) is not white, is quite gray because is dirty.
The solution is a very simple, but require much skill.
You must disassembly the scanner unit, remove any screw you see (you need an no. 2 phillips screwdriver) and very gently remove the upper side (with glass) from the rest of scanner unit. Please note that is several plastic fasteners to be disposed.
after you remove the glass (with a plastic frame) you get a small tissue of cotton and soaking with an windows cleaner solutions. Gently clean the BOTH surfaces of scanner glass.
For assembly follow the reverse procedure.
Beware to the glass, it has only 3 mm thickness. Don't broke!
Like I sad: simple problem, but require much skill. If you think is to difficult for you, please go to the service.
Sep 21, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
111 people viewed this question
Seeker5211
Seeker5211
