Question about ParkerVision SIGNALMAX WR1500 (884181000031) Router
How do I reset my parkervision router.
I do not have my instruction booklet. I need to know who to hard reset my router.
  • 240 Answers
On the back of the router you should see a small pin hole beside the power cable. Press a pin in that hole and hold it down for a few seconds and the router should reset to factory settings.
Thanks,
Pat
Posted on May 12, 2010
I have two ParkerVision WR1500 4-port Wireless DSL/Cable Routers. The first one I have connected my Ethernet Cable from my modem to the WAN port. This is where I get my Internet Signal. My understanding...
You won't get internet connection that way because there is no connection between the first parkervision and the 2nd one.
Best way is use only one parkervision router. Connect WAN port to modem for internet, 1st lan port connect to your pc and 2nd lan port connect to 2nd pc in other room. 2nd way is, use only one parkervision. Connect WAN port to modem for internet, 1st lan port connect to your pc, setup wireless SSID and connect your 2nd pc to this router for internet wirelessly. Assuming your 2nd pc has wireless capability.
Apr 13, 2011 | ParkerVision SIGNALMAX WR1500...
Forgot password to my ParkerVision WR1500 Router. Please help.
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Dec 13, 2010 | ParkerVision SIGNALMAX WR1500...
How do I secure my parkervision wr1500 router
You want to secure the wireless network.
Is there any computer connected to the router with the Ethernet cable?
If not then you will need to connect the computer to the router with the cable.
Check the IP address on the computer. Open the router set up page.
Once you open the set up page, you will find the option to make it secured
Click Here
for step by step instructions
Mar 24, 2010 | ParkerVision SignalMAX WR1500 / SignalMAX...
What is the parkervision wr1500 defaul password?
By default your password for this router is 1234, but if it doesn't work it means that it was change already so better try your commonly use password and if still wont work reset the router to bring it back to its default settings with default password.
Mar 23, 2010 | ParkerVision SIGNALMAX WR1500...
LOST SOFTWARE TO PARKERVISION WR 1500 --- PLEASE HELP ! ! !
You do not need to have a disk for the router. The router has firmware built into the router. Make sure you have your lan into the 1 port and type in your browser 192.168.150.1 and it should take you to a screen to log in. The default is 1234 for the user and password.
You should be able to use the wizard inside of the router after you log in. Hope this helps!
Nov 20, 2008 | ParkerVision SIGNALMAX WR1500...
ParkerVision Signalmax WR1500
from the original docs:
Reset Button
The WR1500 Wireless Router reset button is built into the rear panel. Use this button to restore the factory default password to 1234; IP address to 192.168.1.1, subnet mask to 255.255.255.0 and DHCP sever enabled with a pool of 8 IP addresses starting at 192.168.1.33.
note my unit resets to ip 192.168.150.1
Sep 29, 2008 | ParkerVision SIGNALMAX WR1500...
How to get to the DMZ
it seems that the wr1500 doesn't have a DMZ feature. im not sure if it has a latest firmware that will provide DMZ but what you can do is use the port forwarding feature. you just need to know the ports of the applications that you want to pass the router's firewall
hope this'll help you and just ask me if you have other concern
ciao!
Jul 09, 2008 | ParkerVision SIGNALMAX WR1500...
Router
hello!
parkervision tech support number: 800 532 8034
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings if needed
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router
May 08, 2008 | ParkerVision SIGNALMAX WR1500...
My new alarm system / wireless router
What type of Alarm system? If that pakervision has network ports on the back there is no reason they couldn't run a cable to it and setup the security for you. I've never heard an alarm company tell a consumer "No you can't have wireless in your house" I'd need to know the model # of that parkervision because this doesn't make sense to me. If that parkervision doesn't have any network ports on it... yea go out and buy a wireless router that has ports on it.
May 01, 2008 | ParkerVision SIGNALMAX WR1500...
Reconnection problem
first try conecting a defrent computer ot the router then try to connect to the net. if that don`t work then update the firmware try here http://itchy.parkervision.com/support/WiFi/downloads/index.php if that don`t work then call 937-278-9141.
Aug 29, 2006 | ParkerVision SIGNALMAX WR1500...
ParkerVision SIGNALMAX WR1500 (884181000031) Router Logo
134 people viewed this question
Top ParkerVision Computers & Internet Experts
Aris C.
Aris C.
Larry Maranto
Are you a ParkerVision Computer and Internet Expert? Answer questions, earn points and help others
