Question about SanDisk Sansa c250 (2 GB) MP3 Player (SDMX7-2048)
Sansa c250 Micro SD card not recocnised
Help! When I connnect my micro SD card to my Sansa c250, it doesn't do ANYTHING! How do I find the songs that I have on my SD card?
  • cmde Apr 06, 2008
    I have the same problem. I saw a suggestion that I format the card from the player. That action deleted all of my music, both on the card and in internal memoray. I added music back. The system recognizes that the card is there and that it has files on it, but doesn't list the music so I don't know how to play those songs.
  • Anonymous Mar 15, 2014
    my polaroid wont pop back the micro sd card, i have to use a small paper clip to get it out, and also doesn't show files on card, how can i fix this.?
You need to create a folder named MUSIC on the MicroSD card to copy your MP3 files into
Posted on May 10, 2008
6ya staff
SOURCE:
How do I save songs, pictures, etc to SD flash card?
A SD flash card is not part of the player itself and you will need a SD card adapter to plug it into your computer. With the adapter you can transfer files over to the SD card and then place the card back into the player. Adapters are usually no more than 10 dollars at local stores.
Jul 13, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
Sandisk Sansa C250 won't recognize 8Gig micro chip
Your model doesn't natively support SD cards over 4GB, however I hear you can install something called "Rockbox," it's a free third party firmware that allows you to dual boot between "Rockbox" and the Sansa firmware. "Rockbox" adds the support you need for SD cards with a capacity of 4GB or more. I've never used this firmware, but it does sound promising.
Download it here
Sorry I couldn't be more help.
Jun 03, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
Song's will not appear on Sandisk Sansa e270 (6GB)
Go to http://www.sandisk.com/ and search for your mp3's programming and download it, no promises, but it worked for my sansa fuze
May 13, 2009 | SanDisk Sansa e270 MP3 Player
Micro sd probelem
Well, the most memory from a micro sd card the Sansa mp3 player can take is 2gb, because anything more will freeze up the player because it was not designed to read that much memory. So if you have a 1gb or a 2gb memory card, then you can use them.
Mar 01, 2009 | SanDisk Sansa MP3 Player
Micro SD card not read
The Sansa c250 and lower cannot read SDHC cards. They must be regular SD cards for the c250 to "see" them. That is, they must be of 2GB capacity or lower. If the card is 4GB or higher, it is a SDHC card and will not work.
Feb 28, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
Ghost Files
I would run the Sansa Recovery Tool for the c200 series - it will erase/format all the songs without deleting system files - it is available from Sandisk's website.
-Tha Mp3 Doctor
Dec 13, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
How to use memory card in sansa c250
This player only RELIABLY reads SD cards that are 256 MB or smaller - anything else is a crapshoot
May 27, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Sansa c250 sd card installation
yes i have the same problem how do i get the music onto card itself
Jan 10, 2008 | Audio Players & Recorders
Sansa e250 using micro sd card
Go to the knowledge base on the Sansa site and find this (chances are you have an SDHC card in an incompatible unit):
Sansa e200
 - verify the version of the player.  To check, go to SETTINGS > INFO
For 01.xx.xx firmware (e200 version 1) - up to 2GB microSD cards
For 03.xx.xx firmware (e200 version 2) - up to 16GB microSDHC cards
NOTE: Firmware is not interchangeable.
Sansa e200R - up to 2GB microSD cards
Sansa e100 - supports SD cards up to 2GB
Nov 12, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa  c250 (2 GB) MP3 Player (SDMX7-2048) Logo
810 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
