Question about Electric Mobility 4 Wheel Heavy Duty Mobility Electric Power Scooter
I have a milan mobility scooter,turn the key & it sounds a low
Beep,every second speed pot renewed + controller al was ok for a couple wks,then same again,except the scooter either went forward or reverse slowly on its own,then was told to renew speed pot,now left with the beep i previously described,its so frustrating it was a scooter repairer who looked at it,be honest he said i needed the last thing the speed pot & i would be back on road,plus im thinking did i really need the new controller im thinking of having the other 1 tested.please can anyone help.
  • 177 Answers
Hi. This sounds difficult. I have had a few scooters move slowly forward or in reverse, but not both. Normally if the speed pot ( wig wag ) is not exactly in the central position, they can do this.
It is possible for a scooter to have your problem, if the speed lever is binding or rubbing on the housing. Normally the lever is returned to the middle by a spring around the speed pot shaft. If this spring is loose or broken, then this could also cause the problem. Sometimes a small spot of oil or grease will help.
To check the speed lever is in the middle, slowly move the lever for forward untill you hear the brake solenoid release. Now release the lever and slowly pull it for reverse untill you hear the brake solenoid release. Make sure that the speed lever moves the same amount for forward as it does for reverse. If not adjust it with the key off.
If you get the machine to drive properly, then change the controller to see if it is OK.
As for the beeping, a lot of machines will go into an error mode if the speed lever is not in the central position when you turn the key on. This is a safety precausion.
Good luck. Neil.
Posted on Jun 07, 2010
Testimonial: "hello,thanks for ur info.i came to be here by paying for it,then ended up answering questions for others,my scooter is still not working.its a long story but i have learned a lot & have lived my life helping others.i recently downloaded info from shoprider,not having my scooter has depressed me like you wouldnt believe,but i will eventually get it sorted,this is my email if you wish to exchange info,i was punched off my scooter last year & suffered concusion.hence i have a problem getting to grip with things at times.the CPS dropped the charges against the young male 150 people there i had it put in local paper for witnesses with no help lol.gotta laugh whats the point moaning colintaylor1957@hotmail.co.uk"
Please robin - try to understand - you tell me that the beeper is attached to the cable - i don't know where the cable is - don't tell me its by the controller - i don't know what the controller is or
the beeps are diagnostic beep codes and the sounder should not be disconnected,
count the number of beeps then refer to my chart.will tell you what problem is
2 battery voltage too low =fully charge min 8 hours
3 volts too high =contact dealer
5 scooter in freewheel or Brake trip=chech in drive then turn on
6 throttle wig wag faulty or not in center when turning key
7 throttle or speed pot wireing or faulty
8 motor faulty or wireing poor /disconnected
9 battery pack pads and terminals coroded .replace them £2 eachn from pride or controller faulty ..replace
Advisory the analog battery guages on these regulary go faulty and read over full get electrical friend to check battery volts 12.8 to 13volt =fully charged
Dec 29, 2014 | Pride Go-Go Sport 4-Wheel
Can I bypass the speed pot
No, the controller checks the resistance of the combination of the speed and throttle pots on startup.
Oct 12, 2014 | Pride Celebrity X 4-Wheel Electric Scooter...
When I want to get scooter to go, it just beeps.
2 beeps=too low battery voltage
3 beeps=battery voltage too high
5 beeps=solenoid brake trip or free wheel mode
remove key then push then push the manual release lever in completely
6 beeps=throttle trip
throttle control lever may have been depressed while
inserting key so release control lever completely
7 beeps=throttle trip
throttle potentiometer fault or speed potentiometer fault
Oct 01, 2014 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
What does the 7 beep code mean on my Pride Victory 10 scooter mean when I turn the key on ?
This is a speed pot or throttle control problem (wig-wag) have you had some speed issues with the scooter before this happened, if so the wig-wag needs replacing. Make sure it is in the centre position at rest and switch the scooter on again.
Jul 11, 2014 | Pride Mobility Products Pride Victory 10 -...
I have a celebrity pride 3 wheel scooter and when i move lever to forward or reverse all it does is click but no movement
Have you checked the speed pot is not turned down too low?
No flash / beep codes.
I would check motor connector on drive unit, motor brushes.
May 24, 2014 | Pride Mobility Products Pride Celebrity XL...
How to stop a continuing beep on my Cordoba scooter when I turn the key on? The scooter don't move at all.
Hi Mag,
I have this steps that might help you with beeping sound on your Scooter. Hope it helps.
UNIT LIGHTS UP/HORN WORKS BUT UNIT WILL NOT MOVE
Possible Cause:
  • This often occurs when the scooter is in free wheel mode and is not in drive mode. Re-Engage the free wheel lever which is located down near the rear wheels (normally a yellow or red lever).
  • If you hear a beeping noise, the beeping you hear is a fault beep indicating the scooter main control box has detected a problem. Contact your dealer who can diagnose the beep code.
  • Check batteries with load tester - If either battery drops more than 1 volt under a load, the battery(s) are bad. Replace "both" batteries.
I also find these additional steps on how to know beep alarm indicators:
This main control box has a self-diagnostics feature & cannot be tested with a volt meter. When a
problem is present the main control box will diagnose the fault, prohibit the scooter from being driven
and sound an alert beep. Each alert beep indicates a different issue which helps to determining the
problem by narrowing the fault into one of a few main areas of the scooter. Reference this information
below for the alert beep indications.
Very Rapid beep- Batteries are low. Charge & test batteries.
Medium Fast beep- Motor/brake wiring fault. Free wheel lever disengaged.
Solid beep- The charger is plugged into the scooter (some models may vary).
Very Slow beep- The throttle pot was not at center when you turned the unit on. Throttle pot off
center or wiring (yellow & orange wires) fault.
Apr 24, 2014 | Shoprider Health & Beauty
Hi my scooter will drive in reverse on its own at all kinds of speeds if u leave the key on and is slow in forward only it will only stop in reverse if you turn of key or disconnect the forward or reverse...
Hi tandseaster,
I have owned my own business for 3 years and have been working on scooters and powerchairs for 15 years. I know exactly what the problem is. I can almost tell you what kind of scooter you have. In the future give as much info about the scooter as possible.
Your problem is the throttle pot or somtime called the engager.
You can do one of two things. 1. Open the faceplate to your tiller. look for a lock nut on the throttle pot. loosen it, on the bottom of the pot is a slot for a flat tip screwdriver. Take the key out before you start this procedure. You can turn the screw slot on the pot a little at a time, one way then the other. Turn the key back on, turn the speed pot to lowest speed so the scooter won't take off on you. Once you align the throttle pot to neutral tighten the lock nut. The easiest way to fix your problem is:
2. Replace the throttle pot.
Your problem will be fixed.
Good Luck
Tim
May 02, 2011 | Health & Beauty
7 bleeps on my GO GO ELITE TRAVELLER SCOOTER
Hi. 7 beeps is fault code for a faulty speed potentiometer. Might also be a broken wire on the pot or a faulty connector. Most times, a new pot will fix the problem.
Good luck. Neil.
Jul 08, 2010 | Pride Go Go Elite Traveller Plus HD 4...
SCOOTER WON,T MOVE OR MOVES ERRATIC LED INDACATES SPEED POT AT FAULT
hi, ok that's sounds about right, the speed pot hat is attached to the throttle lever is normally about 5K in value.
Feb 14, 2010 | Hurricane Pride PMV Mobility Scooter -...
Mayfair freerider mobility scooter - keeps losing power, especially on slow speed
ok, sounds like the speed pot,
Can you move the throttle lever up and down, try going along at a constant speed (losing power ?) then move the lever up & down ?
does it improve response ? if so replace the speed pot.
Regards
GeWiz.
Oct 18, 2009 | Health & Beauty
Electric Mobility 4 Wheel Heavy Duty Mobility Electric Power Scooter Logo
378 people viewed this question
Top Electric Mobility Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
wcdoc1953
wcdoc1953
Are you an Electric Mobility Health and Beauty Expert? Answer questions, earn points and help others
